查看: 2511|回复: 4
[已解决] 求creo1.0的config.pro文件
发表于 2011-12-29 17:26:30 | 显示全部楼层 |阅读模式
帮帮忙啊求助
28
发表于 2011-12-29 21:40:36 | 显示全部楼层
pro_unit_length unit_mm
pro_unit_mass unit_kilogram
template_designasm D:\Program Files\PTC\Creo 1.0\Common Files\M010\templates\mmns_asm_design.asm
template_drawing D:\Program Files\PTC\Creo 1.0\Common Files\M010\templates\a4_drawing.drw
template_sheetmetalpart D:\Program Files\PTC\Creo 1.0\Common Files\M010\templates\mmns_part_sheetmetal.prt
template_solidpart D:\Program Files\PTC\Creo 1.0\Common Files\M010\templates\mmns_part_solid.prt
drawing_setup_file $PRO_DIRECTORY\text\prodetail.dtl
format_setup_file $PRO_DIRECTORY\text\prodetail.dtl
todays_date_note_format %Mmm-%dd-%yy
tolerance_standard ansi
tol_mode nominal
weld_ui_standard ansi
enable_flexmove_tool yes
dxf_out_scale_views yes
file_open_default_folder working_directory
pro_unit_sys mmns
allow_anatomic_features yes
default_draw_scale 1:1
trail_dir e:\CREO\temp
display_full_object_path yes
display_points no
display_axes yes
display_coord_sys yes
display_planes yes
pdf_use_pentable yes
open_window_maximized yes
preserve_comp_color_in_preview yes
save_texture_with_model yes
frt_enabled yes
default_object_scope_setting skeleton_model
ref_scope_no_pick_to_copy yes
pro_colormap_path E:\proE\appearance.dmt
pro_font_dir C:\WINDOWS\Fonts
web_browser_homepage about:blank
ncpost_type gpost
creo_less_restrictive_names yes
system_colors_file E:\CREO\syscol.scl
save_display yes
这事我的配置,有些需要自己设置的,路径不一样的
 楼主| 发表于 2011-12-30 17:33:30 | 显示全部楼层
回复 2# jiangfeigood
    谢谢老大谢谢
 楼主| 发表于 2011-12-30 17:39:16 | 显示全部楼层
谢谢版主谢谢
发表于 2012-1-19 16:26:47 | 显示全部楼层
{:soso_e181:}谢谢共享
GMT+8, 2025-2-20 23:50
