查看: 11807|回复: 40
[分享] Creo3.0全模块新增功能详解
发表于 2014-6-19 09:08:45 | 显示全部楼层 |阅读模式
Creo3.0全模块新增功能详解
Creo3.0全模块新增功能详解
Creo3.0全模块新增功能详解
Creo3.0全模块新增功能详解
Creo3.0全模块新增功能详解
基础 ...........................................................................................................................7
质量属性的改进....................................................................................................8
重定向模型变得更为简单.......................................................................................8
窗口将自动激活....................................................................................................8
自定义快捷菜单....................................................................................................9
设计探索...................................................................................................................11
“设计探索”可用...................................................................................................12
在“设计探索”中存储更改......................................................................................13
零件建模 (零件、PTC Creo Flexible Modeling)............................................................15
复制曲面时取消修剪 ...........................................................................................16
弦倒圆角............................................................................................................16
重新排序功能得到了增强.....................................................................................17
易于标识只读特征...............................................................................................17
边界混合增强功能...............................................................................................18
展平面组增强功能...............................................................................................19
PTC Creo Flexible Modeling 中的倒角支持...........................................................20
PTC Creo Flexible Modeling 中增强的倒圆角支持.................................................21
PTC Creo Flexible Modeling 中的相切传播和控制.................................................21
PTC Creo Flexible Modeling 中的阵列传播...........................................................22
PTC Creo Flexible Modeling 中的新挠性阵列工具.................................................23
插入模式的入口点...............................................................................................23
“骨架折弯”用户界面得到了增强............................................................................23
编辑参考的增强功能 ...........................................................................................24
显示缺失参考 .....................................................................................................25
参考零件建模中的阵列........................................................................................25
可变拓扑上的几何阵列........................................................................................26
新布局特征.........................................................................................................26
布局特征的更新控制 ...........................................................................................27
数据交换...................................................................................................................29
从 PTC Creo Elements/Direct 导入绘图................................................................30
导入时,支持产品制造信息 (PMI) ........................................................................30
支持 JT 9.5.........................................................................................................31
JT 支持平面和区域横截面 ...................................................................................32
JT 支持注释语义交换..........................................................................................32
JT 支持使用颜色.................................................................................................32
支持 JT 中的角度控制 .........................................................................................33
详细绘图...................................................................................................................35
用于创建尺寸的用户界面得到了改进....................................................................36
用于创建注解的用户界面得到了改进....................................................................36
几何公差增强功能...............................................................................................37
注释的安全标记指定 ...........................................................................................38
组合状态的超链接...............................................................................................38
注解中的符号 .....................................................................................................39
PTC Creo Layout ......................................................................................................41
导入功能得到了改进 ...........................................................................................42
支持剖面线和填充...............................................................................................42
倒角工具得到了改进。........................................................................................43
新建子布局.........................................................................................................43
草绘增强功能 .....................................................................................................44
PTC Creo Layout 模型树.....................................................................................45
尺寸属性............................................................................................................45
支持参数............................................................................................................46
选择功能得到了改进 ...........................................................................................46
曲面设计 (自由式、造型、专业曲面设计) ....................................................................47
对齐自由式几何..................................................................................................48
连接自由式几何..................................................................................................48
在自由式特征中拖动 ...........................................................................................49
造型中的扫描几何...............................................................................................49
在造型特征中合并曲面........................................................................................50
造型中的等值线..................................................................................................50
在专业曲面设计中计算连接 .................................................................................50
改进了节点分析功能 ...........................................................................................51
渲染 (照片级逼真渲染)...............................................................................................53
操控 HDR 图像...................................................................................................54
逼真的凹凸映射..................................................................................................54
逼真的外观.........................................................................................................55
透明显示的改进..................................................................................................56
环境光遮蔽可用..................................................................................................56
装配设计 (Intelligent Fastener,装配) .........................................................................57
PTC Creo Intelligent Fastener..............................................................................58
PTC Creo Intelligent Fastener (Lite).....................................................................58
数据共享特征的更新控制.....................................................................................59
通知得到了收集且便于访问 .................................................................................61
用于控制外部参考的新选项 .................................................................................61
4 新增功能:PTC Creo Parametric 3.0
装配中的状况报告功能得到了改进 .......................................................................62
“选取器”对话框的改进.........................................................................................62
会话中的更新功能得到了改进..............................................................................62
族表中的改进 .....................................................................................................63
识别活动元件变得更为容易。..............................................................................63
Advanced Framework Design ....................................................................................65
组装和测量得到了改进........................................................................................66
复制子装配变得更为容易.....................................................................................66
更多选项可从快捷菜单进行访问...........................................................................66
电气设计 (缆、ECAD、线束制造)...............................................................................69
“缆”中的束过渡...................................................................................................70
PTC Creo View 中缆的支持得到了增强 ................................................................70
装配的 ECAD 子类型 ..........................................................................................70
ECAD 刚挠性电路板 ...........................................................................................71
线束制造............................................................................................................72
制造 (NC 制造)..........................................................................................................73
体积块铣削的新用户界面.....................................................................................74
粗加工步骤中的连接得到了增强...........................................................................74
轨迹铣削的新用户界面........................................................................................75
切割线铣削的刀具轴控制.....................................................................................76
多任务加工.........................................................................................................77
锥形螺纹铣削 .....................................................................................................79
模具设计与铸造.........................................................................................................81
使用延伸曲线创建分型面.....................................................................................82
使用填充环创建分型面........................................................................................82
拔模分析得到了改进 ...........................................................................................82
检查 3D 深度......................................................................................................83
钣金件 (钣金件设计) ..................................................................................................85
“平整成型”和“平整形态”得到了增强 ......................................................................86
凹模用户界面得到了改进.....................................................................................86
折弯止裂槽方面的改进........................................................................................87
“扯裂连接”和“草绘扯裂”工具得到了增强................................................................87
折弯单个特征中的共面曲面 .................................................................................88
PTC Creo Simulate ...................................................................................................89
用于显示 PTC Creo Simulate 中的结果的新用户界面 ............................................90
支持映射键.........................................................................................................91
PTC Creo Simulate 支持 Unicode ........................................................................92
PTC Creo Simulate 的性能改进 ...........................................................................92
PTC Creo Simulate 支持 ANSYS 14.5..................................................................93
目录 5
PTC Creo Simulate 支持 MSC Nastran 2012 ........................................................93
求解器引擎 I/O 的性能调整得到了改进 .................................................................94
图标得到了更新..................................................................................................94
更改图元颜色 .....................................................................................................95
具有已定义预加载荷的紧固件的可用性改进..........................................................95
FEM 模式的改进.................................................................................................96
2D 分析中的受力连接..........................................................................................98
新增了简单的断裂力学........................................................................................98
用于确定最佳分析的改进过程..............................................................................99
用于创建注解的新工作流...................................................................................100
分析研究在模型树中列出...................................................................................101
用于查询结果的改进工作流 ...............................................................................102
定义存在有限摩擦的接触界面............................................................................104
适用于 2D 模型的映射的网格选项......................................................................105
壳、梁和紧固件的显示得到了改进 .....................................................................106
分析包含失败特征的模型...................................................................................107
用于创建线性化应力的更新过程.........................................................................108
多个载荷集的疲劳分析......................................................................................109
Creo3.0全模块新增功能详解-精诚网www.creoug.com.pdf (1.51 MB, 下载次数: 14)
32
发表于 2014-6-19 09:18:28 | 显示全部楼层
这个必须看,谢版主
发表于 2014-6-19 09:27:08 | 显示全部楼层
Creo3.0全模块新增功能详解
发表于 2014-6-19 09:39:37 | 显示全部楼层
这个要了解。谢谢分享
发表于 2014-6-19 09:43:19 | 显示全部楼层
感谢分享!
发表于 2014-6-19 09:47:01 | 显示全部楼层
下载后打开退出,文件是不是有问题?
发表于 2014-6-19 09:52:23 | 显示全部楼层
这个好,不错
发表于 2014-6-19 10:07:36 | 显示全部楼层
下载来看看!~
发表于 2014-6-19 10:09:52 | 显示全部楼层
看看加了哪些功能
发表于 2014-6-19 10:31:13 | 显示全部楼层
这个要了解增加了什么。谢谢分享
GMT+8, 2025-4-30 16:24
