楼主: kaiser1007
[原创] PTC CREO 2.0/3.0 CONFIG经典配置 2016版
发表于 2016-12-16 06:19:29 | 显示全部楼层
感觉不错,系统
发表于 2016-12-16 08:34:10 | 显示全部楼层
PTC CREO 2.0/3.0 CONFIG经典配置 2016版 http://bbs.creoug.com/forum.php? ... &fromuid=721944
发表于 2016-12-16 09:09:32 | 显示全部楼层
非常好,弥补自己的不足
发表于 2016-12-17 09:30:02 | 显示全部楼层
感谢分享感谢分享
 楼主| 发表于 2016-12-22 10:23:26 | 显示全部楼层
因补充内容已满,以此楼回复方式发贴
CREO 3.0快捷键优化
mapkey ane @MAPKEY_LABEL创建元件;~ Command `ProCmdCompCreate` ;\
mapkey(continued) @MANUAL_PAUSE请选择元件类型,输入名称,点击"恢复"按钮完成操作;~ Activate `comp_create` `OK`;\
mapkey(continued) ~ Activate `crt_opt_prt` `okbutton`;\
mapkey(continued) ~ Open `main_dlg_cur` `maindashInst0.constr_offset_type_2`;\
mapkey(continued) ~ Close `main_dlg_cur` `maindashInst0.constr_offset_type_2`;\
mapkey(continued) ~ Select `main_dlg_cur` `maindashInst0.constr_offset_type_2` 1 `Default`;\
mapkey(continued) ~ Activate `main_dlg_cur` `dashInst0.stdbtn_1`;
mapkey asm @MAPKEY_LABEL组装元件;~ Command `ProCmdCompAssem` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) @MANUAL_PAUSE请选择添加的元件,点击"恢复"按钮完成操作;\
mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;\
mapkey edi @MAPKEY_LABEL编辑定义;~ Command `ProCmdRedefine` ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.extrev_1_placement.0` 1;\
mapkey(continued) ~ Activate `extrev_1_placement.1.0` `PH.Sketch`;
mapkey sco @MAPKEY_LABEL复制几何;~ Command `ProCmdOduiDsfCopyGeom` ;\
mapkey(continued) ~ Select `main_dlg_cur` `maindashInst0.ExternalRadioGroup` 1 `ExternalOpt`;\
mapkey(continued) ~ Activate `main_dlg_cur` `maindashInst0.Open_ref_model`;\
mapkey(continued) @MANUAL_PAUSE请选择参考元件,点击"恢复"按钮继续操作;\
mapkey(continued) ~ Activate `cg_placement` `OKButton`;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.References.0` 1;\
mapkey(continued) ~ Trigger `References.0.0` `PH.Ref_Model` `0`;\
mapkey(continued) ~ Trigger `References.0.0` `PH.PGList` `0`;\
mapkey(continued) ~ Focus `References.0.0` `PH.PGList`;~ Select `References.0.0` `PH.PGList` 0;\
mapkey(continued) ~ Trigger `References.0.0` `PH.PGList` ``;\
mapkey(continued) @MANUAL_PAUSE请选择参考元件的发布几何,点击"恢复"按钮完成操作;\
mapkey(continued) ~ Enter `main_dlg_cur` `daGr_accs_proe_win` 3 1 182 0;\
mapkey(continued) ~ Move `main_dlg_cur` `daGr_accs_proe_win` 3 1 182 0;\
mapkey(continued) ~ Exit `main_dlg_cur` `daGr_accs_proe_win` 3 -39 173 0;\
mapkey(continued) ~ Activate `main_dlg_cur` `dashInst0.Done`;
mapkey $F2 @MAPKEY_LABEL工作目录;~ Command `ProCmdSessionChangeDir`;
mapkey $F3 @MAPKEY_LABEL打开文件;~ Command `ProCmdModelOpen`;
mapkey $F4 @MAPKEY_LABEL新建文件;~ Command `ProCmdModelNew`;
mapkey pri @MAPKEY_LABEL打印输出;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdModelPrint` ;~ Activate `print` `OK`;\
mapkey(continued) ~ Activate `main_dlg_cur` `main_dlg_cur`;
mapkey clo @MAPKEY_LABEL关闭窗口;~ Command `ProCmdWinCloseGroup`;
mapkey era @MAPKEY_LABEL试除内存;~ Command `ProCmdModelEraseNotDisp`;\
mapkey(continued) ~ Activate `file_erase_nd` `ok_pb`;
发表于 2016-12-22 15:22:24 | 显示全部楼层
急需Creo3.0配置文件,没有银子呢,怎么充值?
发表于 2016-12-22 22:35:13 | 显示全部楼层
感觉很专业
发表于 2016-12-23 09:17:49 | 显示全部楼层
没有银子,无法下载,呵呵
发表于 2016-12-24 16:57:35 | 显示全部楼层
还要银子呀!去哪加呀!
 楼主| 发表于 2016-12-25 07:44:40 | 显示全部楼层
Hogan 发表于 2016-12-24 16:57
还要银子呀!去哪加呀!
看贴不细心,帖子图片上有作者,QQ交流群,版本等信息,再看下吧
GMT+8, 2025-4-30 09:13
