查看: 5883|回复: 8
[求助] Creo 6.0.1.0配置好config文件后跳出自动回溯信息
发表于 2019-6-10 17:22:32 | 显示全部楼层 |阅读模式
一时心血来潮,装了Creo 6.0.1.0,所有的安装都很顺利,装完之后也运行了一次,没有任何问题,然后把之前用的config调整替换以后,就一直跳出自动回溯信息,弄不明白啊。求大神帮忙看看。
!Model unit setup
pro_unit_length UNIT_MM
pro_unit_mass UNIT_KILOGRAM
!system colors
system_colors_file D:\ptc\CreoWork5.0\config\syscol.scl
!Drawing & format setup files
drawing_setup_file D:\ptc\CreoWork5.0\config\drawing.dtl
format_setup_file D:\ptc\CreoWork5.0\config\format.dtl
!template models directory
template_designasm D:\ptc\CreoWork5.0\templates\start_asm.asm
template_sheetmetalpart D:\ptc\CreoWork5.0\templates\start_sheet.prt
template_solidpart D:\ptc\CreoWork5.0\templates\start_part.prt
template_harnesspart D:\ptc\CreoWork5.0\templates\start_part.prt
template_flat_harness D:\ptc\CreoWork5.0\templates\mmks_flat_harness.asm
template_mfgnc D:\ptc\CreoWork5.0\templates\mmks_mfg_nc.asm
template_mfgmold D:\ptc\CreoWork5.0\templates\mmks_mfg_mold.asm
!Default Path
pro_format_dir D:\ptc\CreoWork5.0\format
pro_symbol_dir D:\ptc\CreoWork5.0\symbol
start_model_dir D:\ptc\CreoWork5.0\templates
trail_dir D:\ptc\temp\Creotemp5.0\temp
train_file_path D:\ptc\temp\Creotemp5.0
pro_group_dir D:\ptc\CreoWork5.0\group
pro_note_dir D:\ptc\CreoWork5.0\notes
pro_library_dir D:\ptc\CreoWork5.0\library
pro_material_dir D:\ptc\CreoWork5.0\material
pro_table_dir D:\ptc\CreoWork5.0\table
mdl_tree_cfg_file D:\ptc\CreoWork5.0\config\tree.cfg
pro_catalog_dir D:\ptc\CreoWork5.0\library
pro_pip_lnstk_dir D:\ptc\CreoWork5.0\linestock
!ptc_manikin_library
ptc_manikin_library_path D:\ptc\CreoWork5.0\library\manikin_lib
ptc_manikin_posture_path D:\ptc\CreoWork5.0\library\manikin_lib\Postures
!Tolerence Setup
tol_mode nominal
tolerance_standard ISO
tolerance_class MEDIUM
!Layer Setup
def_layer LAYER_DATUM               DATUM
def_layer LAYER_AXIS                AXIS
def_layer LAYER_CSYS                CSYS
def_layer LAYER_POINT               POINT
def_layer LAYER_CURVE               CURVE
def_layer LAYER_QUILT               QUILT
def_layer layer_surface             SURFS
def_layer layer_hole_feat             HOLES
def_layer layer_draft_feat             DRAFTS
def_layer layer_round_feat             ROUNDS
def_layer layer_chamfer_feat             CHAMFER
def_layer layer_cosm_sketch             COSMETICS
def_layer layer_copy_geom_feat             COPY_GEOM
def_layer layer_skeleton_model      skeleton
def_layer layer_detail_item             DETAILS
def_layer layer_draft_dim             DRAFT_DIMS
def_layer layer_refdim                     REF_DIMS
def_layer layer_gtol                     GTOLS
def_layer layer_symbol                     SYMBOLS
def_layer layer_note                     NOTES
def_layer layer_dwg_table             TABLES
def_layer layer_draft_geom             DRAFT_GEOM
!setup plotter
pen1_line_weight 4
pen2_line_weight 2
pen3_line_weight 2
pen4_line_weight 2
pen5_line_weight 2
pen6_line_weight 2
pen7_line_weight 2
pen8_line_weight 2
plotter a3_pdf_plotter
plotter_command WINDOWS_PRINT_MANAGER
pro_plot_config_dir D:\ptc\CreoWork5.0\plotter
use_8_plotter_pens yes
pen_table_file D:\ptc\CreoWork5.0\config\table.pnt
!save_model_display shading_low
save_drawing_picture_file embed
!System environment
default_ui_font 宋体
menu_font 宋体
model_tree_font 宋体
popuphelp_font 宋体
make_parameters_from_fmt_tables yes
display shade
highlight_new_dims yes
parenthesize_ref_dim yes
!system_edge_high_color 100 100 0
bell NO
clock no
prompt_on_exit yes
default_dec_places 3
default_ang_dec_places 3
menu_translation yes
msg_translation yes
dialog_translation yes
pro_font_dir C:\Windows\Fonts
!system_letter_color 100 100 0
general_undo_stack_limit 10
rename_drawings_with_object both
multiple_skeletons_allowed yes
enable_absolute_accuracy yes
default_abs_accuracy 0.001
display_silhouette_edges yes
allow_move_view_with_move yes
verify_on_save_by_default yes
!model_note_display yes
visible_message_lines 3
!Intralink environment
web_browser_homepage about:bland
dm_http_compression_level 3
!model display
display_planes no
display_axes no
display_coord_sys no
display_points no
spin_center_display no
pdf_use_pentable yes
allow_anatomic_features yes
menu_show_instances no
save_objects changed
save_object_in_current yes
override_store_back yes
pipe_solid_centerline yes
compress_output_files yes
save_texture_with_model yes
dm_auto_open_zip yes
dm_cache_mode all
dm_overwrite_contents_on_update yes
dm_remember_server yes
dm_secondary_upload automatic
dm_upload_objects explicit
use_temp_interface_for_paste no
dxf_out_drawing_scale yes
dxf_out_scale_views yes
intf_out_layer part_layer
save_display yes
spin_with_orientation_center yes
spin_with_part_entities yes
sketcher_dimension_autolock yes
sketcher_lock_modified_dims yes
sketcher_starts_in_2d yes
sket_import_geometry_line_style yes
create_temp_interfaces no
auto_place_max_number 5
dxf_export_format 2000
dwg_export_format 2000
intf2d_out_dxf_mapping_file D:\ptc\CreoWork5.0\config\Dxf_export.pro
display_coord_sys_tags yes
display_annotations no
display_point_tags yes
display_axis_tags yes
display_plane_tags yes
dm_cache_limit 16000
freeze_failed_cable_locations yes
load_ui_customization_run_dir yes
auto_add_remove yes
hlr_for_quilts yes
mass_property_calculate automatic
display_thick_cables yes
max_animation_time 0.1
open_window_maximized yes
!各种软件挂载选项
protkdat D:\ptc\CreoWork5.0\config\protk.dat
!加载AFX
afx_enabled yes
!解锁PDM锁定参数选项
!allow_create_pdm_param yes
!搜索路径选项
search_path_file D:\ptc\CreoWork5.0\config\Search.pro
!管道密度不更新问题
piping_material_source material_dir
!草绘修改尺寸不缩放界面
sketcher_refit_after_dim_modify no
graphics win32_gdi
default_draw_scale 1.0
orientation isometric
spin_with_silhouettes yes
edge_display_quality high
enable_fsaa 16
shade_quality 10
自动回溯信息
自动回溯信息
电脑配置
电脑配置
电脑里安装的软件
电脑里安装的软件
电脑里安装的软件
电脑里安装的软件
 楼主| 发表于 2019-6-10 17:35:01 | 显示全部楼层
我把config文件里的设置一行一行的排除之后,发现“load_ui_customization_run_dir yes”改为“load_ui_customization_run_dir no”就可以启动了,但是这样不就不能自定义UI了吗?
问题点
问题点
发表于 2019-6-11 08:31:42 | 显示全部楼层
呵呵,很有心找问题。
发表于 2019-6-11 09:12:07 | 显示全部楼层
删除工作目录的UI文件,重新设置,试一下
 楼主| 发表于 2019-6-11 09:41:41 | 显示全部楼层
谢谢您的回复,已尝试,还是不行。
 楼主| 发表于 2019-6-11 17:50:18 | 显示全部楼层
已经解决了,重新装了系统,不管WIN10还是WIN7,一定记得装原版的系统,GHOST系统就会有问题。
发表于 2019-6-13 08:47:23 | 显示全部楼层
真是花了功夫啊!!!
发表于 2019-6-18 10:43:27 | 显示全部楼层
给你的验证精神点赞 我也是用的自己的ui 没问题 win10
发表于 2019-6-25 22:57:20 | 显示全部楼层
我安装完creo 用了配置后 创建零件也发生了 严重错误  你帖子里说是系统ghost的原因 拿非gohst的系统版本是什么版本啊
GMT+8, 2025-2-26 13:15
