查看: 36168|回复: 154
[分享] 关于creo4.0安装edrawings,已经可以成功安装
 火... [复制链接]
发表于 2017-1-17 09:20:21 | 显示全部楼层 |阅读模式
种子文件在这里
根据soliduser的回答,本人昨天晚上已经安装成功。
How to install eDrawings for Creo 10.6 for Creo 4.0 (by SSQ)
eDrawings for Creo 10.6 does not support Creo 4.0 and can not be installed for Creo 4.0 with standard installation procedure
to install it you need
1. Go to <Creo 4.0 program folder>\F000\Common Files\bin\pim\xml  (by default C:\Program Files\PTC\Creo 4.0\F000\Common Files\bin\pim\xml) and make backup copy of file "creobase.p.xml"
2. Open "creobase.p.xml" in text editor and edit string
<RODUCT ARP="TC Creo Common Files" datecode="2016390" family="Creo" name="Creo Common Files" parentonly="Y" shipcode="F000" tag="creobase.xml" version="4.0">
to
<RODUCT ARP="TC Creo Common Files" datecode="2016390" family="Creo" name="Creo Common Files" parentonly="Y" shipcode="M120" tag="creobase.xml" version="3.0">
3. Save "creobase.p.xml"
4. Run setup "eDrawingsForProE_Creo_10_6_64Bit.exe"
5. Select "Install eDrawings Viewer + eDrawings Publisher for Pro/ENGINEER"
6. On the next page for "Select Pro/ENGINEER path for additional versions" click "Add Pro/E..."
7. Browse to <Creo 4.0 program folder>\F000\Common Files (by default C:\Program Files\PTC\Creo 4.0\F000\Common Files) and click "OK"
8. Install eDrawings for Creo v10.6
9. Restore original "creobase.p.xml"
10. Now you can use eDrawings for Creo 10.6 from Creo 4.0 interface
发表于 2017-1-17 09:32:53 | 显示全部楼层
看下怎么安装,谢谢楼主分享!
发表于 2017-1-17 10:19:18 | 显示全部楼层
看下怎么安装,谢谢楼主分享!
发表于 2017-1-17 10:19:25 | 显示全部楼层
这个可以支持下
发表于 2017-1-17 10:52:40 | 显示全部楼层
那么快就攻克了?
发表于 2017-1-17 11:02:27 | 显示全部楼层
看下怎么安装,谢谢楼主分享!
发表于 2017-1-17 11:16:00 | 显示全部楼层
谢谢楼主分享
发表于 2017-1-17 12:01:10 | 显示全部楼层
看下怎么安装,谢谢楼主分享!
发表于 2017-1-17 12:01:24 | 显示全部楼层
看看下一个.
发表于 2017-1-17 12:02:46 | 显示全部楼层
看下怎么安装,谢谢楼主分享!
GMT+8, 2025-2-24 22:04
