查看: 2859|回复: 0
[分享] NX 8.5 单位系统的汉化问题
发表于 2013-12-25 09:50:57 | 显示全部楼层 |阅读模式
最近研究了一下表达式和单位系统,然后为了查看UG中可用的单位,于是就写了一个简单的程序测试了一下,结果发现了一些搞笑的翻译,很有可能是中文版的汉化问题。
代码是这样的:
  1. Session theSession = Session.GetSession();
  2. UI theUI=UI.GetUI();
  3. Part workPart = theSession.Parts.Work;
  4. UnitCollection uc = workPart.UnitCollection;
  5. ExpressionCollection ec = workPart.Expressions;
  6. StreamWriter sw=new StreamWriter(@"C:\Measures In NX.txt");
  7. foreach (string s in uc.GetMeasures())
  8. {
  9.     sw.WriteLine(s);
  10.     foreach (Unit u in uc.GetMeasureTypes(s))
  11.         sw.WriteLine("Name:" + u.Name + "\t\t\tAbbreviation:" + u.Abbreviation);
  12.     sw.WriteLine("--------------------------------");
  13. }
复制代码
然后我的到文本文件内容是这样的,注意红色的内容,括号内容是我的疑问:
长度
Name:米                        Abbreviation:m
Name:毫米                        Abbreviation:mm
Name:英寸                        Abbreviation:in
Name:英尺                        Abbreviation:ft
Name:CentiMeter                        Abbreviation:cm
(为什么前面用中文的米,后面用英文的CentiMeter,而不是厘米?可能主单位都翻译了,但是非主要单位就没有翻译?
Name:KiloMeter                        Abbreviation:km
Name:Mile                        Abbreviation:mi
Name:Micron                        Abbreviation:micron
Name:NanoMeter                        Abbreviation:nm
Name:Angstrom                        Abbreviation:埃(这里又是中文……)
面积
Name:平方米                        Abbreviation:m^2
Name:SquareMilliMeter                        Abbreviation:mm^2
Name:SquareInch                        Abbreviation:in^2
Name:SquareFeet                        Abbreviation:ft^2
Name:SquareCentiMeter                        Abbreviation:cm^2
体积
Name:立方米                        Abbreviation:m^3
Name:CubicMilliMeter                        Abbreviation:mm^3
Name:CubicInch                        Abbreviation:in^3
Name:CubicFeet                        Abbreviation:ft^3
Name:CubicCentiMeter                        Abbreviation:cm^3
质量
Name:千克                        Abbreviation:kg
Name:Gram                        Abbreviation:g
Name:Tonne                        Abbreviation:t
Name:Slug                        Abbreviation:slug(lbf-sec^2/ft)
Name:PoundSecondsSquaredPerInch                        Abbreviation:lbf-sec^2/in
Name:PoundMass                        Abbreviation:lbm
Name:KilogramForceSecondsSquaredPerMeter                        Abbreviation:kgf-sec^2/m
Name:KilogramForceSecondsSquaredPerMilliMeter                        Abbreviation:kgf-sec^2/mm
质量密度
Name:千克/立方米                        Abbreviation:kg/m^3
Name:KilogramPerCubicMilliMeter                        Abbreviation:kg/mm^3
Name:TonnePerCubicMeter                        Abbreviation:T/m^3
Name:TonnePerCubicMilliMeter                        Abbreviation:T/mm^3
Name:PoundsSecondSquaredPerInchFourth                        Abbreviation:lbf-sec^2/in^4
Name:SlugsPerCubicFeet                        Abbreviation:Slug/ft^3
Name:PoundMassperCubicInch                        Abbreviation:lbm/in^3
疲劳强度系数
Name:MilliNewtonPerSquareMilliMeter                        Abbreviation:mN/mm^2(kPa)
Name:NewtonPerSquareMilliMeter                        Abbreviation:N/mm^2(MPa)
Name:Pascals                        Abbreviation:Pa(N/m^2)
Name:PoundForcePerSquareInch                        Abbreviation:lbf/in^2(psi)
时间
Name:第二个(这个我就不吐槽了)        Abbreviation:sec
Name:分                        Abbreviation:min
Name:小时                        Abbreviation:hr
角度
Name:弧度                        Abbreviation:弧度
Name:度                        Abbreviation:度
后面还有一些,我就不都贴出来了,不然长度超标了……
GMT+8, 2026-9-19 18:07
