楼主: renmm
[求助] 半螺旋槽的加工方法
发表于 2019-10-19 19:33:37 | 显示全部楼层
拿走,不谢
20191019.prt (937.5 KB, 下载次数: 314)
发表于 2019-10-20 08:09:43 | 显示全部楼层
666666666666666666666
发表于 2019-10-20 10:10:47 来自手机 | 显示全部楼层
加我 我教你
50
发表于 2019-10-20 10:22:23 | 显示全部楼层
这种5轴加工中心才能实现。
发表于 2019-10-20 10:31:08 | 显示全部楼层
大哥你用的1855?
发表于 2019-10-20 10:52:34 | 显示全部楼层
你这个是什么版本的?我1863也打不开。
发表于 2019-10-20 10:53:08 | 显示全部楼层
这个是四轴的吗?
 楼主| 发表于 2019-10-20 15:47:00 | 显示全部楼层
您好,您用的ug版本太高了,太多网友没有安装最新版,老师能否用12.0编辑下下刀路,万分感谢,如果您电脑是没有低版本的UG,可以发个图文教程,鄙人愚昧,顺便问一下,用曲面区域指定侧壁,会报警,不能构建栅格线,老师是不是建铺助曲面了,谢谢{:smile:}
发表于 2019-10-20 19:26:26 | 显示全部楼层
renmm 发表于 2019-10-19 13:35
不会设置参数呀,还请老师指教
29
发表于 2019-10-20 20:08:48 | 显示全部楼层
550115 发表于 2019-10-19 11:46
一刀切,目前只有顺序铣可以解决。
一刀切,纯四轴程序,非顺序铣 {:smile:}
TOOL PATH/01,TOOL,D4
TLDATA/MILL,4.0000,0.0000,75.0000,0.0000,0.0000
MSYS/0.0000,0.0000,0.0000,1.0000000,0.0000000,0.0000000,0.0000000,1.0000000,0.0000000
$$ centerline data
PAINT/PATH
PAINT/SPEED,10
PAINT/COLOR,186
RAPID
GOTO/-23.6500,20.5300,11.3400,0.0000000,0.8554841,0.5178291
PAINT/COLOR,211
RAPID
GOTO/-23.6500,16.2539,8.7516
PAINT/COLOR,42
FEDRAT/MMPM,250.0000
GOTO/-23.6500,8.3619,3.9745
CIRCLE/-23.6500,8.9833,2.9480,0.0000000,-0.8554841,-0.5178291,1.2000,0.0600,0.5000,4.0000,0.0000
GOTO/-22.4500,8.9833,2.9480
PAINT/COLOR,31
GOTO/-22.4500,9.2550,1.9310,0.0000000,0.9176978,0.3972791
GOTO/-22.4500,9.4116,0.8900,0.0000000,0.9631417,0.2689945
GOTO/-22.4500,9.4511,-0.1619,0.0000000,0.9907595,0.1356304
GOTO/-22.4500,9.3733,-1.2116,0.0000000,1.0000000,0.0000000
GOTO/-22.4142,9.3530,-1.6742,0.0000000,1.0000000,0.0000004
GOTO/-22.3088,9.3305,-2.1211,0.0000000,1.0000000,0.0000000
GOTO/-22.2639,9.2398,-2.3125,0.0000000,1.0000000,0.0000072
GOTO/-22.2500,9.1212,-2.5000,0.0000000,1.0000000,0.0000000
GOTO/-22.2500,8.8833,-3.2609,0.0000000,0.9999994,0.0011031
GOTO/-22.2500,8.5844,-4.0000,0.0000000,1.0000000,0.0000000
GOTO/-22.3424,7.9195,-4.4718,0.0000000,1.0000000,0.0000043
GOTO/-22.5938,7.1773,-4.8611,0.0000000,1.0000000,0.0000093
GOTO/-22.9816,6.5114,-5.1374,0.0000000,1.0000000,-0.0000322
GOTO/-23.5000,6.2062,-5.2500,0.0000000,1.0000000,0.0000000
GOTO/-24.0181,6.5113,-5.1376,0.0000000,1.0000000,0.0000025
GOTO/-24.4062,7.1774,-4.8611,0.0000000,1.0000000,-0.0000051
GOTO/-24.6576,7.9195,-4.4719,0.0000000,1.0000000,0.0000058
GOTO/-24.7500,8.5844,-4.0000,0.0000000,1.0000000,0.0000000
GOTO/-24.7500,8.8833,-3.2609,0.0000000,0.9999994,0.0011031
GOTO/-24.7500,9.1212,-2.5000,0.0000000,1.0000000,0.0000000
GOTO/-24.7361,9.2398,-2.3125,0.0000000,1.0000000,0.0000072
GOTO/-24.6912,9.3305,-2.1211,0.0000000,1.0000000,0.0000000
GOTO/-24.5858,9.3530,-1.6742,0.0000000,1.0000000,0.0000004
GOTO/-24.5500,9.3733,-1.2116,0.0000000,1.0000000,0.0000000
GOTO/-24.5500,9.4339,-0.5808,0.0000000,0.9968607,0.0791757
GOTO/-24.5500,9.4524,0.0527,0.0000000,0.9874374,0.1580107
GOTO/-24.5500,9.4282,0.6860,0.0000000,0.9717665,0.2359445
GOTO/-24.5500,9.3616,1.3162,0.0000000,0.9499435,0.3124219
GOTO/-24.5500,9.2528,1.9406,0.0000000,0.9221215,0.3869003
GOTO/-24.5500,9.1022,2.5562,0.0000000,0.8885100,0.4588572
GOTO/-24.5500,8.9106,3.1603,0.0000000,0.8493708,0.5277965
GOTO/-24.5500,8.6792,3.7504,0.0000000,0.8050145,0.5932552
GOTO/-24.4997,8.5381,4.2092,0.0000000,0.8059254,0.5920171
GOTO/-24.3472,8.3375,4.6007,0.0000000,0.8062438,0.5915835
GOTO/-24.3472,8.3375,4.6007,0.0000000,0.8062436,0.5915837
GOTO/-23.6888,7.8762,5.3609,0.0000002,0.7483696,0.6632820
GOTO/-23.2259,7.5328,5.8337,-0.0000006,0.7063166,0.7078961
GOTO/-22.7619,7.1606,6.2850,-0.0000001,0.6614683,0.7499731
GOTO/-22.2972,6.7607,6.7130,0.0000003,0.6141284,0.7892061
GOTO/-21.8328,6.3354,7.1156,0.0000004,0.5645062,0.8254288
GOTO/-21.3686,5.8862,7.4914,0.0000002,0.5127744,0.8585234
GOTO/-20.9044,5.4149,7.8389,0.0000000,0.4591127,0.8883780
GOTO/-20.4402,4.9232,8.1567,-0.0000001,0.4037094,0.9148872
GOTO/-19.9759,4.4128,8.4436,-0.0000001,0.3467734,0.9379489
GOTO/-19.5117,3.8858,8.6987,-0.0000001,0.2885247,0.9574725
GOTO/-19.0474,3.3442,8.9210,-0.0000001,0.2291876,0.9733823
GOTO/-18.5832,2.7898,9.1095,0.0000000,0.1689875,0.9856182
GOTO/-18.1189,2.2249,9.2636,0.0000000,0.1081493,0.9941347
GOTO/-17.6546,1.6517,9.3828,0.0000000,0.0469020,0.9988995
GOTO/-17.1904,1.0722,9.4666,0.0000000,-0.0145229,0.9998945
GOTO/-16.7261,0.4887,9.5145,0.0000000,-0.0758937,0.9971159
GOTO/-16.2618,-0.0967,9.5265,0.0000000,-0.1369784,0.9905740
GOTO/-15.7976,-0.6817,9.5025,0.0000000,-0.1975448,0.9802939
GOTO/-15.3333,-1.2642,9.4427,0.0000000,-0.2573628,0.9663148
GOTO/-14.8691,-1.8418,9.3471,0.0000000,-0.3162077,0.9486900
GOTO/-14.4048,-2.4125,9.2163,0.0000000,-0.3738593,0.9274854
GOTO/-13.9406,-2.9741,9.0507,0.0000000,-0.4301005,0.9027810
GOTO/-13.4763,-3.5244,8.8509,0.0000000,-0.4847190,0.8746699
GOTO/-13.0120,-4.0615,8.6177,0.0000000,-0.5375099,0.8432574
GOTO/-12.5478,-4.5831,8.3518,0.0000000,-0.5882741,0.8086616
GOTO/-12.0835,-5.0875,8.0545,0.0000000,-0.6368184,0.7710138
GOTO/-11.6193,-5.5727,7.7268,0.0000000,-0.6829582,0.7304575
GOTO/-11.1550,-6.0367,7.3699,0.0000000,-0.7265196,0.6871458
GOTO/-10.6907,-6.4780,6.9851,0.0000000,-0.7673396,0.6412409
GOTO/-10.2265,-6.8949,6.5739,0.0000000,-0.8052644,0.5929158
GOTO/-9.7622,-7.2857,6.1380,0.0000000,-0.8401506,0.5423532
GOTO/-9.4347,-7.5555,5.7557,0.0000000,-0.8525493,0.5226469
GOTO/-9.1556,-7.8175,5.3242,0.0000000,-0.8565566,0.5160531
GOTO/-9.1556,-7.8175,5.3242,0.0000000,-0.8565568,0.5160528
GOTO/-8.8904,-8.1246,4.7665,0.0000000,-0.8564162,0.5162860
GOTO/-8.7008,-8.4243,4.1809,0.0000000,-0.8562789,0.5165138
GOTO/-8.5876,-8.7112,3.5742,0.0000000,-0.8560358,0.5169166
GOTO/-8.5500,-8.9849,2.9490,0.0000000,-0.8554841,0.5178291
GOTO/-8.5500,-9.2233,2.0914,0.0000000,-0.8887101,0.4584696
GOTO/-8.5500,-9.3795,1.2148,0.0000000,-0.9176626,0.3973606
GOTO/-8.5500,-9.4531,0.3275,0.0000000,-0.9423532,0.3346199
GOTO/-8.5500,-9.4437,-0.5629,0.0000000,-0.9627622,0.2703498
GOTO/-8.5500,-9.3511,-1.4486,0.0000000,-0.9788361,0.2046460
GOTO/-8.5500,-9.1763,-2.3217,0.0000000,-0.9904868,0.1376079
GOTO/-8.5500,-8.9207,-3.1746,0.0000000,-0.9975925,0.0693479
GOTO/-8.5500,-8.5854,-4.0000,0.0000000,-1.0000000,0.0000000
GOTO/-8.4728,-7.9692,-4.3952,0.0000000,-1.0000000,0.0000052
GOTO/-8.2616,-7.2909,-4.7229,0.0000000,-1.0000000,-0.0000048
GOTO/-7.9347,-6.6907,-4.9558,0.0000000,-1.0000000,0.0000021
GOTO/-7.5000,-6.4209,-5.0500,0.0000000,-1.0000000,0.0000000
GOTO/-7.0648,-6.6908,-4.9556,0.0000000,-1.0000000,-0.0000294
GOTO/-6.7383,-7.2909,-4.7229,0.0000000,-1.0000000,0.0000091
GOTO/-6.5271,-7.9692,-4.3950,0.0000000,-1.0000000,0.0000031
GOTO/-6.4500,-8.5856,-4.0000,0.0000000,-1.0000000,0.0000000
GOTO/-6.4500,-8.9563,-3.0732,0.0000000,-0.9967269,0.0808421
GOTO/-6.4500,-9.2266,-2.1129,0.0000000,-0.9870756,0.1602550
GOTO/-6.4500,-9.3949,-1.1295,0.0000000,-0.9712721,0.2379718
GOTO/-6.4500,-9.4593,-0.1339,0.0000000,-0.9495028,0.3137586
GOTO/-6.4500,-9.4192,0.8630,0.0000000,-0.9219117,0.3874001
GOTO/-6.4500,-9.2750,1.8502,0.0000000,-0.8885993,0.4586843
GOTO/-6.4500,-9.0283,2.8168,0.0000000,-0.8496254,0.5273866
GOTO/-6.4500,-8.6807,3.7515,0.0000000,-0.8050145,0.5932552
GOTO/-6.5003,-8.5381,4.2092,0.0000000,-0.8059254,0.5920171
GOTO/-6.6528,-8.3375,4.6007,0.0000000,-0.8062438,0.5915835
GOTO/-6.6528,-8.3375,4.6007,0.0000000,-0.8062436,0.5915837
GOTO/-6.7424,-8.2547,4.7378,0.0000000,-0.8016549,0.5977871
GOTO/-6.8541,-8.1850,4.8746,0.0000000,-0.7875207,0.6162882
GOTO/-7.3036,-7.8805,5.3528,0.0000000,-0.7494727,0.6620352
GOTO/-7.7530,-7.5482,5.8120,0.0000000,-0.7087713,0.7054383
GOTO/-8.2025,-7.1892,6.2507,0.0000000,-0.6655611,0.7463434
GOTO/-8.6520,-6.8047,6.6672,0.0000000,-0.6199949,0.7846058
GOTO/-9.1015,-6.3961,7.0601,0.0000000,-0.5722330,0.8200911
GOTO/-9.5510,-5.9649,7.4280,0.0000000,-0.5224439,0.8526737
GOTO/-10.0005,-5.5126,7.7696,0.0000000,-0.4708047,0.8822375
GOTO/-10.4500,-5.0407,8.0837,0.0000000,-0.4174994,0.9086772
GOTO/-10.8995,-4.5510,8.3692,0.0000000,-0.3627166,0.9318995
GOTO/-11.3490,-4.0452,8.6250,0.0000000,-0.3066496,0.9518225
GOTO/-11.7985,-3.5250,8.8504,0.0000000,-0.2494975,0.9683754
GOTO/-12.2479,-2.9924,9.0444,0.0000000,-0.1914629,0.9814999
GOTO/-12.6974,-2.4492,9.2063,0.0000000,-0.1327498,0.9911496
GOTO/-13.1469,-1.8973,9.3356,0.0000000,-0.0735651,0.9972904
GOTO/-13.5964,-1.3387,9.4320,0.0000000,-0.0141190,0.9999003
GOTO/-14.0459,-0.7754,9.4950,0.0000000,0.0453770,0.9989699
GOTO/-14.4954,-0.2093,9.5242,0.0000000,0.1047124,0.9945025
GOTO/-14.9449,0.3575,9.5198,0.0000000,0.1636771,0.9865140
GOTO/-15.3944,0.9231,9.4817,0.0000000,0.2220614,0.9750327
GOTO/-15.8439,1.4854,9.4101,0.0000000,0.2796578,0.9600997
GOTO/-16.2934,2.0424,9.3050,0.0000000,0.3362636,0.9417679
GOTO/-16.7429,2.5922,9.1670,0.0000000,0.3916796,0.9201017
GOTO/-17.1924,3.1329,8.9967,0.0000000,0.4457094,0.8951777
GOTO/-17.6418,3.6624,8.7945,0.0000000,0.4981612,0.8670844
GOTO/-18.0913,4.1790,8.5610,0.0000000,0.5488499,0.8359209
GOTO/-18.5408,4.6807,8.2973,0.0000000,0.5975962,0.8017972
GOTO/-18.9903,5.1660,8.0042,0.0000000,0.6442264,0.7648349
GOTO/-19.4398,5.6329,7.6829,0.0000000,0.6885745,0.7251657
GOTO/-19.8893,6.0798,7.3342,0.0000000,0.7304841,0.6829298
GOTO/-20.3388,6.5052,6.9596,0.0000000,0.7698079,0.6382756
GOTO/-20.7883,6.9077,6.5604,0.0000000,0.8064067,0.5913613
GOTO/-21.2378,7.2857,6.1380,0.0000000,0.8401506,0.5423532
GOTO/-21.5653,7.5555,5.7557,0.0000000,0.8525493,0.5226469
GOTO/-21.8444,7.8175,5.3242,0.0000000,0.8565566,0.5160531
GOTO/-21.8444,7.8175,5.3242,0.0000000,0.8565568,0.5160528
GOTO/-22.1096,8.1246,4.7665,0.0000000,0.8564162,0.5162860
GOTO/-22.2992,8.4243,4.1809,0.0000000,0.8562789,0.5165138
GOTO/-22.4124,8.7112,3.5742,0.0000000,0.8560358,0.5169166
GOTO/-22.4500,8.9839,2.9483,0.0000000,0.8554841,0.5178291
PAINT/COLOR,37
CIRCLE/-23.6482,8.9494,3.0053,0.0000000,-0.8554841,-0.5178291,1.2000,0.0600,0.5000,4.0000,0.0000
GOTO/-23.7147,9.5699,1.9803
GOTO/-23.7147,17.4612,6.7569
PAINT/COLOR,211
RAPID
GOTO/-23.7147,20.5300,8.6145
PAINT/SPEED,10
PAINT/TOOL,NOMORE
END-OF-PATH
刀轨列表有 169 行。
GMT+8, 2025-1-10 14:03
