用户名  找回密码
查看: 2745|回复: 5
[求助] 锁定程序
发表于 2019-10-10 09:41:13 | 显示全部楼层 |阅读模式
有谁知道锁定程序,刀在在刀具列表中怎么做到不输出。
51
 楼主| 发表于 2019-10-11 11:39:46 | 显示全部楼层
发表于 2019-10-14 15:26:27 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
51
 楼主| 发表于 2019-10-14 16:42:34 | 显示全部楼层
ZhuaiGG 发表于 2019-10-14 15:26
锁定后跳过不处理这个操作,那也可以用同样的条件,跳过刀具信息的输出
没跳过,我跳不过{:}{:}
禁止发言
发表于 2019-10-18 08:31:38 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
51
 楼主| 发表于 2019-10-18 09:16:52 | 显示全部楼层
zcx461 发表于 2019-10-18 08:31
后处理可以加个判断,跳过锁定程序
我不懂TCL文件怎么写啊我的刀具列标#PB_CMD_endofnc
set outputthd 1
global mom_tool_name
global mom_tool_diameter cccc
global mom_tool_corner1_radius
global mom_tool_corner1_radiusglobal
global mom_tool_flute_length
global mom_tool_corner1_radius mom_tool_lower_corner_radius
global mom_tool_type
global mom_tool_point_angle
global mom_tool_nose_radius
global mom_sys_tool_stack
set mom_tool_name [format "%-10s" $mom_tool_name]
set tdi [ format  "%-6.2f" $mom_tool_diameter]
if {$mom_tool_type == "Milling Tool-T Cutter"} {
  set tr [format  "%-5.2f" $mom_tool_lower_corner_radius]
} else {
set tr [format  "%-5.2f" $mom_tool_corner1_radius]
#set tr [ format  "%-5.2f" $tr]
#set tr [format  "%-5.2f" $mom_tool_corner1_radius]
#MOM_output_literal "(刀具名及大小:$mom_tool_name,D$tdi,R$tr)"
global mom_tool_adjust_register mom_tool_cutcom_register
global mom_cutcom_adjust_register
global mom_tool_adj_reg_defined
global mom_tool_number
if [info exists mom_tool_number] {
    set tt $mom_tool_number
} else {
    set tt 0
if {$mom_tool_adj_reg_defined == 1} {
    set th $mom_tool_adjust_register
} else {
    set th 0
if [info exists mom_tool_cutcom_register] {
if { $cccc==1  } {
    set td $mom_tool_cutcom_register
} else {
    set td 0
} else {
    set td 0
set tt [format "%-3s" $tt]
set th [format "%-5.2f" $th]
set td [format "%-5.2f" $td]
if {$outputthd == 1 } {
   # MOM_output_literal "(刀具号各补偿号.:T$tt,H$th,D$td)"
} else {
   # MOM_output_literal "(刀具号各补偿号:T00,H00,D$td)"
global mom_stock_part side
global mom_stock_floor
global mom_stock use floor same as side
global mom_operation_type
global mom_motion_type
set xystock 0
set zstock 0
if [info exists mom_stock_floor] {
    set xystock [format "%.2f" $mom_stock_part side]
    set zstock [format "%.2f" $mom_stock_floor]
if {$mom_operation_type == "point to point"} {
    set xystock 0
    set zstock 0
#MOM_output_literal "(XY=[format "%.2f" $xystock]MM,Z=[format "%.2f" $zstock]MM)"
#output tool info
global ptp_file_name
global tool_lists_file_name
global ino
global mom_group_name mom_output_file_suffix mom_output_file_basename
global mom_sys_max_travel
global mom_sys_min_travel
global mom_machine_time
global mom_toolpath_lock_option mom_operation_name
#MOM_output_literal  "操作 $mom_operation_name"
if {$mom_toolpath_lock_option == "Yes"} {
MOM_skip_handler_to_event "MOM_tfile"
set tool_lists_file_name ${ptp_file_name}_toollists
if {![info exists ino]} {
    set ino 1
    if {[file exists $tool_lists_file_name]} {
    MOM_remove_file $tool_lists_file_name
set tfile [open $tool_lists_file_name a]
    puts $tfile "(T$tt $mom_tool_name D$tdi R$tr  z [format "%.2f" $mom_sys_min_travel(2)])"
set ino [expr $ino+1]
close $tfile
set tmp_file_name "${ptp_file_name}_"
if {[file exists $tmp_file_name]} {
MOM_remove_file $tmp_file_name
MOM_close_output_file $ptp_file_name
file rename $ptp_file_name $tmp_file_name
set ifile [open $tmp_file_name r]
set ofile [open $ptp_file_name w]
set ttfile [open $tool_lists_file_name a]
#puts $ttfile "          (zmax=[format "%.2f" $mom_sys_max_travel(2)] zmin=[format "%.2f" $mom_sys_min_travel(2)])"
#puts $ttfile "(time=[ format  "%.2f" $mom_machine_time]MIN)"
close $ttfile
set ttfile [open $tool_lists_file_name r]
global mom_output_file_basename
global mom_part_name
global mom_date
puts $ofile "%"
#puts $ofile "(Graph file path:$mom_part_name)"
set datee [clock format [clock seconds] -format "%Y.%m.%d %H:%M week%w"]
puts $ofile "($datee)"
set buf ""
while { [gets $ttfile buf] > 0 } {
puts $ofile $buf
set buf ""
while { [gets $ifile buf] > 0 } {
puts $ofile $buf
close $ifile
close $ofile
close $ttfile
MOM_open_output_file $ptp_file_name
GMT+8, 2025-3-9 19:07
