楼主: qq1562417262
[分享] 【优品】UpinV8.10,新增对最新版NX1876的支持。
发表于 2019-9-27 12:39:18 | 显示全部楼层
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
发表于 2019-9-29 10:25:35 | 显示全部楼层
656666666666666
发表于 2019-9-29 12:19:17 | 显示全部楼层
兄弟UG12.0可以用吗
发表于 2019-9-29 12:19:55 | 显示全部楼层
UG12.0可以用吗
 楼主| 发表于 2019-9-29 23:20:00 | 显示全部楼层
小姨娘 发表于 2019-9-29 12:19
兄弟UG12.0可以用吗
1872都支持何况12.0
发表于 2019-10-1 23:46:14 | 显示全部楼层
卡了健康了健康离开家离开家
发表于 2019-10-12 09:56:47 | 显示全部楼层
UG12不能使用。。。。。请问是什么问题?
AppBase: D:\UP_Software\startup\
Loaded assembly: UPinStartup, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null from D:\UP_Software\startup\UPinStartup.dll
Resolve failed: NXOpenUI, Version=9.0.0.19, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpenUI, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null from D:\Siemens\NX12\nxbin\managed\NXOpenUI.dll
Loaded: : NXOpenUI, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpen.Utilities, Version=12.0.0.0, Culture=neutral, PublicKeyToken=null from D:\Siemens\NX12\nxbin\managed\NXOpen.Utilities.dll
Resolve failed: NXOpen, Version=9.0.0.19, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpen, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null from D:\Siemens\NX12\nxbin\managed\NXOpen.dll
Loaded: : NXOpen, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null
Resolve failed: NXOpen.UF, Version=9.0.0.19, Culture=neutral, PublicKeyToken=null
Loaded assembly: NXOpen.UF, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null from D:\Siemens\NX12\nxbin\managed\NXOpen.UF.dll
Loaded: : NXOpen.UF, Version=12.0.0.27, Culture=neutral, PublicKeyToken=null
Resolve failed: NXOpen.Utilities, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
Loaded: : NXOpen.Utilities, Version=12.0.0.0, Culture=neutral, PublicKeyToken=null
Verifying D:\UP_Software\startup\UPinStartup.dll for NXOpen signature.
NXOpen.Utilities.MissingResourceException: NX Resource bundle is empty
   在 NXOpen.Utilities.ResourceUtilities.getEmbeddedDataLen()
   在 NXOpen.Utilities.ResourceUtilities.computeHash()
   在 NXOpen.Utilities.BaseSession.verifyAssembly(String filename, Boolean& alliance_mode, SignatureType signTypeNeeded)
Validation failed
Caught exception while running: Startup
NXOpen.Utilities.NeedDOTNETAuthorLicenseException: Invalid NX signature found
   在 NXOpen.Utilities.BaseSession.InitLicense()
   在 NXOpen.UI.GetUI()
   在 Program.uIWR9kqMJCRibrtmtO()
   在 Program.Startup()
*** EXCEPTION: Error code  3600044 in line 2352 of o:\ugnx120\ip27\src\syss\no\ind\lmldr.c at Thu Sep 12 13:55:08 2019
+++ Invalid NX signature found
发表于 2019-10-17 17:37:13 | 显示全部楼层
前面一家公司用的就是优品   可惜拷不出来
发表于 2019-10-19 20:37:22 | 显示全部楼层
6666666666666666666
发表于 2019-10-24 14:51:52 | 显示全部楼层
666666
GMT+8, 2025-4-12 06:54
