查看: 2738|回复: 4
[求助] 求大神!4轴改A轴转向后报错
发表于 2019-7-15 08:11:03 | 显示全部楼层 |阅读模式
只改了一个A轴转向,反转改为法相,保存时报错如下
list element in quotes followed by ""\$mom_kin_4th_axis_" instead of space
    while executing
"foreach var $Page::($page_obj,axis_4th_param) {
if { ![string compare "4-Axis" $machData(1)] &&  ![string compare "\$mom_kin_4th_axis_leader" $var] } ..."
    (procedure "UI_PB_mach_ValidateEmptyEntry" line 25)
    invoked from within
"UI_PB_mach_ValidateEmptyEntry $page_obj"
    (procedure "UI_PB_ValidatePrevBookData" line 16)
    invoked from within
"UI_PB_ValidatePrevBookData book_obj"
    (procedure "UI_PB_ProgTpthTab" line 3)
    invoked from within
"UI_PB_ProgTpthTab .widget.main.nb image264 1170"
    ("eval" body line 1)
    invoked from within
"eval $cb_cmd $book_id $img_id $book"
    (procedure "__RaiseCmd" line 3)
    invoked from within
"__RaiseCmd UI_PB_ProgTpthTab .widget.main.nb image264 1170 pro"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 $data($child,raisecmd)"
    (procedure "tixVStack:raise" line 20)
    invoked from within
"tixVStack:raise .widget.main.nb pro"
    invoked from within
"tixChainMethod $w raise $child"
    (procedure "tixNoteBook:raise" line 4)
    invoked from within
"tixNoteBook:raise .widget.main.nb pro"
    invoked from within
"tixCallMethod $w raise $name"
    (procedure "tixNoteBook:MouseUp" line 15)
    invoked from within
"tixNoteBook:MouseUp .widget.main.nb 149 18"
    (command bound to event)
fanuc_4a.zip
53.74 KB, 下载次数: 32, 下载积分: G币 -1
发表于 2019-7-15 11:43:18 | 显示全部楼层
我这可以改
发表于 2019-7-15 11:44:46 | 显示全部楼层
法向
四轴法向fanuc_4a.zip
58.56 KB, 下载次数: 15, 下载积分: G币 -1
 楼主| 发表于 2019-7-15 12:53:32 | 显示全部楼层
谢谢!可以了
点评
怎么改的 学习一下  发表于 2020-3-10 11:59
GMT+8, 2025-3-10 09:01
