查看: 2163|回复: 5
[求助] 西门子帮助文件中的例子,居然运行不了。真真奇怪了
发表于 2019-7-6 09:56:28 | 显示全部楼层 |阅读模式
求大神指导!求大神指导!
#include <string.h>#include <stdio.h>#include <uf_defs.h>#include <uf.h>#include <uf_assem.h>#include <uf_attr.h>#include <uf_curve.h>#include <uf_part.h>#include <uf_route.h>#include <uf_dirpath.h>#define UF_CALL(X)(report_error( __FILE__, __LINE__, #X, (X)))static int report_error( char *file, int line, char *call, int irc ){    if(irc)    {        char err[133],             msg[133];        sprintf( msg, "*** ERROR code %d at line %d in %s:\n+++",            irc, line, file );        UF_get_fail_message( irc, err );        UF_print_syslog( msg, FALSE );        UF_print_syslog( err, FALSE );        UF_print_syslog( "\n", FALSE );        UF_print_syslog( call, FALSE );        UF_print_syslog( ";\n", FALSE );        if( !UF_UI_open_listing_window() )        {            UF_UI_write_listing_window( msg );            UF_UI_write_listing_window( err );            UF_UI_write_listing_window( "\n" );            UF_UI_write_listing_window( call );            UF_UI_write_listing_window( ";\n" );        }    }    return( irc );}/*ARGSUSED*/void ufusr(char *param, int *retcod, int parm_len){    double stock_and_part_nps   = 3.0;    char   *stock_material      = "ASTM A312 TP304(W)";    char   *stock_schedule      = "80S";    char   *std_part_material   = "ASTM A403 WP316L(W)";    char   *std_part_rating     = "10S";    char   *app_view_name       = NULL;    char   *app_view_symb       = "UGII_ROUTE_MECH_APP_VIEW";    char   *part_search_symb    = "UGII_ROUTE_MECH_PART_PATH";    char   full_name[MAX_FSPEC_SIZE];    double  pos1[3] = {  0.0, 0.0, 0.0 };    double  pos2[3] = { 10.0, 0.0, 0.0 };    double  pos3[3] = { 10.0, 10.0, 0.0 };    double  pos4[3] = { 10.0, 10.0, 10.0 };    double  pos5[3] = { 10.0, 0.0, 10.0 };    double  origin[3] = { 0.0, 0.0, 0.0 };    double  csys[6] = { 1.0, 0.0,  0.0, 0.0, 1.0, 0.0 };    double  radius = 2.0;    double  ratio = 2.0;    int     n_stock_charx;    int     n_stock_matches;    int     n_std_part_charx;    int     n_std_part_matches;    int     inx;    int     style = UF_ROUTE_STYLE_SIMPLE;    int     num_segs;    int     num_places;    tag_t   point;    tag_t   line;    tag_t   rcps[5];    tag_t   segs[7];    tag_t   stock_data;    tag_t   anchor;    tag_t   cross;    tag_t   corner;    tag_t   work_part;    tag_t   fit_part;    tag_t   inst_id;    tag_t   occ;    tag_t   work_part_comp;    tag_t   work_part_occ;    tag_t   dir_path;    UF_CURVE_line_t  line_s;    UF_ROUTE_charx_t  stock_charx[3];    UF_ROUTE_charx_t  std_part_charx[4];    UF_ROUTE_part_lib_part_p_t stock_matches;    UF_ROUTE_part_lib_part_p_t std_part_matches;    UF_ROUTE_application_view_p_t old_app_view;    UF_ROUTE_application_view_p_t app_view;    UF_PART_load_status_t   error_code ;    UF_ROUTE_place_solution_p_t *places;    UF_CALL( UF_initialize() );    /* Load and set the application view *** Routing -> Base */    old_app_view = UF_ROUTE_ask_current_app_view( );    UF_CALL( UF_translate_variable( app_view_symb, &app_view_name ) );    UF_CALL( UF_ROUTE_load_app_view( app_view_name, &app_view ) );    UF_CALL( UF_ROUTE_set_current_app_view( app_view ) );    /* Set the search path for locating Routing (Base) parts / stock */    UF_CALL( UF_DIRPATH_create_from_env ( part_search_symb, &dir_path ) );    UF_CALL( UF_ROUTE_set_part_search_path ( dir_path ) );    /* Create the RCPs at absolute positions */    UF_CALL( UF_ROUTE_create_rcp_position( pos1, &rcps[0] ) );    UF_CALL( UF_ROUTE_create_rcp_position( pos2, &rcps[1] ) );    /* Create RCPs at existing point */    UF_CALL( UF_CURVE_create_point( pos3, &point ) );    UF_CALL( UF_ROUTE_create_rcp_point( point, &rcps[2] ) );    /* Create the Segments through these RCPs */    UF_CALL( UF_ROUTE_create_seg_thru_rcps( rcps[0], rcps[1], &segs[0] ) );    UF_CALL( UF_ROUTE_create_seg_thru_rcps( rcps[1], rcps[2], &segs[1] ) );    /* Create a curve and use this object to create a segment */    for( inx = 0 ; inx < 3 ; inx++ )    {        line_s.start_point[inx] = pos4[inx];        line_s.end_point[inx]   = pos5[inx];    }    UF_CALL( UF_CURVE_create_line( &line_s, &line ) );    /* Create the Segments through RCPs that follows a curve       In this case the RCPs should be created along the curve parameter */    UF_CALL( UF_ROUTE_create_rcp_curve_parm( line, 0, &rcps[3] ) );/* Curve start parm=0 */    UF_CALL( UF_ROUTE_create_rcp_curve_parm( line, 1, &rcps[4] ) );/* Curve end parm=1 */    UF_CALL( UF_ROUTE_create_seg_thru_rcps( rcps[2], rcps[3], &segs[2] ) ); /* Connecting        Segment */    UF_CALL( UF_ROUTE_create_seg_on_curve( line, rcps[3], rcps[4], &segs[3] ) );    /* Set up the characteristics for the stock we wish to assign */    stock_charx[0].type = UF_EPLIB_CHARX_TYPE_REAL;    strcpy (stock_charx[0].title, "NPS");    stock_charx[0].value.r_value = stock_and_part_nps;    stock_charx[1].type = UF_EPLIB_CHARX_TYPE_STR;    strcpy (stock_charx[1].title, "MATERIAL");    stock_charx[1].value.s_value = stock_material;    stock_charx[2].type = UF_EPLIB_CHARX_TYPE_STR;    strcpy (stock_charx[2].title, "SCHEDULE");    stock_charx[2].value.s_value = stock_schedule;    n_stock_charx = sizeof( stock_charx ) / sizeof( stock_charx[0] );    /* Find the stock we want in the Routing Part Library */    UF_CALL( UF_ROUTE_match_charx_in_plib( "STOCK",                                           n_stock_charx,                                           stock_charx,                                           &n_stock_matches,                                           &stock_matches ) );    /* Locate (or load) the stock data which matches our criteria */    UF_CALL( UF_ROUTE_load_stock_by_charx( &stock_matches[0],                                           "",                                           style,                                           &stock_data,                                           &anchor,                                           &cross ) );    UF_CALL( UF_ROUTE_free_match_results( n_stock_matches,                                          stock_matches ) );    /* Create a bend corner at one of the RCP junctions */    UF_CALL( UF_ROUTE_create_bend_by_radius( rcps[1], radius,                                             &corner, &segs[4] ) );    /* Assigns the stock data to segments */    num_segs = 5;    UF_CALL( UF_ROUTE_assign_stock( stock_data, anchor,                                    cross, num_segs, segs ) );    /* Create a bend corner by the ratio of stock dia to the bend radius       The stock gets automatically updated at the bend */    UF_CALL( UF_ROUTE_create_bend_by_ratio( rcps[2], ratio,                                            &corner, &segs[5] ) );    /* Set up the characteristics for the Standard part we wish to place */    std_part_charx[0].type = UF_EPLIB_CHARX_TYPE_REAL;    strcpy (std_part_charx[0].title, "NPS");    std_part_charx[0].value.r_value = stock_and_part_nps;    std_part_charx[1].type = UF_EPLIB_CHARX_TYPE_REAL;    strcpy (std_part_charx[1].title, "ELBOW_ANG");    std_part_charx[1].value.r_value = 90.0;    std_part_charx[2].type = UF_EPLIB_CHARX_TYPE_STR;    strcpy (std_part_charx[2].title, "FITTING_MATERIAL");    std_part_charx[2].value.s_value = std_part_material;    std_part_charx[3].type = UF_EPLIB_CHARX_TYPE_STR;    strcpy (std_part_charx[3].title, "RATING");    std_part_charx[3].value.s_value = std_part_rating;    n_std_part_charx = sizeof( std_part_charx ) / sizeof( std_part_charx[0] );    UF_CALL( UF_ROUTE_match_charx_in_plib( "ELBOWS", n_std_part_charx,                                  std_part_charx, &n_std_part_matches,                                  &std_part_matches ) );    UF_CALL( UF_ROUTE_load_part_by_charx( std_part_matches[0].num_charx,                                 std_part_matches[0].charx, &fit_part ) );    /* Add the elbow as a component of the work part */    UF_CALL( UF_PART_ask_part_name( fit_part, full_name ) );    work_part = UF_ASSEM_ask_work_part( );    UF_CALL( UF_ASSEM_add_part_to_assembly( work_part, full_name,                                            NULL, NULL, origin,                                            csys, -1, &inst_id,                                            &error_code ) );    /*        For the following Routing operations of setting the characteristics        of the fitting part and for placing it within the Routing, we        use the part occurrence of the fitting in the part occurrence tree        that is "rooted" at the work part. This is because the Routing        characteristics and placement functions expect this particular        part occurrence.    */    work_part_comp = UF_ASSEM_ask_parent_of_instance( inst_id );    work_part_occ = UF_ASSEM_ask_root_part_occ( work_part_comp );    occ = UF_ASSEM_ask_part_occ_of_inst( work_part_occ, inst_id ) ;    /*        We now have the part occurrence of the fitting in the work part's        part occurrence tree. So we can attach the Routing characteristics        to this part occurrence and place this occurrence within the        Routing.    */    UF_CALL( UF_ROUTE_set_characteristics( occ, std_part_matches[0].num_charx,                                           std_part_matches[0].charx ) );    /* Place the elbow at the fourth RCP */    num_places = 0; places = NULL;    UF_CALL( UF_ROUTE_solve_places( rcps[3], occ,                                    &num_places, &places ) );    UF_CALL( UF_ROUTE_ask_places_transform( places[0], origin, csys ) );    UF_CALL( UF_ASSEM_reposition_instance( inst_id, origin, csys ) );    UF_CALL( UF_ROUTE_free_places( num_places, places ) );    UF_CALL( UF_ROUTE_set_part_in_stock( occ ) );    UF_CALL( UF_ROUTE_unload_app_view( app_view ) );    UF_CALL( UF_ROUTE_set_current_app_view( old_app_view ) );    UF_terminate();    return;}
发表于 2019-7-6 11:32:58 | 显示全部楼层
管线布置模块的模块没怎么了解过,可能需要布置一下环境吧。。
 楼主| 发表于 2019-7-7 22:30:21 | 显示全部楼层
是的,是管线布置模块,和您说的一样。创建管路需要选择管路的型材,这个需要在NX重用库中选择管路的截面大小。一起研究研究?
 楼主| 发表于 2019-7-7 22:31:51 | 显示全部楼层
 楼主| 发表于 2019-7-7 22:32:24 | 显示全部楼层
发表于 2024-3-5 22:41:27 | 显示全部楼层
GMT+8, 2025-2-23 13:05
