查看: 1885|回复: 0
[求助] 请大神帮我翻译一下下面的,TCL语言的意思
发表于 2019-4-18 16:17:23 | 显示全部楼层 |阅读模式
#PB_CMD_TOOL_INFO
set outputthd 1
global toollist  mom_tool_cutcom_register mom_cutcom_adjust_register mom_tool_name mom_tool_diameter mom_tool_corner1_radius mom_tool_adjust_register mom_tool_adj_reg_defined mom_tool_number
set tdi [ format  "%.2f" $mom_tool_diameter]
set tr [ format  "%.2f" $mom_tool_corner1_radius]
if [info exists mom_tool_number] {
    set tt $mom_tool_number
} else {
    set tt 0
if [info exists mom_tool_adj_reg_defined] {
    set th $mom_tool_adjust_register
} else {
    set th 0
    set td $mom_tool_cutcom_register
} else {
    set td 0
set tt [format "%02.0f" $tt]
set th [format "%02.0f" $th]
set td [format "%02.0f" $td]
global mom_stock_part side
global mom_stock_floor
global mom_stock use floor same as side
global mom_operation_type
global mom_motion_type
set xystock 0
set zstock 0
#output tool info
global ptp_file_name
global tool_lists_file_name
global ino
global mom_group_name mom_output_file_suffix mom_output_file_basename
global mom_sys_max_travel
global mom_sys_min_travel
global mom_machine_time
set tool_lists_file_name ${ptp_file_name}_toollists
if {![info exists ino]} {
    set ino 1
    if {[file exists $tool_lists_file_name]} {
    MOM_remove_file $tool_lists_file_name
set tfile [open $tool_lists_file_name a]
if {$ino > 1} {
    puts $tfile "(ZMAX=[format "%.2f" $mom_sys_max_travel(2)] ZMIN=[format "%.2f" $mom_sys_min_travel(2)])"
set mom_sys_max_travel(2) -9999.999
set mom_sys_min_travel(2)  9999.999
#puts $tfile "(NC ne:$mom_group_name.$mom_output_file_suffix)"
if {$outputthd == 1 }  {
    puts $tfile "(T$tt:$mom_tool_name D:$tdi R:$tr H:$th D:$td)"
set ino [expr $ino+1]
close $tfile
}  Z 的最大深度和最小深度代码是排在  刀具表的前面,为什么程序单上的Z 的最大深度和最小深度在每把刀具的后面
Z的最大深度可不可以放在,每把刀具一行的后面,代码要怎么写  网上有人发的但第一把刀和最后一把刀没有刀具单
GMT+8, 2025-3-10 20:18
