楼主: topckey
[综合分享] NX1847全系列最简便的控制内存爆仓的方法100%有效
 火... [复制链接]
发表于 2019-5-28 19:25:54 | 显示全部楼层
MP9 8412253 mom_nex_motion_event incorrect for the first circular_move motion MP9 8413555 This object contains geometry not in the current reference set MP9 8413640 This object contains geometry not in the current reference set MP9 8415488 XML output for knuckle bending parameter: wrong angle (pos./neg. value). MP9 8830778 On Machine Probing- incorrect position and orientation MP9 9045957 [CAD]Open the drawing with Structure Only, it becomes Modified. MP9 9212678 Mold Wizard generated symbolic thread does not appear in drafting views. MP9 9230234 [CAD]Open the drawing with Structure Only, it becomes Modified, Read Only. MP9 9251076 Symbolic thread ending on divided face not shown always in drawing views MP9 9285830 Wrong Output Vectors for Circular Motion when using Variable Turning Tool Holder MP9 9336814 Error occurs and cannot display Harness Libraries in Japanese MP9 9339154 Component preview window performs fit all after every selection MP9 9340620 Sheet Metal Flat Pattern - Toolmarker Callouts Tool Id wrongly placed MP9 9342650 Component preview window performs fit all after every selection MP9 9344575 Display of threads in Drafting MP9 9346283 Assembly constraints not updating after interpart expression change MP9 9361225 When I transform and do a rotation the (Point Set) angle does not change MP9 9366670 Shop Doc output wrong progr group name in header & error MP9 9369996 Memory Access Violation, PMI Suspected. MP9 9376624 Check PMI GD&T Syntactic Validity Check in NX 12.0.2 MP9 9384376 slow loading of parts containing expressions with excel lookup functions MP9 9385637 Null pointer opening piping assemblies MP9 9393749 MOM generates incorrect value for mom_nxt_motion_event MP9 9394899 Import part with CAM objects problem results in error. MP9 9395216 error when unv result import in NX 12.0.2 MP9 9397113 Restructure Manufacturing -Make Target-Move To Target-missing parts in ModelView MP9 9399266 Error PMI Suspected, related to PR9369996 MP9 9401899 Load Option from Folder : Modeler error: non fatal run-time error MP9 9409417 Profiles Sketch: creation performance MP9 9409543 Position Numbering on profiles/brackets incorrect MP9 9415012 4GD DE assembly structures do not load in NX MP9 9417962 BendAngle and Bend include Angle not correct MP9 9419417 Restructure Reordering per Drag N Drop does not work MP9 9420676 Manufacturing Preparation: Selection of ship container unnecessary MP9 9420896 Manufacturing Preparation: Edit does not remove parts after restart MP9 9423366 This object contains geometry not in the current reference set MP9 9426655 Post variable mom_kin_read_ahead_next_motion reports incorrect motion type MP9 9427502 Problem in Object Attribute Management Tool in Mold and Die Wizards MP9 9429983 Tool Assembly Display is incorrect with GMC Operation MP9 9432930 Tracelinks between Detail design parts and Manufacturing parts get lost in TC MP9 9442376 Incomplete EDM_output.xml file since NX 12.0.2, fine with EDM_output.txt MP9 9446795 Wrong XML output for knuckle bending parameter in Ship Structure Manufacturing MP9 9455822 two users can save the same file in Native NX MP9 9467675 Tracelinks get lost between Detail design parts and Manufacturing parts in TC MP9 9341315 Issue in which user was getting different behavior for the view PN status is fixed.
发表于 2019-5-28 20:04:50 | 显示全部楼层
谢谢分享!
发表于 2019-5-28 20:08:27 | 显示全部楼层
看看怎么样
发表于 2019-5-28 20:19:25 | 显示全部楼层
666666666666666666
发表于 2019-5-28 20:41:12 | 显示全部楼层
看看是什么高招
发表于 2019-5-28 20:51:29 | 显示全部楼层
学习学习{}{:}
24
发表于 2019-5-28 20:55:33 | 显示全部楼层
沙发留起来备用
发表于 2019-5-28 21:03:23 | 显示全部楼层
看看,了解下
发表于 2019-5-28 21:11:59 | 显示全部楼层
fxjytgytkitkt
发表于 2019-5-28 21:23:48 | 显示全部楼层
GMT+8, 2025-1-11 14:24
