发表于 2012-3-2 22:51:08
显示全部楼层
查看一下重用库的标准,好像没有轴用弹性挡圈GB 894.1-1986
Screw,GB100-86.prt
Screw,GB101-86.prt
Bolt,GB12-88.prt
Bolt,GB27-88.prt
Bolt,GB28-88.prt
Bolt,GB29.1-88.prt
Bolt,GB29.2-88.prt
Bolt,GB31.1-88.prt
Bolt,GB31.2-88.prt
Bolt,GB31.3-88.prt
Bolt,GB32.1-88.prt
Bolt,GB32.2-88.prt
Bolt,GB32.3-88.prt
Bolt,GB35-88.prt
Nut,GB39-1988.prt
Screw,GB5281-85.prt
Screw,GB5282_C-85.prt
Screw,GB5282_F-85.prt
Screw,GB5283_C-85.prt
Screw,GB5283_F-85.prt
Screw,GB5284_C-85.prt
Screw,GB5284_F-85.prt
Nut,GB56-1988.prt
Bolt,GB5784-86.prt
Bolt,GB5789-86.prt
Bolt,GB5790-86.prt
Nut,GB6181-86.prt
Nut,GB63-1988.prt
Screw,GB65_A-2000.prt
Profile,GB6723_C-1986.prt
Profile,GB6723_L-1986.prt
Profile,GB6723_U-1986.prt
Profile,GB6723_UC-1986.prt
Profile,GB6723_UL-1986.prt
Profile,GB6723_UU-1986.prt
Profile,GB6723_UZ-1986.prt
Profile,GB6723_Z-1986.prt
Profile,GB6727_KQC-1986.prt
Profile,GB6727_KQF-1986.prt
Profile,GB6727_KQJ-1986.prt
Profile,GB707-1988.prt
Screw,GB71-85.prt
Washer,GB7244-87.prt
Screw,GB72-88.prt
Screw,GB73-85.prt
Screw,GB74-85.prt
Screw,GB75-85.prt
Bolt,GB798-85.prt
Bolt,GB799-85.prt
Nut,GB802-1988.prt
Nut,GB804-1988.prt
Nut,GB805-1988.prt
Nut,GB806-1988.prt
Nut,GB807-1988.prt
Nut,GB810-1988.prt
Nut,GB812-88.prt
Screw,GB821-88.prt
Bolt,GB825_A-88.prt
Bolt,GB825_B-88.prt
Screw,GB828-88.prt
Screw,GB829-88.prt
Screw,GB830-88.prt
Screw,GB83-1988.prt
Screw,GB832_A-88.prt
Screw,GB832_B-88.prt
Screw,GB832_C-88.prt
Screw,GB833-88.prt
Screw,GB835-88.prt
Screw,GB837-88.prt
Screw,GB838-88.prt
Screw,GB845_CH-85.prt
Screw,GB845_CZ-85.prt
Screw,GB845_FH-85.prt
Screw,GB845_FZ-85.prt
Screw,GB846_CH-85.prt
Screw,GB846_CZ-85.prt
Screw,GB846_FH-85.prt
Screw,GB846_FZ-85.prt
Screw,GB847_CH-85.prt
Screw,GB847_CZ-85.prt
Screw,GB847_FH-85.prt
Screw,GB847_FZ-85.prt
Screw,GB84-88.prt
Washer,GB849-88.prt
Washer,GB850-88.prt
Washer,GB852-88.prt
Washer,GB853-88.prt
Washer,GB854-88.prt
Washer,GB855-88.prt
Screw,GB85-88.prt
Washer,GB859-87.prt
Washer,GB861.1-87.prt
Washer,GB861.2-87.prt
Washer,GB862.1-87.prt
Washer,GB862.2-87.prt
Screw,GB86-88.prt
Pin,GB877-86.prt
Pin,GB878-86.prt
Pin,GB880-86.prt
Pin,GB882_A-86.prt
Pin,GB882_B-86.prt
Bolt,GB8-88.prt
Nut,GB923_A-88.prt
Nut,GB923_B-88.prt
Washer,GB93-87.prt
Screw,GB946-88.prt
Screw,GB947-88.prt
Screw,GB948-88.prt
Screw,GB949-88.prt
Screw,GB951-86.prt
Profile,GB9787-1988.prt
Profile,GB9788-1988.prt
Screw,GB99-86.prt
Profile,GB-T11263_H-2005.prt
Profile,GB-T11263_T-2005.prt
Pipe,GB-T13793-1992.prt
Bolt,GB-T16674.1-2004.prt
Bolt,GB-T16939-1997.prt
Profile,GB-T17395_C-1998.prt
Profile,GB-T17395_P-1998.prt
Profile,GB-T17395_S-1998.prt
Bearing,GB-T276_160000-1994.prt
Bearing,GB-T276_60000_2LS-1994.prt
Bearing,GB-T276_60000_2RS-1994.prt
Bearing,GB-T276_60000_2RZ-1994.prt
Bearing,GB-T276_60000_2Z-1994.prt
Bearing,GB-T276_60000_LS-1994.prt
Bearing,GB-T276_60000_N-1994.prt
Bearing,GB-T276_60000_RS-1994.prt
Bearing,GB-T276_60000_RZ-1994.prt
Bearing,GB-T276_60000_Z-1994.prt
Bearing,GB-T276_60000_ZN-1994.prt
Bearing,GB-T276_60000-1994.prt
Bearing,GB-T283_N-1994.prt
Bearing,GB-T283_NF-1994.prt
Bearing,GB-T283_NH-1994.prt
Bearing,GB-T283_NJ-1994.prt
Bearing,GB-T283_NU-1994.prt
Bearing,GB-T283_NUP-1994.prt
Bearing,GB-T283_RN-1994.prt
Bearing,GB-T283_RNU-1994.prt
Bearing,GB-T285_NN-1994.prt
Bearing,GB-T285_NNK_W33-1994.prt
Bearing,GB-T285_NNK-1994.prt
Bearing,GB-T285_NNU_W33-1994.prt
Bearing,GB-T285_NNU-1994.prt
Bearing,GB-T285_NNUK_W33-1994.prt
Bearing,GB-T285_NNUK-1994.prt
Bearing,GB-T290_BK_1-1998.prt
Bearing,GB-T290_BK_2-1998.prt
Bearing,GB-T290_F-1998.prt
Bearing,GB-T290_HK_2RS-1998.prt
Bearing,GB-T290_HK_RS-1998.prt
Bearing,GB-T290_HK-1998.prt
Bearing,GB-T290_MF-1998.prt
Bearing,GB-T292_AC_DB-1994.prt
Bearing,GB-T292_AC_DT-1994.prt
Bearing,GB-T292_AC-1994.prt
Bearing,GB-T292_B_AC_DB-1994.prt
Bearing,GB-T292_B_AC_DF-1994.prt
Bearing,GB-T292_B_AC_DT-1994.prt
Bearing,GB-T292_B_AC-1994.prt
Bearing,GB-T292_B_B_DB-1994.prt
Bearing,GB-T292_B_B_DF-1994.prt
Bearing,GB-T292_B_B_DT-1994.prt
Bearing,GB-T292_B_C_DB-1994.prt
Bearing,GB-T292_B_C_DF-1994.prt
Bearing,GB-T292_B_C_DT-1994.prt
Bearing,GB-T292_B_C-1994.prt
Bearing,GB-T292_B_DB-1994.prt
Bearing,GB-T292_B_DF-1994.prt
Bearing,GB-T292_B_DT-1994.prt
Bearing,GB-T292_B-1994.prt
Bearing,GB-T292_C_DB-1994.prt
Bearing,GB-T292_C_DF-1994.prt
Bearing,GB-T292_C_DT-1994.prt
Bearing,GB-T292_C-1994.prt
Bearing,GB-T292_S-1994.prt
Bearing,GB-T301_51000-1995.prt
Bearing,GB-T301_52000-1995.prt
Bearing,GB-T301_53000-1995.prt
Bearing,GB-T301_53000U-1995.prt
Bearing,GB-T301_54000-1995.prt
Bearing,GB-T301_54000U-1995.prt
Profile,GB-T3094_A-2000.prt
Profile,GB-T3094_B-2000.prt
Profile,GB-T3094_C-2000.prt
Profile,GB-T3094_D-2000.prt
Profile,GB-T3094_E-2000.prt
Profile,GB-T3094_F-2000.prt
Bearing,GB-T3882_UB-1995.prt
Bearing,GB-T3882_UC-1995.prt
Bearing,GB-T3882_UE-1995.prt
Bearing,GB-T3882_UEL-1995.prt
Nut,GB-T41-2000.prt
Bearing,GB-T4663_80000-1994.prt
Bearing,GB-T4663_GS81000-1994.prt
Bearing,GB-T4663_K81000-1994.prt
Bearing,GB-T4663_WS81000-1994.prt
Washer,GB-T5287-2002.prt
Bolt,GB-T5780-2000.prt
Bolt,GB-T5781-2000.prt
Bolt,GB-T5782-2000.prt
Bolt,GB-T5783-2000.prt
Bolt,GB-T5785-2000.prt
Bolt,GB-T5786-2000.prt
Nut,GB-T6170_F-2000.prt
Nut,GB-T6170_T-2000.prt
Nut,GB-T6171_F-2000.prt
Nut,GB-T6171_T-2000.prt
Nut,GB-T6172_1-2000.prt
Nut,GB-T6173-2000.prt
Nut,GB-T6174-2000.prt
Nut,GB-T6175_F-2000.prt
Nut,GB-T6175_T-2000.prt
Nut,GB-T6176_F-2000.prt
Nut,GB-T6176_T-2000.prt
Nut,GB-T6179-1986.prt
Nut,GB-T6182-2000.prt
Bearing,GB-T6643_NKXR00_IR-1996.prt
Bearing,GB-T6643_NKXR00-1996.prt
Bearing,GB-T6643_NKXR00Z_IR-1996.prt
Bearing,GB-T6643_NKXR00Z-1996.prt
Screw,GB-T67-2000.prt
Profile,GB-T6728_C-2002.prt
Profile,GB-T6728_R-2002.prt
Profile,GB-T6728_S-2002.prt
Screw,GB-T68-2000.prt
Screw,GB-T69-2000.prt
Screw,GB-T70.1-2000.prt
Profile,GB-T702_R-2004.prt
Profile,GB-T702_SQ-2004.prt
Profile,GB-T705_E-1989.prt
Profile,GB-T705_S-1989.prt
Profile,GB-T706-1988.prt
Screw,GB-T77-2000.prt
Screw,GB-T78-2000.prt
Screw,GB-T79-2000.prt
Screw,GB-T80-2000.prt
Screw,GB-T818_Z-2000.prt
Screw,GB-T819_1_H-2000.prt
Screw,GB-T819_1_Z-2000.prt
Screw,GB-T820_Z-2000.prt
Washer,GB-T848-2002.prt
Nut,GB-T889.1-1986.prt
Washer,GB-T95-2002.prt
Washer,GB-T96_1-2002.prt
Washer,GB-T96_2-2002.prt
Washer,GB-T97_1-2002.prt
Washer,GB-T97_2-2002.prt
Bearing,GB-T285_NN_W33-1994.prt
Bolt,GB37-88.prt
Screw,GB65_B-2000.prt
Nut,GB9459.prt
Pin,GB-T117_A-2000.prt
Pin,GB-T117_B-2000.prt
Pin,GB-T118_A-2000.prt
Pin,GB-T118_B-2000.prt
Pin,GB-T119.1-2000.prt
Pin,GB-T120.1-2000.prt
Pin,GB-T120.2_A-2000.prt
Pin,GB-T120.2_B-2000.prt
Pin,GB-T13829.1-2004.prt
Pin,GB-T13829.2-2004.prt
Pin,GB-T13829.3-2004.prt
Pin,GB-T13829.4-2004.prt
Bearing,GB-T292_AC_DF-1994.prt
Pin,GB-T879.1-2000.prt
Pin,GB-T879.2-2000.prt
Pin,GB-T881-2000.prt
Pin,GB-T91_C-2000.prt
Pin,GB-T91-2000.prt
Screw,GB-T818_H-2000.prt
Screw,GB-T820_H-2000.prt
Bearing,JB3122_NKX00-91.prt
Bearing,JB3122_NKX00Z_IR-91.prt
Bearing,JB3122_NKX00Z-91.prt
Bearing,JB3122_NKXOO_IR-91.prt
Bearing,JB3123_NKIA0000-91.prt
Bearing,JB3123_NKIB0000-91.prt
