查看: 1378|回复: 2
[求助] 请教UF_MODL_create_thru_curves这个函数怎么用?
发表于 2019-3-22 14:08:16 | 显示全部楼层 |阅读模式
int UF_MODL_create_thru_curves
UF_STRING_p_t s_section,
UF_STRING_p_t s_spine,
int * patch,
int * alignment,
double value [ 6 ] ,
int * vdegree,
int * vstatus,
int * body_type,
UF_FEATURE_SIGN boolean,
double tol [ 3 ] ,
tag_t c_face_id [ 2 ] ,
int c_flag [ 2 ] ,
tag_t * body_obj_id
 楼主| 发表于 2019-3-22 14:09:38 | 显示全部楼层
请教大神这两个函数怎么设置?
UF_STRING_p_t  s_section;
UF_STRING_p_t  s_spine;
发表于 2024-3-6 19:00:24 | 显示全部楼层
请教大神这两个函数怎么设置?
GMT+8, 2025-2-19 03:55
