楼主: 老玩童UG
[原创] 宏程序,螺纹,钻孔,UG刀库
 楼主| 发表于 2019-2-19 08:45:51 | 显示全部楼层
O9164(SI ZHOU LUO XUAN CAO CENG XI)
(G964 XUVWH RZQ EBC FT)
(G964 A0X0 U-232V240W218H80 R0Z-20Q2 E4 F0.1)
(A=A QI DIAN G90)
(X=X ZHI CAO G90)
(U=X ZHONG DIAN G91)
(V=DA WAI JING)
(W=XIAO WAI JING)
(H=LUO JU)
(R=KAI SHI QIE SHEN Z)
(Z=CAO SHEN Z)
(Q=MEI DAO QIE SHEN Z)
(E=ZONG SHU)
(B=KAI SHI XIAN SHU)
(C=JIE SHU XIAN SHU)
(F=FEI A ZHOU F)
(T=A ZHOU F=[114.592/#22*#9])
IF[#1EQ#0]THEN#3000=1(A)
IF[#24EQ#0]THEN#3000=1(X)
IF[#21EQ#0]THEN#3000=1(U)
IF[#22EQ#0]THEN#3000=1(V)
IF[#23EQ#0]THEN#3000=1(W)
IF[#11EQ#0]THEN#3000=1(H)
IF[#18EQ#0]THEN#3000=1(R)
#18=AB[#18](-R)
IF[#26EQ#0]THEN#3000=1(Z)
#26=AB[#26](-Z)
IF[#17EQ#0]THEN#3000=1(Q)
IF[#8EQ#0]THEN#3000=1(E)
IF[#2EQ#0]TH#2=1(B)
IF[#3EQ#0]TH#3=#8(C)
IF[#9EQ#0]TH#9=#4109(F)
IF[#20EQ#0]TH#20=[114.592/#22*#9](T)
M8(M)
M#13S#19F#9
#14=#5001(X)
#15=#5002(Y)
#16=#5003(Z)
#500=#0
#501=#0
#502=#0
#503=#0
#504=#0
G65P9302A#18B#26C#17J117
WHILE[#18LT#26]DO2
#18=#18+#117
IF[#18GT#26]TH#18=#26
#501=#18(QIE SHEN)
#124=#18/#26*#21
#118=#18/#26*[#26-[#22-#23]/2]
#101=#18/#26*[#21/[-#11]*360]
WH[#2LE#3]DO1
#503=#2(XIAN SHU)
G0G90X#14Y#15A[[#2-1]*[360/#8]+#1]
G0G90Z-[#18-#117]
G1G90Z-#18F#9
G1G90X#24F#9M8
G1G91X#124Z#118A#101F#20
G0G90Z#16M3
#504=#2(XIAN SHU)
#2=#2+1
M9
M1
END1
M3
#2=1
#502=#18(QIE SHEN)
END2
M99
 楼主| 发表于 2019-2-19 08:47:23 | 显示全部楼层
(A=A QI DIAN G90)
(X=X ZHI CAO G90)
(V=DA WAI JING)
(W=XIAO WAI JING)
(H=LUO JU)
(Z=CAO SHEN Z)
(E=ZONG SHU)
(F=FEI A ZHOU F)
#18=AB[#18](-R)
#26=AB[#26](-Z)
IF[#2EQ#0]TH#2=1(B)
M8(M)
M#13S#19F#9
#14=#5001(X)
#15=#5002(Y)
#16=#5003(Z)
#500=#0
#501=#0
#502=#0
#503=#0
#504=#0
WHILE[#18LT#26]DO2
#18=#18+#117
#501=#18(QIE SHEN)
#124=#18/#26*#21
WH[#2LE#3]DO1
#503=#2(XIAN SHU)
G0G90Z-[#18-#117]
G1G90Z-#18F#9
G1G90X#24F#9M8
G0G90Z#16M3
#504=#2(XIAN SHU)
#2=#2+1
M9
M1
END1
M3
#2=1
#502=#18(QIE SHEN)
END2
M99
发表于 2019-2-19 09:05:37 | 显示全部楼层
赞 就是图没有发原图
 楼主| 发表于 2020-1-27 19:22:12 | 显示全部楼层
没有想学宏程序的吗
发表于 2022-4-11 20:47:51 | 显示全部楼层
楼主发一份吧977750320@qq.com  谢谢
GMT+8, 2025-3-4 08:16
