楼主: haoyuan366
UG后处理程序头带刀具单与换刀前输出序列号N代码
 火... [复制链接]
发表于 2019-3-6 22:15:30 | 显示全部楼层
试试看888
发表于 2019-3-7 17:47:22 | 显示全部楼层
学习学习
发表于 2019-3-7 19:46:09 | 显示全部楼层
可以,牛牛
发表于 2019-3-8 09:50:49 | 显示全部楼层
{:smile:}
发表于 2019-3-8 12:15:27 | 显示全部楼层
让我去燃烧大大的文萨法法师·
发表于 2019-3-8 16:51:52 | 显示全部楼层
#PB_CMD_TOOL_INFO
set outputthd 1
global mom_tool_name
global mom_tool_diameter
global mom_tool_corner1_radius
set tdi [ format  "%.2f" $mom_tool_diameter]
set tr [ format  "%.2f" $mom_tool_corner1_radius]
MOM_output_literal "($mom_tool_name,D$tdi,R$tr)"
global mom_tool_adjust_register
global mom_cutcom_adjust_register
global mom_tool_adj_reg_defined
global mom_tool_number
if [info exists mom_tool_number] {
    set tt $mom_tool_number
} else {
    set tt 0
if {$mom_tool_adj_reg_defined == 1} {
    set th $mom_tool_adjust_register
} else {
    set th 0
if [info exists mom_cutcom_adjust_register] {
    set td $mom_cutcom_adjust_register
} else {
    set td 0
set tt [format "%02.0f" $tt]
set th [format "%02.0f" $th]
set td [format "%02.0f" $td]
if {$outputthd == 1 } {
    #MOM_output_literal "(T$tt,H$th,D$td#)"
} else {
    #MOM_output_literal "(T00,H00,D$td#)"
global mom_stock_part side
global mom_stock_floor
global mom_stock use floor same as side
global mom_operation_type
global mom_motion_type
set xystock 0
set zstock 0
if [info exists mom_stock_floor] {
    set xystock [format "%.2f" $mom_stock_part side]
    set zstock [format "%.2f" $mom_stock_floor]
if {$mom_operation_type == "point to point"} {
    set xystock 0
    set zstock 0
MOM_output_literal "(XY=[format "%.2f" $xystock], Z=[format "%.2f" $zstock])"
#output tool info
global ptp_file_name
global tool_lists_file_name
global ino
global mom_group_name mom_output_file_suffix mom_output_file_basename
global mom_sys_max_travel
global mom_sys_min_travel
global mom_machine_time
set tool_lists_file_name ${ptp_file_name}_toollists
if {![info exists ino]} {
    set ino 1
    if {[file exists $tool_lists_file_name]} {
    MOM_remove_file $tool_lists_file_name
set tfile [open $tool_lists_file_name a]
if {$ino > 1} {
    puts $tfile "(T$tt $mom_tool_name D$tdi R$tr H$th ZMIN=[format "%.2f" $mom_sys_min_travel(2)])"
set mom_sys_max_travel(2) -9999.999
set mom_sys_min_travel(2)  9999.999
set ino [expr $ino+1]
close $tfile
发表于 2019-3-9 06:41:25 | 显示全部楼层
谢谢楼主,辛苦了
发表于 2019-3-11 11:48:57 | 显示全部楼层
我看看
发表于 2019-3-11 13:43:49 | 显示全部楼层
6666666
发表于 2019-3-11 17:21:01 | 显示全部楼层
{:smile:}{:smile:}{:smile:}{:smile:}{:smile:}{:smile:}{:smile:}{:smile:}{:smile:}
GMT+8, 2025-4-30 22:24
