查看: 2008|回复: 2
[求助] 输出T型刀R
发表于 2018-11-13 20:49:19 | 显示全部楼层 |阅读模式
各位大佬,下面这段语言该怎么改,主体是论坛一位朋友的,想在他的基础上输出T型刀的R角,自己试着在前面加了一段,但是还是不行,希望论坛里的大神能助我一臂之力{:biggrin:}
set outputthd 1
global toollist mom_tool_type mom_tool_cutcom_register mom_cutcom_adjust_register mom_tool_name mom_tool_diameter mom_tool_corner1_radius mom_tool_lower_corner_radius mom_tool_adjust_register mom_tool_adj_reg_defined mom_tool_number
set tdi [ format  "%.2f" $mom_tool_diameter]
   if {$mom_tool_type == "Milling Tool-T Cutter"} {
set tr1 [ format "%.2f" $mom_tool_lower_corner_radius]
} else {
set tr [ format  "%.2f" $mom_tool_corner1_radius]
if [info exists mom_tool_number] {
    set tt $mom_tool_number
} else {
    set tt 0
if [info exists mom_tool_adj_reg_defined] {
    set th $mom_tool_adjust_register
} else {
    set th 0
    set td $mom_tool_cutcom_register
} else {
    set td 0
set tt [format "%02.0f" $tt]
set th [format "%02.0f" $th]
set td [format "%02.0f" $td]
if {$outputthd == 1 } {
    MOM_output_literal "(T$ttmom_tool_name D=$tdi R=$tr H$th D$td)"
} else {
    MOM_output_literal "(T00mom_tool_name D=$tdi R=$tr H00 D$td)"
 楼主| 发表于 2018-11-13 22:08:22 来自手机 | 显示全部楼层
各位大师些,棒棒忙啦
发表于 2018-11-14 21:03:09 | 显示全部楼层
global mom_tool_type mom_tool_cutcom_register mom_cutcom_adjust_register mom_tool_name mom_tool_diameter mom_tool_corner1_radius
global mom_tool_lower_corner_radius mom_tool_adjust_register mom_tool_adj_reg_defined mom_tool_number
set tr [ format "%.2f" $mom_tool_lower_corner_radius]
} else {
} else {
    set tt 0
} else {
    set th 0
if [info exists mom_tool_cutcom_register] {
} else {
    set td 0
    MOM_output_literal "(T$tt:$mom_tool_name D=$tdi R=$tr H$th D$td)"
GMT+8, 2025-3-10 23:30
