查看: 21905|回复: 6
[已回复] UG8.0星空外挂提示没有注册该按钮上的操作
发表于 2018-10-27 22:22:06 | 显示全部楼层 |阅读模式
发表于 2018-10-29 09:26:20 | 显示全部楼层
星空外挂报警“没有注册该按钮是的操作”的解决方法
http://www.ugsnx.com/thread-189432-1-1.html
(出处: UG爱好者)
 楼主| 发表于 2018-10-29 19:07:56 | 显示全部楼层
(出处 ...
没有用,我手动,自动都试了几遍了,D:\QuickCAM\NX10.0也改了,还是不行
我的是UG8.0的。
不过还是谢谢你
 楼主| 发表于 2018-10-29 19:09:57 | 显示全部楼层
估计是8.0的不得行哦
发表于 2018-12-2 09:28:40 | 显示全部楼层
我之前一直好好的,最新也老出现这个问题,8.0
发表于 2019-8-29 20:24:05 | 显示全部楼层
我的日志有这样的提示。。。。。请问是什么问题?
Validation failed for D:\QuickCAM\NX10.0\startup\v7.4_nx10_quick_cam.dll and no CPP author license exists
Unloading D:\QuickCAM\NX10.0\startup\v7.4_nx10_quick_cam.dll
+++ Failed to load D:\QuickCAM\NX10.0\startup\v7.4_nx10_quick_cam.dll - Native license authentication failed and no CPP license is available
MB_LIBRARY_LOAD_FAILED Load failed for library: D:\QuickCAM\NX10.0\startup\v7.4_nx10_quick_cam.dll
Validation failed for D:\QuickCAM\NX10.0\startup\v7.4_plot_nx10.dll and no CPP author license exists
Unloading D:\QuickCAM\NX10.0\startup\v7.4_plot_nx10.dll
+++ Failed to load D:\QuickCAM\NX10.0\startup\v7.4_plot_nx10.dll - Native license authentication failed and no CPP license is available
MB_LIBRARY_LOAD_FAILED Load failed for library: D:\QuickCAM\NX10.0\startup\v7.4_plot_nx10.dll
Validation failed for D:\QuickCAM\NX10.0\startup\v7.4_steel_cam_nx10.dll and no CPP author license exists
Unloading D:\QuickCAM\NX10.0\startup\v7.4_steel_cam_nx10.dll
+++ Failed to load D:\QuickCAM\NX10.0\startup\v7.4_steel_cam_nx10.dll - Native license authentication failed and no CPP license is available
发表于 2022-2-22 21:47:59 | 显示全部楼层
我的是UG8.0的。
不过还是谢 ...
我也是啊,你解决了吗?以前安装别的电脑没问题啊
GMT+8, 2025-4-18 17:07
