查看: 1521|回复: 3
[求助] unsupported Java version of Java Runtime
发表于 2018-10-15 11:45:41 | 显示全部楼层 |阅读模式
unsupported Java
version of Java Runtime ('RE) being does not meet minimum system requirements for this TO Correct this, Set to point to a Of the JRE that at version 1.8.0_45 0' later.
TO See versions Of the IRE meet the System requirements. 100k at the notes for this software.
发表于 2018-10-15 13:30:10 | 显示全部楼层
哪个版本的UG
 楼主| 发表于 2018-10-15 15:08:02 | 显示全部楼层
UG12.0,现在问题解决了
发表于 2018-10-15 16:42:56 | 显示全部楼层
ybz825676250 发表于 2018-10-15 15:08
UG12.0,现在问题解决了
可以分享下你解决的方法哦
GMT+8, 2025-3-14 19:33
