查看: 2310|回复: 1
[求助] Java一定要降级吗
发表于 2018-6-9 01:07:24 | 显示全部楼层 |阅读模式
the java version is 10.0.1 and nx reuiress at least bersion 1.8.0_45.
Java version is 10.0.1
NX is configured to use an unsupported version of Java from C:\Program Files\Java\jre-10.0.1.
The Java version is 10.0.1 and NX requires at least version 1.8.0_45.
Either upgrade this version of Java, or change the NX environment variable UGII_JAVA_HOME to point to a supported version of Java.
发表于 2018-6-9 10:24:01 | 显示全部楼层
要求你换版本了 就一定要换了
GMT+8, 2026-6-13 23:16
