查看: 1280|回复: 0
[分享] 怎麼獲得點集內點的坐標
爱好者VIP1
发表于 2018-6-2 14:23:40 | 显示全部楼层 |阅读模式
您可以遍歷集合來處理每個特徵或查找特定的特徵。
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        For Each myFeature As Features.Feature In workPart.Features
            If TypeOf (myFeature) Is Features.PointSet Then
                lw.WriteLine(".GetFeatureName: " & myFeature.GetFeatureName)
                lw.WriteLine(".Name: " & myFeature.Name)
                lw.WriteLine(".FeatureType: " & myFeature.FeatureType)
                lw.WriteLine(".Timestamp: " & myFeature.Timestamp.ToString)
                lw.WriteLine("")
                Dim myPoints() As NXObject = myFeature.GetEntities
                For Each tempPt As Point In myPoints
                    lw.WriteLine(tempPt.Coordinates.ToString)
                Next
            End If
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
参与人数 1G币 +20 收起 理由
3D世界网-零 + 20 不错,支持你!
GMT+8, 2026-10-6 14:29
