楼主: B.D
[教程] 教你掌握UG背景颜色永久修改的方法(原创视频)
 火... [复制链接]
发表于 2018-8-21 12:11:18 | 显示全部楼层
学习下线
发表于 2018-8-23 08:16:43 | 显示全部楼层
感谢楼主分享
发表于 2018-8-24 17:18:45 | 显示全部楼层
我又了了学习
发表于 2018-8-24 17:28:49 | 显示全部楼层
;  Program Parameters File For AutoCAD 2007
;  External Command and Command Alias Definitions
;  Copyright (C) 1997-2006 by Autodesk, Inc.  All Rights Reserved.
;  Each time you open a new or existing drawing, AutoCAD searches
;  the support path and reads the first acad.pgp file that it finds.
;  -- External Commands --
;  While AutoCAD is running, you can invoke other programs or utilities
;  such Windows system commands, utilities, and applications.
;  You define external commands by specifying a command name to be used
;  from the AutoCAD command prompt and an executable command string
;  that is passed to the operating system.
;  -- Command Aliases --
;  The Command Aliases section of this file provides default settings for
;  AutoCAD command shortcuts.  Note: It is not recommended that  you directly
;  modify this section of the PGP file., as any changes you make to this section of the
;  file will not migrate successfully if you upgrade your AutoCAD to a
;  newer version.  Instead, make changes to the new
;  User Defined Command Aliases
;  section towards the end of this file.
;  -- User Defined Command Aliases --
;  You can abbreviate frequently used AutoCAD commands by defining
;  aliases for them in the User Defined Command Aliases section of acad.pgp.
;  You can create a command alias for any AutoCAD command,
;  device driver command, or external command.
;  Recommendation: back up this file before editing it.  To ensure that
;  any changes you make to PGP settings can successfully be migrated
;  when you upgrade to the next version of AutoCAD, it is suggested that
;  you make any changes to the default settings in the User Defined Command
;  Aliases section at the end of this file.
;  External command format:
;  <Command name>,[<Shell request>],<Bit flag>,[*]<Prompt>,
;  The bits of the bit flag have the following meanings:
;  Bit 1: if set, don't wait for the application to finish
;  Bit 2: if set, run the application minimized
;  Bit 4: if set, run the application "hidden"
;  Bit 8: if set, put the argument string in quotes
;  Fill the "bit flag" field with the sum of the desired bits.
;  Bits 2 and 4 are mutually exclusive; if both are specified, only
;  the 2 bit is used. The most useful values are likely to be 0
;  (start the application and wait for it to finish), 1 (start the
;  application and don't wait), 3 (minimize and don't wait), and 5
;  (hide and don't wait). Values of 2 and 4 should normally be avoided,
;  as they make AutoCAD unavailable until the application has completed.
;  Bit 8 allows commands like DEL to work properly with filenames that
;  have spaces such as "long filename.dwg".  Note that this will interfere
;  with passing space delimited lists of file names to these same commands.
;  If you prefer multiplefile support to using long file names, turn off
;  the "8" bit in those commands.
;  Examples of external commands for command windows
DEL,       DEL,            8,要删除的文件: ,
DIR,       DIR,            8,指定文件: ,
SH,        ,               1,*操作系统命令: ,
SHELL,     ,               1,*操作系统命令: ,
START,     START,          1,*要启动的应用程序: ,
TYPE,      TYPE,           8,要列出的文件: ,
; Examples of external commands for Windows
; See also the (STARTAPP) AutoLISP function for an alternative method.
EXPLORER,  START EXPLORER, 1,,
NOTEPAD,   START NOTEPAD,  1,*要编辑的文件: ,
PBRUSH,    START PBRUSH,   1,,
; Command alias format:
;   <Alias>,*<Full command name>
;  The following are guidelines for creating new command aliases.
;  1. An alias should reduce a command by at least two characters.
;      Commands with a control key equivalent, status bar button,
;      or function key do not require a command alias.
;      Examples: Control N, O, P, and S for New, Open, Print, Save.
;  2. Try the first character of the command, then try the first two,
;      then the first three.
;  3. Once an alias is defined, add suffixes for related aliases:
;      Examples: R for Redraw, RA for Redrawall, L for Line, LT for
;      Linetype.
;  4. Use a hyphen to differentiate between command line and dialog
;      box commands.
;      Example: B for Block, -B for -Block.
; Exceptions to the rules include AA for Area, T for Mtext, X for Explode.
;  -- Sample aliases for AutoCAD commands --
;  These examples include most frequently used commands.  NOTE: It is recommended
;  that you not make any changes to this section of the PGP file to ensure the
;  proper migration of your customizations when you upgrade to the next version of
;  AutoCAD.  The aliases listed in this section are repeated in the User Custom
;  Settings section at the end of this file, which can safely be edited while
;  ensuring your changes will successfully migrate.
3A,        *3DARRAY
3DMIRROR,  *MIRROR3D
3DNavigate,*3DWALK
3DO,       *3DORBIT
3DW,       *3DWALK
3F,        *3DFACE
3M,        *3DMOVE
3P,        *3DPOLY
3R,        *3DROTATE
A,         *ARC
AC,        *BACTION
ADC,       *ADCENTER
AECTOACAD, *-ExportToAutoCAD
AA,        *AREA
AL,        *ALIGN
3AL,       *3DALIGN
AP,        *APPLOAD
AR,        *ARRAY
-AR,       *-ARRAY
ATT,       *ATTDEF
-ATT,      *-ATTDEF
ATE,       *ATTEDIT
-ATE,      *-ATTEDIT
ATTE,      *-ATTEDIT
B,         *BLOCK
发表于 2018-8-24 17:30:33 | 显示全部楼层
板凳也占了
发表于 2018-8-24 17:34:20 | 显示全部楼层
谢谢楼主!!!
发表于 2018-8-24 17:34:50 | 显示全部楼层
发表于 2018-8-24 17:47:45 | 显示全部楼层
看看好东西
发表于 2018-8-24 18:06:36 | 显示全部楼层
发表于 2018-8-24 18:20:05 | 显示全部楼层
学习学习学习学习
GMT+8, 2026-10-31 00:13
