查看: 5683|回复: 6
[求助] UG12.0三轴后处理编程铣内圆,半径刀补不受机床控制,各位大神求解
发表于 2018-5-10 22:57:04 | 显示全部楼层 |阅读模式
UG12.0.三轴后处理。导出的程序,铣内圆,半径刀补不受机床的控制。如;精铣直径9的内圆,半径刀补R加减0.2---0.5mm,精铣的内圆没有变化,求各位大神解!谢谢各位了!
7万
发表于 2018-5-11 08:23:40 | 显示全部楼层
后处理输出的内圆程序不对。
发表于 2018-5-11 08:41:17 | 显示全部楼层
来学一招,谢谢
发表于 2018-5-11 08:52:57 | 显示全部楼层
最好上传下程序供参考一下,十有八九是设置问题导致后处理出来的程序不对
 楼主| 发表于 2018-5-25 12:57:20 | 显示全部楼层
% G17 G21 G40 G49 G54 G69 G80 G90 (This program is by Liuyi,thanks fou my wife) (Fri May 25 12:56:53 2018) T13 M06 (tool_name=UGT0201_016;tool_diameter=12;tool_length=28;tool_radius= 0) G00 G90 G54 X100. Y69. S5000 M03 G43 G90 Z70. H13 M08 Z1. G01 Z-2. F2000. G03 X100.072 Y70.639 I0. J0.821 X97.676 Y69.204 I-0.208 J-2.37 X99.156 Y65.684 I2.443 J-1.044 X104.595 Y68.187 I1.509 J3.882 X101.593 Y74.572 I-4.748 J1.666 X93.241 Y70.818 I-2.267 J-6.125 X97.233 Y61.344 I6.879 J-2.68 X108.766 Y65.797 I3.471 J8.17 X104.318 Y78.549 I-8.831 J4.071 X89.435 Y73.947 I-5.056 J-10.013 X93.784 Y57.792 I10.568 J-5.818 X112.11 Y61.978 I6.988 J11.615 X108.43 Y81.591 I-12.045 J7.892 X86.642 Y78.397 I-9.232 J-12.935 X89.076 Y55.345 I13.224 J-10.258 X114.268 Y56.967 I11.751 J13.933 X113.658 Y83.365 I-14.064 J12.881 X85.194 Y83.889 I-14.505 J-14.573 X83.413 Y54.312 I14.532 J-15.718 X114.941 Y51.081 I17.449 J14.825 X119.665 Y83.596 I-14.598 J18.722 X85.352 Y90.073 I-20.535 J-14.659 X77.161 Y54.933 I14.239 J-21.844 X113.908 Y44.702 I23.711 J14.057 X126.056 Y82.086 I-13.434 J25.031 X87.293 Y96.54 I-26.924 J-13.001 X70.74 Y57.359 I12.172 J-28.23 X111.037 Y38.258 I30.118 J11.482 X132.395 Y78.729 I-10.446 J31.383 X91.1 Y102.846 I-33.236 J-9.496 X64.598 Y61.648 I8.255 J-34.434 X106.299 Y32.206 I36.22 J7.048 X138.225 Y73.52 I-5.606 J37.325 X96.753 Y108.529 I-39.014 J-4.147 X59.195 Y67.751 I2.512 J-39.998 X99.764 Y27.005 I41.559 J0.809 X143.089 Y66.56 I1.009 J42.399 X104.125 Y113.136 I-43.802 J2.944 X54.978 Y75.518 I-4.931 J-44.472 X91.611 Y23.098 I45.688 J-7.082 X147.166 Y59.023 I9.296 J46.542 X112.99 Y116.242 I-46.946 J10.776 I-12.99 J-47.242 G41 G01 X100. Y69. G40 G00 Z70. G91 G28 Z0. M5 M19 M09 M01
66
发表于 2018-5-25 15:29:55 | 显示全部楼层
{:smile:}上图大家学习下~
发表于 2018-5-25 16:03:16 | 显示全部楼层
6666666
GMT+8, 2025-3-11 11:13
