查看: 1763|回复: 1
[求助] 发帖求助 ugnx12 doc的安装,不成功
发表于 2018-4-10 22:18:09 | 显示全部楼层 |阅读模式
又一个说明,可惜英文不好,安装后,路径下文件是空的
        Documentation                                           VERSION 12.0
        Linux & Mac                                   Issued:   October 2017
        Files on this DVD are for use on SUSE or Red Hat Linux OR Mac OS X.
        ___________________________________________________________________
        DVD CONTENTS:
        README.txt         General information and install instructions.
        WEB SERVED DOCUMENTATION:
        Siemens PLM documentation has been redesigned to use a Web server
        application to serve the documentation.
        Customers must decide on either a "Local Installation" using the
        splmdocserver kit or a "Company Wide Installation" approach using one
        of many available commercial Web servers. Please read the installation
        documentation for more information.
        _____________________________________________________________________
        INSTALLATION:
          SPLMDOCSERVER:
        Note: This kit should be installed first, and will install two daemons:
           1.  The mandatory Siemens PLM Solr Server used for searching.
           2.  The optional Siemens PLM Documentation Server.
        The installation program for the documentation Web server is contained
        in the "splmdocserverXXX" directory. (where XXX is the version)
        To install splmdocserver, change directory to "splmdocserverXXX" then
        run the install script: ./splmdocserver_install -v
        NOTE: The verbose switch (-v) is recommended for first time users.
        MacOS only: a run_splmdocserver script is provided to allow running
                    spmdocserver_install by double-clicking in Finder.
          DOCUMENTATION:
        The installation program for Documentation is contained in the
        "docs_help120" directory.
        NOTE: The Programmers Reference Manuals are available for download.
        To install DOCs, change directory to "docs_help120" then run the
        install script: ./nxdoc_install -v
        MacOS only: a run_nxdocs script is provided to allow running
                    nxdocs_install by double-clicking in Finder.
        ______________________________________________________________________
发表于 2018-4-15 18:08:49 | 显示全部楼层
这个是Linux平台的安装包
GMT+8, 2025-3-10 03:19
