查看: 1606|回复: 3
[求助] 进行仿真驱动出现的提示
发表于 2018-3-2 14:14:14 | 显示全部楼层 |阅读模式
Error: Element "L006/L006_com" (Type "AxisSystemEntity"): Reference Frame Vector "X" is zero while an unit vector is expected.
Error: Element "L006/L006_com" (Type "AxisSystemEntity"): Reference Frame Vector "Y" is zero while an unit vector is expected.
Error: Element "L006/L006_com" (Type "AxisSystemEntity"): Reference Frame Vector "Z" is zero while an unit vector is expected.
Error: Element "L006/L006_coi" (Type "AxisSystemEntity"): Reference Frame Vector "X" is zero while an unit vector is expected.
Error: Element "L006/L006_coi" (Type "AxisSystemEntity"): Reference Frame Vector "Y" is zero while an unit vector is expected.
Error: Element "L006/L006_coi" (Type "AxisSystemEntity"): Reference Frame Vector "Z" is zero while an unit vector is expected.
Error: Element "L007/L007_com" (Type "AxisSystemEntity"): Reference Frame Vector "X" is zero while an unit vector is expected.
Error: Element "L007/L007_com" (Type "AxisSystemEntity"): Reference Frame Vector "Y" is zero while an unit vector is expected.
Error: Element "L007/L007_com" (Type "AxisSystemEntity"): Reference Frame Vector "Z" is zero while an unit vector is expected.
Error: Element "L007/L007_coi" (Type "AxisSystemEntity"): Reference Frame Vector "X" is zero while an unit vector is expected.
Error: Element "L007/L007_coi" (Type "AxisSystemEntity"): Reference Frame Vector "Y" is zero while an unit vector is expected.
Error: Element "L007/L007_coi" (Type "AxisSystemEntity"): Reference Frame Vector "Z" is zero while an unit vector is expected.
Body "L006" has an invalid mass (mass is <= 0.0).
Body "L007" has an invalid mass (mass is <= 0.0).
Execution aborted due to error in hierarchy object module.
Partial results are stored as follows:
    Info file:      E:\毕业设计\dof_n
redun_法兰克_motion2-solution_1.minf
 楼主| 发表于 2018-3-2 14:42:24 | 显示全部楼层
有大神帮忙解答吗??
 楼主| 发表于 2018-3-2 15:21:10 | 显示全部楼层
我是在进行发那科机器人的运动仿真
连杆及运动副创建都没有问题,但解算就是会出现下图的提示 ,希望有大神能够帮忙解决,小弟感激不尽。
发表于 2018-3-29 20:34:13 | 显示全部楼层
QQ56501548
GMT+8, 2025-4-23 20:25
