查看: 3512|回复: 2
[求助] UG二次开发关于UF_CURVE_arc_p_t问题
发表于 2018-3-1 10:58:17 | 显示全部楼层 |阅读模式
使用acr_coords->radius进行相关操作会提示如下错误
代码如下
#include <uf.h>
#include <uf_exit.h>
#include <uf_ui.h>
#include <uf_disp.h>
#include <uf_curve.h>
#include <uf_csys.h>
#include <uf_obj.h>
#include <uf_modl.h>
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
#        include <strstream>
#   include <iostream>
        using std::ostrstream;
        using std::endl;
        using std::ends;
        using std::cerr;
#else
#        include <strstream.h>
#   include <iostream.h>
#endif
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
static int report_error( char *file, int line, char *call, int irc)
    if (irc)
        char
            err[133],
            messg[300];
        UF_get_fail_message(irc, err);
        sprintf(messg, "\n%s\nerror %d at line %d in %s\n%s",
            err, irc, line, file, call);
        printf("%s\n", messg);
        strcpy(&messg[129], "...");
        uc1601(messg, TRUE);  /* Internal only - remove for external */
    return(irc);
//设置选择的实体类型
static int init_proc( UF_UI_selection_p_t select, void *user_data )
    int  errorCode   = 0;
int  num_triples = 1; //选择类型 数量
UF_UI_mask_t mask_triples[]={UF_face_type,0,0,}; //定义选择类型
errorCode = UF_UI_set_sel_mask(select, UF_UI_SEL_MASK_CLEAR_AND_ENABLE_SPECIFIC,num_triples, mask_triples);
if( errorCode == 0)
  return UF_UI_SEL_SUCCESS;
else
  return UF_UI_SEL_FAILURE;
char *IntToChar(int a) ;                            //这两个函数已定义,功能将int 和 double 转换为char
char *DoubleToChar(double a) ;
static void do_it(void)
  char *message="提示!请选择表面。";
  char *title="请选择表面";
  int  scope=UF_UI_SEL_SCOPE_WORK_PART;//UF_UI_SEL_SCOPE_NO_CHANGE
  int  response;
  tag_t object_tag;                        //选择面的tag
  tag_t point;
  double  cursor[3]={0.0};
  tag_t view=NULL_TAG;
  UF_UI_lock_ug_access (UF_UI_FROM_CUSTOM);//加锁
  UF_UI_select_with_single_dialog(message,title,scope,init_proc,NULL,&response,&object_tag,cursor,&view);  //选择框
  UF_DISP_set_highlight(object_tag,0); //1高亮显示 0不高亮显示
  UF_UI_unlock_ug_access (UF_UI_FROM_CUSTOM);//解锁
  if (response==UF_UI_OBJECT_SELECTED)
    //获得面最外边缘
    int      n=0;
             int      loops_count=0;                // 封闭循环曲线数量
    tag_t    edge_id[2000];
    uf_loop_p_t       loops_list=NULL_TAG;     // 边的链表
    UF_CURVE_arc_p_t  acr_coords= 0;
    UF_MODL_ask_face_loops(object_tag,&loops_list );     //查询面上边的链表loops_list
    uc1601( IntToChar(object_tag),1 );           //
    UF_MODL_ask_loop_list_count(loops_list,&loops_count);//查询边的数量loops_count
    uc1601( IntToChar(loops_count), 1 );         //
    for (int l_i=0; l_i<loops_count; l_i++)
    int    loops_type=0;              //类型
    uf_list_p_t   edge_list=NULL_TAG; //边缘菜单指针ID
    UF_MODL_ask_loop_list_item(loops_list,l_i,&loops_type,&edge_list);  // 输出loops_type及edge_list
    uc1601( IntToChar(loops_type), 1 );        //
    if ( 2 == loops_type )                //边界=1, 洞=2, 其他=3
        uc1601( "有hole边界哦!", 1 );      //
        int  edge_count=0;             //边缘数量
        UF_MODL_ask_list_count ( edge_list, &edge_count );
     uc1601( "接下来是edge_count!", 1 );
     uc1601( IntToChar(edge_count), 1 );
        for(int edge_i=0; edge_i<edge_count;edge_i++)
      n=n+1;
      //输出边的tag edge_id
      UF_MODL_ask_list_item( edge_list,edge_i,&edge_id[n-1]);     //n-1 是因为 数组是从0开始的
      uc1601( IntToChar(edge_id[n-1]), 1 );
      UF_CURVE_ask_arc_data( edge_id[n-1],acr_coords );
      UF_DISP_set_highlight (edge_id[n-1],1);
      uc1601( "接下来是radius!", 1 );
      uc1601( DoubleToChar(acr_coords->radius), 1 );
      if ( fabs( acr_coords->radius - 5.0 ) < 1.0)
            uc1601( "到底出什么错了呢?!", 1 );
         //从输入边缘提取曲线并返回该曲线的标识符
      UF_MODL_create_curve_from_edge(edge_id[n-1],&edge_id[n-1]);
     uc1601( "222?", 1 );  //在这之前有个2
     if (n!=0)
    //char msg[32]="";
    //sprintf(msg, "%d",n);
    uc1601( "接下来是n!", 1 );
    uc1601( IntToChar(n),1 );
     else
     uc1601("UGapi提示!你选择的面没有发现边缘(比如:首尾相连的圆柱面不返回边缘)",1);
//        errorCode = UF_terminate();
// return;
void ufusr(char *param, int *retcode, int paramLen)
    if (UF_CALL(UF_initialize())) return;
    do_it();
    UF_terminate();
int ufusr_ask_unload( void )
        return (UF_UNLOAD_IMMEDIATELY);
 楼主| 发表于 2018-3-1 11:06:47 | 显示全部楼层
消灭0回复
发表于 2018-3-18 10:41:40 | 显示全部楼层
UF_CURVE_arc_t  arc_coords;
UF_CURVE_ask_arc_data( edge_id[n-1], &acr_coords );
这样试一下
GMT+8, 2025-4-29 09:19
