查看: 1965|回复: 3
[求助] VC++6.0配置NX8.5
发表于 2017-12-13 20:58:38 | 显示全部楼层 |阅读模式
本人初学者,严格按照教程配置VC环境,为何敲完代码构建时报错。代码如下
#include <stdio.h>
#include <uf.h>
#include <uf_modl.h>
#include <uf_ui.h>
#define UF_CALL(X) (report( __FILE__, __LINE__, #X, (X)))
static int report( char *file, int line, char *call, int irc)
    if (irc)
        char    messg[133];
        printf("%s, line %d:  %s\n", file, line, call);
        (UF_get_fail_message(irc, messg)) ?
            printf("    returned a %d\n", irc) :
        printf("    returned error %d:  %s\n", irc, messg);
    return(irc);
static void do_ugopen_api(void)
    UF_FEATURE_SIGN sign = UF_NULLSIGN;
    UF_FEATURE_SIGN sign1 = UF_POSITIVE;
    double block_orig[3] = {0.0,0.0,0.0};
    double block_orig1[3] = {0.0,0.0,2.5};
    char *block_len[3] = {"1","2","3"};
    char *block_len1[3] = {"1", "1", "1"};
    tag_t blk_obj;
    tag_t blk1_obj;
    UF_CALL(UF_MODL_create_block1(sign, block_orig, block_len, &blk_obj));
    UF_CALL(UF_MODL_create_block1(sign1, block_orig1, block_len1, &blk1_obj));
/*ARGSUSED*/
void ufusr(char *param, int *retcode, int paramLen)
    if (!UF_CALL(UF_initialize()))
        do_ugopen_api();
        UF_CALL(UF_terminate());
int ufusr_ask_unload(void)
    return (UF_UNLOAD_IMMEDIATELY);
看网上说要加个头文件#include <stdafx>,实验发现没有用,错误显示为各种未声明变量。
 楼主| 发表于 2017-12-14 16:12:03 | 显示全部楼层
求各路大神,志同道合的人解答
发表于 2017-12-30 18:28:13 | 显示全部楼层
如果是64位的NX8.5,必须用VS2010SP1以上的版本才可以支持开发。VC6只能开发32位的。
发表于 2018-1-4 17:42:27 | 显示全部楼层
我也是这样。请问vs2012怎么定制开发环境?
GMT+8, 2025-4-29 09:39
