查看: 6186|回复: 15
[求助] UX11.0为什么老师安装不上,系统版本MacOS High Sierra 10.13.1
发表于 2017-11-12 15:41:24 | 显示全部楼层 |阅读模式
提示错误:
NX Initialization Error
License Error:  The desired vendor daemon is down. [ -97 ]
求解大神,求助老叶,怎么破?
另外求问,NX12.0 for Mac 什么时候出来!
@老叶
发表于 2017-11-15 11:25:55 | 显示全部楼层
12.0 For Mac已经出来好多天了
发表于 2017-11-15 11:58:06 | 显示全部楼层
太简单了!不懂远程帮你
发表于 2017-11-15 15:25:14 | 显示全部楼层
1. Show the /Applications/SolidSQUAD_License_Servers/Logs/lmgrd.log
2. On High Sierra, there is an XQuartz bug. To fix it, open Terminal and issue commands:
sudo mv /opt/X11/lib/libXt.6.dylib{,.bak}
sudo cp /opt/X11/lib{/flat_namespace,}/libXt.6.dylib
发表于 2017-11-17 11:52:03 | 显示全部楼层
#神马都是浮云# 发表于 2017-11-15 11:58
太简单了!不懂远程帮你
我的安装好了,许可也显示成功,但是到启动界面就软件就自动退出了,可以帮看看什么原因吗?
  1. 14:53:40 (ugslmd) EXTERNAL FILTERS are OFF
  2. 14:53:40 (lmgrd) ugslmd using TCP-port 49157
  3. 14:53:40 (ugslmd) SLOG: Statistics Log Frequency is 240 minute(s).
  4. 14:53:40 (ugslmd) SLOG: TS update poll interval is 600 seconds.
  5. 14:53:40 (ugslmd) SLOG: Activation borrow reclaim percentage is 0.
  6. 14:53:40 (ugslmd) (@ugslmd-SLOG@) ===============================================
  7. 14:53:40 (ugslmd) (@ugslmd-SLOG@) === Vendor Daemon ===
  8. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Vendor daemon: ugslmd
  9. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Start-Date: Thu Nov 16 2017 14:53:40 CST
  10. 14:53:40 (ugslmd) (@ugslmd-SLOG@) PID: 265
  11. 14:53:40 (ugslmd) (@ugslmd-SLOG@) VD Version: v11.13.1.3 build 176262 x64_mac10 ( build 176262 (ipv6))
  12. 14:53:40 (ugslmd) (@ugslmd-SLOG@)
  13. 14:53:40 (ugslmd) (@ugslmd-SLOG@) === Startup/Restart Info ===
  14. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Options file used: None
  15. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Is vendor daemon a CVD: No
  16. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Is TS accessed: No
  17. 14:53:40 (ugslmd) (@ugslmd-SLOG@) TS accessed for feature load: -NA-
  18. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Number of VD restarts since LS startup: 0
  19. 14:53:40 (ugslmd) (@ugslmd-SLOG@)
  20. 14:53:40 (ugslmd) (@ugslmd-SLOG@) === Network Info ===
  21. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Listening port: 49157
  22. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Daemon select timeout (in seconds): 1
  23. 14:53:40 (ugslmd) (@ugslmd-SLOG@)
  24. 14:53:40 (ugslmd) (@ugslmd-SLOG@) === Host Info ===
  25. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Host used in license file: macbook-pro
  26. 14:53:40 (ugslmd) (@ugslmd-SLOG@) Running on Hypervisor: None (Physical)
  27. 14:53:40 (ugslmd) (@ugslmd-SLOG@) LMBIND needed: No
  28. 14:53:40 (ugslmd) (@ugslmd-SLOG@) LMBIND port: -NA-
  29. 14:53:40 (ugslmd) (@ugslmd-SLOG@) ===============================================
  30. 14:53:40 (ugslmd) TCP_NODELAY NOT enabled
  31. 14:53:48 (ugslmd) OUT: "gateway" zy@macbook-pro
  32. 14:53:49 (ugslmd) IN: "gateway" zy@macbook-pro
复制代码
发表于 2017-11-17 11:52:53 | 显示全部楼层
2. On High Sierra, there is a ...
 楼主| 发表于 2017-11-17 20:35:31 | 显示全部楼层
这是什么意思?没看懂?怎么操作,能不能说一下?谢谢层主!!!
发表于 2017-11-18 09:58:25 | 显示全部楼层
1.贴出/Applications/SolidSQUAD_License_Servers/Logs/lmgrd.log位置的日志文件
2.终端输入sudo开头的两条命了解决
 楼主| 发表于 2017-11-18 22:13:08 | 显示全部楼层
2.终端输入sudo开头的 ...
我的/Applications目录没有你说的这个SolidSQUAD_License_Servers;
你说的贴出是从哪里粘贴到哪里?麻烦层主给我详细说一下!万分感谢!
发表于 2017-11-18 22:16:09 | 显示全部楼层
你说的贴出是从哪里粘贴到哪里?麻烦 ...
nx11可能在siemens/plm下
GMT+8, 2025-3-13 03:24
