查看: 2332|回复: 6
[求助] 刀具信息显示格式哪里错了
发表于 2017-11-5 11:13:45 | 显示全部楼层 |阅读模式
global mom_tool_name mom_tool_type
global mom_tool_diameter mom_tool_corner1_radius mom_tool_flute_length
global mom_tool_length tip_angle mom_tool_point_angle RAD2DEG
if ![ info exists mom_tool_corner1_radius ] { set mom_tool_corner1_radius 0 }
if { $mom_tool_type == "Drilling Tool" } {
set tip_angle [ expr $mom_tool_point_angle * $RAD2DEG ]
MOM_output_literal ";(D=[format "%.2f" $mom_tool_diameter] Tip angle=[format "%.2f"
$mom_tip_angle] F=[format "%.2f" $mom_tool_flute_length ] L=[ format "%.2f"
$mom_tool_length ])"
} else {
MOM_output_literal ";(D=[format "%.2f" $mom_tool_diameter] R=[format "%.2f"
$mom_tool_cornerl_radius] F=[format "%.2f" $mom_tool_flute_length] L=[format "%.2f"
请问格式哪里借了,
7万
发表于 2017-11-5 12:11:55 | 显示全部楼层
是corner1,而不是cornerl
 楼主| 发表于 2017-11-5 20:24:53 | 显示全部楼层
非常感谢
发表于 2017-11-5 21:02:39 | 显示全部楼层
这是刀具清单吗
发表于 2017-11-5 23:00:35 | 显示全部楼层
有高手呀,
 楼主| 发表于 2017-11-6 11:00:07 | 显示全部楼层
if ![info exists mom_tool_corner1_radius] { set mom_tool_corner1_radius 0 }
if {$mom_tool_type=="Drilling Tool"}
{set tip_angle [ expr $mom_tool_point_angle*$RAD2DEG ]
MOM_output_literal ";(D=[format "%.2f" $mom_tool_diameter] Tip angle=[format "%.2f" $mom_tip_angle] F=[format "%.2f" $mom_tool_flute_length ] L=[format "%.2f" $mom_tool_length])"
else{MOM_output_literal ";(D=[format "%.2f" $mom_tool_diameter] R=[format "%.2f" $mom_tool_corner1_radius] F=[format "%.2f" $mom_tool_flute_length] L=[format "%.2f" $mom_tool_length])"
 楼主| 发表于 2017-11-6 15:06:18 | 显示全部楼层
已解决
GMT+8, 2025-3-13 05:39
