查看: 39165|回复: 19
[已回复] UG NX12.0许可证问题,愁死我了
发表于 2017-11-3 22:26:26 | 显示全部楼层 |阅读模式
Universal License Server Installer
    2017 TeAM SolidSQUAD-SSQ
bash.exe: warning: could not find /tmp, please create!
tr: warning: an unescaped backslash at end of string is not portable
Installing LMGRD...
Flexnet Licensing Service DACL is not updated
Please Install Flexnet Licensing Service and run installs.exe -a <service name>
FlexNet License Manager is successfully installed
as one of your Windows Services.  Some handy tips:
        * The FlexNet License Manager will be automatically started
          every time your system is booted.
        * The FlexNet service log file is lmgrd.log in your NT system
          directory.
        * To remove FlexNet License Manager, type 'installs -r'
The permissions of one of the files that you just installed seems
to have the correct settings.
[SC] ChangeServiceConfig 成功
SERVICE_NAME: SSQ FLEXLM Service
        TYPE               : 10  WIN32_OWN_PROCESS
        STATE              : 2  START_PENDING
                                (NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x1
        WAIT_HINT          : 0x1d4c0
        PID                : 8764
        FLAGS              :
NX许可服务已经安装完成! ~老叶!
请按任意键继续. . .
ug12.0安装了几遍了,一直打不开,许可证问题。服务里面的许可证一直无法启动,安装许可证时的提示如红色字体。求大神帮忙。 05.PNG 04.PNG 03.PNG
 楼主| 发表于 2017-11-3 22:27:01 | 显示全部楼层
来个大神帮帮忙{:mad:}
发表于 2017-11-3 22:33:49 | 显示全部楼层
什么系统操作的。win7 还是win10
 楼主| 发表于 2017-11-3 22:37:37 | 显示全部楼层
win10  64位
 楼主| 发表于 2017-11-3 22:38:27 | 显示全部楼层
装了五六遍了,两种方法都试了,都不行
发表于 2017-11-3 22:46:52 | 显示全部楼层
环境变量将28000修改成27800
发表于 2017-11-3 22:57:39 | 显示全部楼层
不行就远程安装
 楼主| 发表于 2017-11-3 23:04:11 | 显示全部楼层
环境变量改了呀
发表于 2017-11-4 00:54:35 | 显示全部楼层
You need to do the following
1. Run as Administrator the server uninstaller script
2. Rename NX6.0-12LicenseServers to SolidSQUAD_License_Servers and move it to D:\
3. Run as Administrator the server installer script
4. Check the Logs folder gets lmgrd.log
发表于 2017-11-4 02:19:40 | 显示全部楼层
重装系统就可以了,我就是重装系统搞定的
GMT+8, 2025-3-10 21:05
