查看: 5552|回复: 4
[求助] 请分析是哪里的问题
发表于 2017-10-30 18:38:18 | 显示全部楼层 |阅读模式
Universal License Server Installer
    2017 TeAM SolidSQUAD-SSQ
bash.exe: warning: could not find /tmp, please create!
tr: warning: an unescaped backslash at end of string is not portable
Installing LMGRD...
Flexnet Licensing Service DACL updated successfully
FlexNet License Manager is successfully installed
as one of your Windows Services.  Some handy tips:
        * The FlexNet License Manager will be automatically started
          every time your system is booted.
        * The FlexNet service log file is lmgrd.log in your NT system
          directory.
        * To remove FlexNet License Manager, type 'installs -r'
The permissions of one of the files that you just installed seems
to have the correct settings.
[SC] ChangeServiceConfig 成功
SERVICE_NAME: SSQ FLEXLM Service
        TYPE               : 10  WIN32_OWN_PROCESS
        STATE              : 2  START_PENDING
                                (NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x7d0
        PID                : 18948
        FLAGS              :
All done! Enjoy!
请按任意键继续. . .
终止批处理操作吗(Y/N)?
发表于 2017-10-30 18:48:28 | 显示全部楼层
没问题吧?
103
 楼主| 发表于 2017-10-30 21:47:52 | 显示全部楼层
没有问题了
发表于 2017-10-30 22:03:12 | 显示全部楼层
Looks fine.
Make sure you changed SPLM_LICENSE_SERVER to 27800@localhost and overwrote the NX 12.0 client crack files
发表于 2017-10-30 22:12:48 | 显示全部楼层
Yes. To control everything runs well:
1. SSQ FlexLM Service must be Running
2. There must be SolidSQUAD_License_Servers\Logs\lmgrd.log
GMT+8, 2025-4-19 21:35
