查看: 4477|回复: 7
[求助] prt打不开这是我用nxopen导入stp形成的prt
发表于 2017-10-25 09:43:30 | 显示全部楼层 |阅读模式
file:///C:\Users\Administrator\AppData\Roaming\Tencent\Users\429570094\QQ\WinTemp\RichOle\E6SGE6ICVUU7M~8HXXQQY(0.png这是为啥,prt打不开这是我用nxopen导入stp形成的prt
** VayoDFM2UG_prt.cpp
** Description:
**     Contains Unigraphics entry points for the application.
/* Include files */
#if ! defined ( __hp9000s800 ) && ! defined ( __sgi ) && ! defined ( __sun )
#   include <strstream>
#   include <iostream>
    using std::ostrstream;
    using std::endl;
    using std::ends;
    using std::cerr;
#else
#   include <strstream.h>
#   include <iostream.h>
#endif
#include <uf.h>
#include <uf_ui.h>
#include <uf_exit.h>
#include <uf_part.h>
#include <io.h>
#include <string.h>
#include <string>
#include <locale.h>
#include <stdlib.h>
#include <fstream>
#include <stdafx.h>
#include <uf_modl.h>
#include "uf_weight.h"
#include <uf_attr.h>
#include<uf_obj.h>
#include<UF_ASSEM.h>
#include "Step214Importer.hxx"
#include <uf_defs.h>
#include <NXOpen/NXException.hxx>
#include <NXOpen/Session.hxx>
#include <NXOpen/BasePart.hxx>
#include <NXOpen/Builder.hxx>
#include <NXOpen/DexManager.hxx>
#include <NXOpen/FileNew.hxx>
#include <NXOpen/NXObject.hxx>
#include <NXOpen/ObjectTypeSelector.hxx>
#include <NXOpen/Part.hxx>
#include <NXOpen/PartCollection.hxx>
#include <NXOpen/PartCloseResponses.hxx>
#include <NXOpen/PDM_PartFromTemplateBuilder.hxx>
#include <NXOpen/PDM_PartManager.hxx>
#include <NXOpen/Step214Importer.hxx>
using namespace NXOpen;
#define UF_CALL(X) (report_error( __FILE__, __LINE__, #X, (X)))
using namespace std;
static int report_error( char *file, int line, char *call, int irc)
    if (irc)
        char err[133],
             msg[133];
        sprintf(msg, "*** ERROR code %d at line %d in %s:\n+++ ",
            irc, line, file);
        UF_get_fail_message(irc, err);
        UF_print_syslog(msg, FALSE);
        UF_print_syslog(err, FALSE);
        UF_print_syslog("\n", FALSE);
        UF_print_syslog(call, FALSE);
        UF_print_syslog(";\n", FALSE);
        if (!UF_UI_open_listing_window())
            UF_UI_write_listing_window(msg);
            UF_UI_write_listing_window(err);
            UF_UI_write_listing_window("\n");
            UF_UI_write_listing_window(call);
            UF_UI_write_listing_window(";\n");
    return(irc);
CStringArray* SplitLine(CString source, CString division)
        CString  csflag;
        CStringArray* dest = new CStringArray() ;
        OutputDebugString(source);
        OutputDebugString(L"\n");
    dest->RemoveAll();
    int pos = 0;
    int pre_pos = 0;
        int iCount_1=0;
        CString Temp;
    while( -1 != pos ){
                int temp1=0;
                int temp2=0;
                iCount_1++;
        pre_pos = pos;
        pos = source.Find(division,(pos+1));
        if(pos == -1){
                        if(iCount_1 == 1){
         //   temp1=source.GetLength()-pre_pos;
                //temp2=pre_pos;
         //   csflag.Format(L"%d",temp1);
         //   OutputDebugString(csflag);
                //OutputDebugString(L"\n");
                //csflag.Format(L"%d",temp2);
        Temp=source.Mid(pre_pos,source.GetLength()-pre_pos);
                                                else{
                // temp1=source.GetLength()-(pre_pos+1);
                // temp2=pre_pos+1;
                                                Temp=source.Mid(pre_pos+1,source.GetLength()-(pre_pos+1));
                                        }else{
                                        if(iCount_1 == 1){
         //         temp1=pos-(pre_pos);
  //           temp2=pre_pos;
                                        Temp=source.Mid(pre_pos,(pos-(pre_pos)));
        else{
         //   temp1=pos-(pre_pos+1);
         //   temp2=pre_pos+1;
        Temp=source.Mid(pre_pos+1,(pos-(pre_pos+1)));
                int compareid=wcscmp(Temp.GetBuffer(), L"");
                if(compareid != 0){
                dest->Add(Temp);
                Temp.ReleaseBuffer();
        //AfxMessageBox(Temp);
   return  dest;
// 将Char型字符转换为Unicode字符
int CharToUnicode(char *pchIn, CString *pstrOut)
    int nLen;
    WCHAR *ptch;
    if(pchIn == NULL)
        return 0;
    nLen = MultiByteToWideChar(CP_ACP, 0, pchIn, -1, NULL, 0);
    ptch = new WCHAR[nLen];
    MultiByteToWideChar(CP_ACP, 0, pchIn, -1, ptch, nLen);
    pstrOut->Format(_T("%s"), ptch);
    delete [] ptch;
    return nLen;
**  Activation Methods
/*  Unigraphics Startup
**      This entry point activates the application at Unigraphics startup */
extern DllExport void ufsta( char *param, int *returnCode, int rlen )
    /* Initialize the API environment */
    if( UF_CALL(UF_initialize()) )
        /* Failed to initialize */
        return;
        CString strText;
    CString szLine; //存储行字符串
    CStdioFile file;
        CString file_path;//list文件路径
        CStringArray *destArray;//全局数组,参数名
        CStringArray *OutputArrayFile;//文件读入数组
    //ProError Error;
        TCHAR strPath_temp[MAX_PATH];
   OutputDebugString(strPath_temp);
////////////////////test use
//////////////EXE路径
//CString  path=AfxGetApp()->m_pszHelpFilePath;
//CString  str=AfxGetApp()->m_pszExeName;
//path=path.Left(path.GetLength()-str.GetLength()-4);
CString inipath;
CString  PropList;
CString  PropLIB;
//inipath=path+ L"\config.ini";
inipath="D:\\UG\\UGII\\config.ini";
//AfxMessageBox(inipath);
OutputDebugString(inipath);
GetPrivateProfileString(L"ProE_Parameter",L"PropList",L"Default",PropList.GetBuffer(MAX_PATH),MAX_PATH,inipath);
GetPrivateProfileString(L"ProE_Parameter",L"LIB",L"Default",PropLIB.GetBuffer(MAX_PATH),MAX_PATH,inipath);
bool flag = CreateDirectory(PropLIB, NULL);
OutputDebugString(PropLIB);
char temps1[99999];
sprintf(temps1,"%S",PropLIB);
         if(_access(temps1, 00)==0)
          OutputDebugString(L"LIB has created\n");
         }else{
                 if(flag)
                 else{
                         PropLIB="C:\\LIB";
                         OutputDebugString(L"LIB has created C:\\LIB\n");
//AfxMessageBox(PropList);
     destArray=SplitLine(PropList.GetBuffer(PropList.GetLength()),L",");//ini文件解析
     PropList.ReleaseBuffer();
         destArray->InsertAt(0,L"STEP_NAME");
         destArray->InsertAt(0,L"PART_RENAME");
     destArray->InsertAt(0,L"PART_NAME");
                 CString t;
                                t.Format(L"%d",destArray->GetCount());
                                OutputDebugString(L"destArray: Count->");
                                OutputDebugString(t);
                 for (int n = 0; n < destArray->GetCount(); n ++)
                                CString t;
                                t.Format(L"%s",(*destArray)[n]);
GetTempPath(MAX_PATH, strPath_temp);
file_path.Format(L"%s\\proe\\list.txt",strPath_temp);
//MessageBox(file_path);
        //Error=ProDirectoryCurrentGet(pro_path);
        //Error=ProDirectoryChange(PropLIB.GetBuffer());
        //PropLIB.ReleaseBuffer();
        //                         if( Error != PRO_TK_NO_ERROR )
        //                                  AfxMessageBox(L"ProDirectoryChange error: 可能PROE未启动 ");
        //                           return;
try
        CFile file(file_path, CFile::modeRead);
        char* buf = NULL;
        DWORD dwLen = (DWORD)file.GetLength();
        buf = new char[dwLen + 1];
        memset(buf, 0, dwLen + 1);
        file.Read(buf, dwLen);
        file.Close();
        CString str(buf);
        delete[] buf;
        buf = NULL;
//AfxMessageBox(str);
                OutputArrayFile=SplitLine(str,L"\r");
                        CString t;
                        t.Format(L"FileLineCount: %d",OutputArrayFile->GetCount());
                        OutputDebugString(L"|end\n");
    catch (CException* e)
        e->ReportError();
        e->Delete();
//file.Open(file_path,CFile::modeRead);//打开文件
//逐行读取字符串
 楼主| 发表于 2017-10-25 09:45:27 | 显示全部楼层
        for (int i1 = 0; i1 < OutputArrayFile->GetCount(); i1 ++)
            szLine=(*OutputArrayFile)[i1].GetBuffer();
                        CStringArray *OutputArrayLine;
                        CString file_path_step;
                    //最后一个带回车
                        szLine.Replace(L"\n",L"");
                        CString t;
            OutputDebugString(L"start|");
                         OutputDebugString(szLine);
                        ////////////////////////行分隔
                        OutputArrayLine=SplitLine(szLine,L"\t");
                        szLine.ReleaseBuffer();
        int n = OutputArrayLine->GetCount();
        if(n ==0){
        //行结束退出
        OutputDebugString(L"Skip blank line.\n");
                                //return;
        }else{
                                char prt_name[256];
                                char file_path_stepW[260];
                                double m_mass;
                                char mass_temps[256];
                                //ProName w_name;
                                //ProPath input_file;
                                //ProMdl model;
                                //int w_id;
                                //ProMassProperty mass_prop;
                                double mass_value;
                                double mass_density;
                                t.Format(L"modelname: %s",(*OutputArrayLine)[0].GetBuffer());
                                file_path_step.Format(L"%s\\ProE\\%s",strPath_temp,(*OutputArrayLine)[2].GetBuffer());
                                sprintf(file_path_stepW,"%S",file_path_step);
                CString prt_name_temp;
                                prt_name_temp.Format(L"%s\\ProE\\%s",strPath_temp,(*OutputArrayLine)[1].GetBuffer());
                                //prt_name_temp=(*OutputArrayLine)[1].GetBuffer();
                                sprintf(prt_name,"%S",prt_name_temp);
                                sprintf(mass_temps, "%S", (*OutputArrayLine)[3].GetBuffer());
                                m_mass=atof(mass_temps);
                                if(m_mass == 0){//赋默认质量1mg
                                m_mass=1;
        Session *theSession = Session::GetSession();
    //   Menu: File->New...
    //Session::UndoMarkId markId1;
   // markId1 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
    FileNew *fileNew1;
    fileNew1 = theSession->Parts()->FileNew();
    //theSession->SetUndoMarkName(markId1, NXString("##84New \345\257\271\350\257\235\346\241\206", NXString::UTF8));
    //Session::UndoMarkId markId2;
    //markId2 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "##84New");
    fileNew1->SetTemplateFileName("model-plain-1-mm-template.prt");
    fileNew1->SetApplication(FileNewApplicationModeling);
    fileNew1->SetUnits(Part::UnitsMillimeters);
    fileNew1->SetTemplateType(FileNewTemplateTypeItem);
    fileNew1->SetNewFileName(prt_name);
    fileNew1->SetMasterFileName("");
    fileNew1->SetUseBlankTemplate(false);
    fileNew1->SetMakeDisplayedPart(true);
    NXObject *nXObject1;
    nXObject1 = fileNew1->Commit();
    Part *workPart(theSession->Parts()->Work());
    Part *displayPart(theSession->Parts()->Display());
   // theSession->DeleteUndoMark(markId2, NULL);
   fileNew1->Destroy();
    //Session::UndoMarkId markId3;
    //markId3 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Enter Modeling");
    //   Menu: File->Import->STEP214...
   // Session::UndoMarkId markId4;
   // markId4 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
    Step214Importer *step214Importer1;
    step214Importer1 = theSession->DexManager()->CreateStep214Importer();
    step214Importer1->SetSimplifyGeometry(true);
    step214Importer1->SetLayerDefault(1);
    step214Importer1->SetInputFile(file_path_stepW);
    step214Importer1->SetSettingsFile("D:\\UG\\step214ug\\step214ug.def");
    step214Importer1->ObjectTypes()->SetSolids(true);
    step214Importer1->SetFlattenAssembly(true);
    step214Importer1->SetOutputFile("D:\\UG\\UGII\\ug-open2-test\\ug--data\\2.prt");
    step214Importer1->SetInputFile("");
    step214Importer1->SetOutputFile("");
    //theSession->SetUndoMarkName(markId4, NXString("Import from STEP214 Options \345\257\271\350\257\235\346\241\206", NXString::UTF8));
    step214Importer1->SetOutputFile(prt_name);
    //Session::UndoMarkId markId5;
    //markId5 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "Import from STEP214 Options");
    step214Importer1->SetFileOpenFlag(false);
    NXObject *nXObject2;
    nXObject2 = step214Importer1->Commit();
    //theSession->DeleteUndoMark(markId5, NULL);
    //theSession->SetUndoMarkName(markId4, "Import from STEP214 Options");
    step214Importer1->Destroy();
        if(_access(file_path_stepW, 00)==0)//判断文件是否存在
                                                       for (int i = 0; i < n; i ++)
        /////debug
        t.Format(L"%d",i);
        OutputDebugString(L"-->");
        /////debug end
        int temp_i=i;
        CString ProParaName;
        //ProModelitem modelitem;
        //ProParamvalue proval;
        //ProParameter param;
        //ProName Pro_PARA_NAME;
        //wchar_t TempProName[PRO_VALUE_SIZE];
        int compareid;
        char ssa[255];    //属性标题
        char sva[255];
        //char ProParaName_char[PRO_FEATREF_KEY_SIZE];
        //char ProParaValue_char[PRO_VALUE_SIZE];
        if(destArray->GetCount() < i+1){
        CString t;
        t.Format(L"INPUT_%d",i);
        sprintf(ssa,"%S",t);
        //AfxMessageBox(t);
        //////////////////////////debug
        OutputDebugString(L"->");
        t.Format(L"%s",(*OutputArrayLine)[temp_i].GetBuffer());
        //////////////////////////debug end
        else{
        sprintf(ssa,"%S",(*destArray)[i].GetBuffer());
        //char ssa[255];    //属性标题
        //char sva[255];
        CString t;
        t.Format(L"%s",(*destArray)[i].GetBuffer());
        //sprintf(ssa,"%S",t);
        //sprintf(sva,"%S",t);
                                              //写入属性
        //AfxMessageBox(destArray[i]);
        sprintf(sva,"%S",(*OutputArrayLine)[temp_i].GetBuffer());
        // AfxMessageBox(temp);
        /////////////////////////写入参数质量
        compareid=wcscmp((*OutputArrayLine)[temp_i].GetBuffer(), L"-1");
        if(compareid != 0){
        compareid=wcscmp((*OutputArrayLine)[temp_i].GetBuffer(), L"");
        if(compareid != 0){
        tag_t workpart;
            workpart=UF_ASSEM_ask_work_part();
           // char ssa[255]="质量";    //属性标题
        //char sva[255]="55";        //属性值
        UF_ATTR_value_t  attr_va;
        attr_va.type=UF_ATTR_string; //属性类型 字符串
        attr_va.value.string=sva;
        UF_ATTR_assign(workpart,ssa,attr_va);
    //   Menu: File->Save
        //Session::UndoMarkId markId9;
    //markId9 = theSession->SetUndoMark(Session::MarkVisibilityVisible, "Start");
                                               (*OutputArrayLine)[temp_i].ReleaseBuffer();
   // theSession->SetUndoMarkName(markId9, NXString("Name Parts \345\257\271\350\257\235\346\241\206", NXString::UTF8));
    //Session::UndoMarkId markId10;
    //markId10 = theSession->SetUndoMark(Session::MarkVisibilityInvisible, "Name Parts");
    workPart->AssignPermanentName(prt_name);
   // theSession->DeleteUndoMark(markId10, NULL);
   // theSession->SetUndoMarkName(markId9, "Name Parts");
    PartSaveStatus *partSaveStatus1;
    partSaveStatus1 = workPart->Save(BasePart::SaveComponentsTrue, BasePart::CloseAfterSaveFalse);
    delete partSaveStatus1;
    PartCloseResponses *partCloseResponses1;
    partCloseResponses1 = theSession->Parts()->NewPartCloseResponses();
    workPart->Close(BasePart::CloseWholeTreeFalse, BasePart::CloseModifiedUseResponses, partCloseResponses1);
    workPart = NULL;
    displayPart = NULL;
    delete partCloseResponses1;
                                         }//if存在file_path_stepW
                                         else{
                                         CString Mes_file_path_step;
                                         Mes_file_path_step.Format(L"Missing file: %s",file_path_step);
                     AfxMessageBox(file_path_step);
                                         //return;
                                }//skip blank
                   delete OutputArrayLine;
        }//for i
        delete destArray;
        delete OutputArrayFile;
    UF_CALL(UF_terminate());
extern int ufusr_ask_unload (void)
        /* 设置UF程序运行以后立刻从内存中卸除,即当重新修改、编译成新的DLL文件时,UG无须关闭重启动,就可调用此新的*.DLL文件 */
        return (UF_UNLOAD_IMMEDIATELY);
53
灌水王活跃会员
发表于 2017-10-26 08:12:19 | 显示全部楼层
表示看不懂
发表于 2018-9-2 15:20:02 | 显示全部楼层
回帖奖励 +10 G币
具体问的什么问题?表示没看懂
发表于 2018-12-15 10:50:20 | 显示全部楼层
看着很厉害的样子
发表于 2018-12-15 10:51:35 | 显示全部楼层
看着很厉害的样子
发表于 2018-12-15 11:22:42 | 显示全部楼层
回帖奖励 +10 G币
具体问的什么问题?表示没看懂
发表于 2018-12-19 12:46:04 | 显示全部楼层
回帖奖励 +10 G币
修复下 看看
GMT+8, 2026-6-16 10:17
