查看: 6898|回复: 5
[求助] 五轴加工坐标转换
发表于 2017-9-23 11:09:28 | 显示全部楼层 |阅读模式
谁能帮忙看看这个程序是怎么坐标转换的,程序如下。实际加工应该是C Z轴联动 Y 轴应该为0,程序里面是五轴联动,厂家给的后处理,实在看不懂怎么回事。程序上机没问题,就是不理解怎么坐标转换的,高手指教下,谢谢!
(INTEGREX e-420HS II Post Version1.00,2014/02/20)
(98KW80C1)
N1
M200
M212
G90G94G54G97G40
G91G28Y0.
G90G00
G91G28X0.
G91G28Z0.
G90G00
T007T000M06
G91G28Y0.
M08
G61.1
M03S2400
G10.9X0
M108
G17
G90G54B99.1852
G90G00C-1.3514
G43.4G00X155.3605Y10.7684Z-272.3476B99.1852C-1.3514H007
G05P2
G01F8000.
X153.3009Y10.817Z-272.0145F7000.
X151.6881Y10.7839Z-271.7476F3200.
X150.0963Y10.5386Z-271.4659
X148.5526Y10.085Z-271.1744
X147.0836Y9.4311Z-270.8779
X145.7144Y8.5881Z-270.5817
X144.4683Y7.5702Z-270.2906
X143.3667Y6.395Z-270.0098
X142.4284Y5.0825Z-269.744
X141.6696Y3.6553Z-269.4977
X141.1031Y2.1377Z-269.2753
X140.7388Y.5557Z-269.0804
X140.5827Y-1.0637Z-268.9165
X140.3766Y-7.6829Z-268.3171B99.185C-4.0539
X139.8599Y-14.2751Z-267.7178B99.1849C-6.7483
X139.034Y-20.8356Z-267.1186B99.185C-9.4419
X137.8999Y-27.354Z-266.5195B99.1851C-12.1383
X136.459Y-33.816Z-265.9202B99.185C-14.8384
X134.7172Y-40.1975Z-265.3209B99.1849C-17.5351
X132.6785Y-46.4866Z-264.7217B99.185C-20.2281
X130.3448Y-52.677Z-264.1225C-22.924
X127.7201Y-58.7551Z-263.5233B99.1851C-25.6238
X124.8141Y-64.6994Z-262.924B99.1849C-28.3218
X121.6345Y-70.4956Z-262.3248B99.185C-31.0147
X118.184Y-76.1391Z-261.7256C-33.71
X114.4687Y-81.6181Z-261.1264B99.1851C-36.409
X110.5005Y-86.915Z-260.5271B99.1849C-39.1083
X106.292Y-92.014Z-259.9278C-41.8015
X101.8466Y-96.9118Z-259.3286B99.185C-44.4964
X97.1719Y-101.5984Z-258.7294B99.1851C-47.1949
X92.2813Y-106.0601Z-258.13B99.1849C-49.8951
X87.1926Y-110.2815Z-257.5308C-52.5888
X81.9096Y-114.2603Z-256.9316B99.185C-55.2832
X76.4413Y-117.9888Z-256.3324B99.1851C-57.981
X70.8013Y-121.4568Z-255.733B99.185C-60.6816
X65.0117Y-124.6517Z-255.1337B99.1849C-63.3761
X59.0781Y-127.5711Z-254.5345B99.185C-66.07
X53.0094Y-130.2099Z-253.9353B99.1851C-68.7672
X46.8196Y-132.5613Z-253.336B99.185C-71.4678
X40.533Y-134.6166Z-252.7366B99.1849C-74.1636
X34.1583Y-136.3737Z-252.1374B99.185C-76.8571
X27.7037Y-137.8301Z-251.5382B99.1851C-79.5537
X21.1831Y-138.9815Z-250.9389B99.185C-82.2541
X14.6212Y-139.8241Z-250.3395B99.1849C-84.9512
X8.0309Y-140.357Z-249.7403B99.185C-87.6444
X1.4185Y-140.5796Z-249.1411C-90.3404
X-5.2019Y-140.4903Z-248.5418B99.1851C-93.0403
X-11.8073Y-140.0898Z-247.9424B99.1849C-95.7388
X-18.3807Y-139.3798Z-247.3432C-98.4319
X-24.917Y-138.361Z-246.744B99.185C-101.1273
X-31.403Y-137.0345Z-246.1447B99.1851C-103.8265
X-37.8182Y-135.4044Z-245.5453B99.1849C-106.5261
X-44.1426Y-133.4766Z-244.946C-109.2194
X-50.3718Y-131.2528Z-244.3469B99.185C-111.9142
X-56.494Y-128.7363Z-243.7477B99.1851C-114.6126
X-62.4918Y-125.9339Z-243.1483B99.185C-117.3129
X-68.3438Y-122.8564Z-242.549B99.1849C-120.0067
X-74.0461Y-119.5064Z-241.9498B99.185C-122.701
X-79.5884Y-115.8892Z-241.3506B99.1851C-125.3986
X-84.9564Y-112.0133Z-240.7513B99.185C-128.0993
X-90.1297Y-107.8943Z-240.152B99.1849C-130.794
X-95.1037Y-103.5368Z-239.5528B99.185C-133.4878
X-99.8706Y-98.9469Z-238.9536B99.1851C-136.1848
X-104.4186Y-94.1346Z-238.3543B99.185C-138.8854
X-108.7306Y-89.1192Z-237.7549B99.1849C-141.5814
X-112.8007Y-83.9082Z-237.1557B99.185C-144.2748
X-116.6237Y-78.5082Z-236.5565B99.1851C-146.9711
X-120.1905Y-72.9302Z-235.9573C-149.6712
X-123.4884Y-67.1951Z-235.3579B99.1849C-152.3684
X-126.511Y-61.3152Z-234.7588B99.185C-155.0614
X-129.2555Y-55.2959Z-234.1596C-157.7571
X-131.7153Y-49.1494Z-233.5604B99.1851C-160.4567
X-133.8821Y-42.8969Z-232.961B99.1849C-163.1552
X-135.7508Y-36.5554Z-232.3618C-165.8481
X-137.3202Y-30.1297Z-231.7626B99.185C-168.5433
X-138.5861Y-23.6322Z-231.1635B99.1851C-171.2421
X-139.5447Y-17.0831Z-230.5641B99.1849C-173.9417
X-140.1936Y-10.5038Z-229.9649C-176.6349
X-140.5326Y-3.8987Z-229.3657B99.185C-179.3295
X-140.5604Y2.7201Z-228.7665B99.1851C-182.0277
X-140.2763Y9.334Z-228.1672B99.185C-184.7279
X-139.6823Y15.9188Z-227.5679B99.1849C-187.4217
X-138.7794Y22.4698Z-226.9688B99.185C-190.1157
X-137.5683Y28.9757Z-226.3696B99.1851C-192.8131
X-136.0513Y35.4204Z-225.7703B99.185C-195.5136
X-134.2352Y41.7787Z-225.171B99.1849C-198.2084
X-132.1225Y48.0443Z-224.5719B99.185C-200.9019
X-129.7156Y54.2078Z-223.9727B99.1851C-203.5986
X-127.0193Y60.2549Z-223.3735B99.185C-206.299
X-124.0447Y66.1624Z-222.7741B99.1849C-208.9951
X-120.797Y71.9213Z-222.175B99.185C-211.6882
X-117.2797Y77.5248Z-221.5758B99.1851C-214.3844
X-113.4996Y82.9603Z-220.9766C-217.0843
X-109.4708Y88.2084Z-220.3772B99.1849C-219.7818
X-105.2026Y93.2576Z-219.778B99.185C-222.4749
X-100.6991Y98.1037Z-219.1788C-225.1707
X-95.9686Y102.7356Z-218.5796B99.1851C-227.8702
X-91.0274Y107.1381Z-217.9802B99.1849C-230.569
X-85.8898Y111.2992Z-217.381C-233.2621
X-80.5595Y115.2162Z-216.7818B99.185C-235.9573
X-75.0465Y118.8807Z-216.1826B99.1851C-238.6561
X-69.3674Y122.2814Z-215.5832B99.1849C-241.3559
X-63.5416Y125.4074Z-214.9839C-244.0493
X-57.5731Y128.2574Z-214.3847B99.185C-246.744
X-51.4725Y130.825Z-213.7855B99.1851C-249.4421
X-45.2562Y133.1032Z-213.1861B99.185C-252.1426
X-38.9475Y135.0839Z-212.5868B99.1849C-254.8368
X-32.5517Y136.7662Z-211.9876B99.185C-257.5309
X-26.0791Y138.1467Z-211.3884B99.1851C-260.2284
X-19.5454Y139.2212Z-210.7891B99.185C-262.9292
发表于 2017-9-23 11:56:12 | 显示全部楼层
后处理可以分享下吗{:smile:}
 楼主| 发表于 2017-9-23 13:12:22 | 显示全部楼层
后处理加密了 我也看不了
灌水王论坛元老
发表于 2017-9-23 15:01:18 | 显示全部楼层
程式軸不等於機械軸,用程式的座標來看,不要用機械的軸定義來看
发表于 2017-11-21 15:37:57 | 显示全部楼层
看看编程远点有没有在工件的回转中心,没有的话就会出现这种情况。
 楼主| 发表于 2018-2-9 11:03:42 | 显示全部楼层
有做mazak五轴的吗
GMT+8, 2025-2-20 18:55
