查看: 1517|回复: 0
[求助] 能否在已有的二次开发程序中动态调用已有的dll?
发表于 2017-6-5 09:34:41 | 显示全部楼层 |阅读模式
代码如下:(目前测试是不成功的,想请教如果可以,需要设置哪些东西?)
int CHANGE_action_0_act_cb ( int dialog_id,
             void * client_data,
             UF_STYLER_item_value_type_p_t callback_data)
     /* Make sure User Function is available. */
     if ( UF_initialize() != 0)
          return ( UF_UI_CB_CONTINUE_DIALOG );
     /* ---- Enter your callback code here ----- */
  char * library_name = "C:\\Users\\user\\Desktop\\ceshi-dll\\c2\\c2\\x64\\Debug\\c2.dll";
  char * symbol_name = "uf_test_2";
  typedef int(* lpFunc)(int);
  lpFunc func;
  HINSTANCE hDll;
   int response;
  if(hDll = LoadLibrary(library_name))
   func = (lpFunc)GetProcAddress(hDll,symbol_name);
  if (func != NULL)
   func(response);
   UF_UI_unlock_ug_access(UF_UI_FROM_CUSTOM);
  FreeLibrary(hDll);
     UF_terminate ();
    /* Callback acknowledged, do not terminate dialog */
    return (UF_UI_CB_CONTINUE_DIALOG);
    /* or Callback acknowledged, terminate dialog.    */
    /* return ( UF_UI_CB_EXIT_DIALOG );               */
GMT+8, 2026-9-21 17:22
