查看: 3682|回复: 8
[求助] UG同步建模里的(调整圆角的大小)在UGopen API的函数是哪个
发表于 2017-5-5 23:02:20 | 显示全部楼层 |阅读模式
各位师傅,谁知道同步建模里的(调整圆角的大小)在UGopen API的函数是哪个啊?先谢谢了!
贵宾
论坛技术员论坛贡献
发表于 2017-5-6 17:55:17 | 显示全部楼层
NXOpen::Features::ResizeBlendBuilder
贵宾
论坛技术员论坛贡献
发表于 2017-5-6 18:47:52 | 显示全部楼层
34
 楼主| 发表于 2017-5-6 20:22:17 | 显示全部楼层
谢谢唐师!可我在UGopen里找不到呢,你给的是NXopen的函数吗,NXopen还不会弄
34
 楼主| 发表于 2017-5-6 20:24:12 | 显示全部楼层
对的,我要的就是这种效果
34
 楼主| 发表于 2017-5-6 20:27:51 | 显示全部楼层
唐师:原代码发给我研究一下呢,谢谢了!
34
 楼主| 发表于 2017-5-27 21:32:54 | 显示全部楼层
唐工:麻烦帮我看我的程序哪里出问题了,谢谢!
    /* TODO: Add your application code here */
    NXOpen::Session *theSession = NXOpen::Session::GetSession();
    NXOpen::Part *workPart(theSession->Parts()->Work());
    NXOpen::Part *displayPart(theSession->Parts()->Display());
  char *message="选择面。";
  char *title="调整倒圆大小";
  int  scope=UF_UI_SEL_SCOPE_WORK_PART;
  int  response;
  tag_t object_tag;
  double  cursor[3]={0.0};
  tag_t view=NULL_TAG;
  UF_UI_lock_ug_access (UF_UI_FROM_CUSTOM);
  UF_UI_select_with_single_dialog(message,title,scope,init_proc,NULL,&response,&object_tag,cursor,&view);
  UF_DISP_set_highlight(object_tag,0);
  UF_UI_unlock_ug_access (UF_UI_FROM_CUSTOM);
  if (response==UF_UI_OBJECT_SELECTED)
    Face *body1(dynamic_cast<Face *>(NXObjectManager::Get(object_tag)));
    NXOpen::Features::Feature *nullNXOpen_Features_Feature(NULL);
    NXOpen::Features::ResizeBlendBuilder *resizeBlendBuilder1;
    resizeBlendBuilder1 = workPart->Features()->CreateResizeBlendBuilder(nullNXOpen_Features_Feature);
    double radius1;
    radius1 = resizeBlendBuilder1->GetBlendFaceRadius(body1);
          resizeBlendBuilder1->Radius()->SetRightHandSide("15");
        NXOpen::Features::Feature *feature1;
    feature1 = resizeBlendBuilder1->CommitFeature();
    NXOpen::Expression *expression1(resizeBlendBuilder1->Radius());
    resizeBlendBuilder1->Destroy();
    /* Terminate the API environment */
34
 楼主| 发表于 2017-5-27 21:36:53 | 显示全部楼层
出现如下提示
出现如下提示
34
 楼主| 发表于 2017-5-28 16:06:35 | 显示全部楼层
功夫不负有心人
GMT+8, 2025-2-25 00:35
