查看: 2350|回复: 1
[求助] UG10.0帮助文件调出错误求解!!!!!!
发表于 2017-3-23 15:26:50 | 显示全部楼层 |阅读模式
错误如下,求稳怎么破{:cry:}HTTP ERROR 500
Problem accessing /tdoc/nx/10/nx_help/. Reason:
    Server Error
Caused byrg.apache.jasper.JasperException: PWC6033: Error in Javac compilation for JSPPWC6199: Generated servlet error:The type java.io.ObjectInputStream cannot be resolved. It is indirectly referenced from required .class files        at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:129)        at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:299)        at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:392)        at org.apache.jasper.compiler.Compiler.compile(Compiler.java:453)        at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:625)        at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)        at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:492)        at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:378)        at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1448)        at org.apache.logging.log4j.core.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:59)        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1419)        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:455)        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:575)        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)        at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:276)        at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:103)        at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:209)        at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:267)        at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1221)        at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1005)        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:952)        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)        at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)        at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1448)        at org.apache.logging.log4j.core.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:66)        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1419)        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:455)        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:533)        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:255)        at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:154)        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:116)        at org.eclipse.jetty.server.Server.handle(Server.java:368)        at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:489)        at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:942)        at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:1004)        at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:640)        at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:235)        at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:82)        at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:628)        at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:52)        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:608)        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:543)        at java.lang.Thread.run(Unknown Source)
Powered by Jetty://、
发表于 2017-3-24 14:57:45 | 显示全部楼层
更改路径?
GMT+8, 2025-4-24 06:40
