楼主: 最高境界*
[原创] 编程员拒绝加班会被公司开除吗?——最高境界帮你解答
 火... [复制链接]
发表于 2017-3-12 20:42:48 | 显示全部楼层
发表于 2017-3-12 22:32:53 | 显示全部楼层
生成bom表ENTITY/obj(1000),ln1,ln2,ln3,pla(6),$
                ln4,ln5,ln6,ln7,ln8,ln9,ln10,ln(1000)
      NUMBER/x(1000),y(1000),z(1000),p(6),h,w(50),I,J,N,lo,$
              xmin,xmax,ymin,ymax,zmin,zmax,w1,distan(7),$
                x1,y1,z1,v,ans,m(100),u1,mindis(6),$
               m1(1000),num(1000),num1(1000),l,p1,q1,r1
      STRING/a(1000),b(1000),c(1000),d(1000),getname(1000,1000),$
             name(1000,1000),t(10),stock(1000,1000),fix(1000),$
             half(4,1000),part_name(132)
      DATA/half,'罗鸣提示:选择的实体是哪侧镶件',$
             '定模镶件',$
             '动模镶件',$
             '滑块镶件'
l10:
      mask/70
      ident/'罗鸣提示:选择镶件实体,数目小于100',obj,CNT,N,rsp
      jump/l10:,hal:,,,rsp
      p1=0
l20:
      DO /l30:,J,1, N
  l21:    getname(J)=&NAME(obj(J))
         ifthen/lenf(getname(J))==0
         r1=&COLOR(obj(J))
          &COLOR(obj(J))=&RED
         messg/'罗鸣提示:红色实体没有命名'
    a7:
        TEXT/'罗鸣提示:输入红色实体名称',part_name,RSP1
       JUMP/a7:,hal:,,RSP1
         &name(obj(J))=part_name
        &COLOR(obj(J))=r1
        jump/l21:
        ELSE
        endif
l30:
     J=1
    m(J)=1
    num(J)=0
l40:
      DO /L50:,I,1,N
        ans=CMPSTR(getname(J),getname(I))
         IFTHEN/ans==1
              m(J)=m(J)+ans
              num(J)=num(J)
         ELSEIF/ans==0
            m(J)=m(J)
            num(J)=num(J)+1
          ELSE
             m(J)=m(J)
             num(J)=num(J)
          ENDIF
L50:
    IFTHEN/J>N
         JUMP/l60:
      ELSE
         J=J+1
         m(J)=1
         num(J)=0
         JUMP/l40:
      ENDIF
l60:
       CHOOSE/half(1..4),DEFLT,1,RSP
       JUMP/l60:,hal:,,,l70:,l80:,l90:,RSP
l70:
      fix='_fix_'
       l=100
      JUMP/l100:
l80:
       fix='_move_'
        l=300
       JUMP/l100:
l90:
       fix='_slide_'
        l=500
l100:
      VIEW/1
     GPOS/'罗鸣提示:选择备料单表格放置点',$
         x1,y1,z1,rsp
     JUMP/l100:,hal:,,,,rsp
      w(1)=10
      w(2)=30
      w(3)=60
      w(4)=10
      h=6
      ln1=LINE/x1,y1,x1+w(1)+w(2)+w(3)+w(4),y1
      u1=0
l110:
      DO /l120:,I,1,N
        IFTHEN/num(I)==1
       u1=u1+num(I)
       ELSE
       u1=u1+1/num(I)
        ENDIF
l120:
       K=1
       J=1
l130:
      DO /l160:, K, 1, N
        DO /l150: , I, 1, N
         IFTHEN/m(I)==K
           m1(J)=I
           name(J)=ISTR(l+J)+fix+&NAME(obj(I))
           num1(J)=num(I)
           I=N
           lo=1
         ELSE
            lo=0
          ENDIF
l150:
     IFTHEN/lo==0
          J=J
       ELSE
          J=J+1
        ENDIF
l160:
     N=u1
     NOTE/x1+w(1)/2,y1-(h/2),'NO.'
              NOTE/x1+w(1)+w(2)/2,y1-(h/2),'NAME'
              NOTE/x1+w(1)+w(2)+w(3)/2,y1-(h/2),'STOCK'
              NOTE/x1+w(1)+w(2)+w(3)+w(4)/2,y1-(h/2),'QTY'
    DO /l170:, I, 1, N
              ln(I)=LINE/PARLEL,ln1,YSMALL,I*h
                p=solbox/obj(m1(I))
                xmin=minf(p(1),p(4))
                xmax=maxf(p(1),p(4))
                ymin=minf(p(2),p(5))
                ymax=maxf(p(2),p(5))
                zmin=minf(p(3),p(6))
                zmax=maxf(p(3),p(6))
$print/xmin,xmax,ymin,ymax,zmin,zmax
draw/off
        pla(1)=PLANE/YZPLAN,(xmin-10)
        pla(2)=PLANE/YZPLAN,(xmax+10)
        pla(3)=PLANE/XZPLAN,(ymin-10)
        pla(4)=PLANE/XZPLAN,(ymax+10)
        pla(5)=PLANE/XYPLAN,(zmin-10)
        pla(6)=PLANE/XYPLAN,(zmax+10)
                distan=reldst/pla(1),obj(m1(I))        $测量两个物体的距离
                mindis(1)=absf(distan(7))        $mindis(7)为距离
                distan=reldst/pla(2),obj(m1(I))
                mindis(2)=absf(distan(7))
                distan=reldst/pla(3),obj(m1(I))
                mindis(3)=absf(distan(7))
                distan=reldst/pla(4),obj(m1(I))
                mindis(4)=absf(distan(7))
                distan=reldst/pla(5),obj(m1(I))
                mindis(5)=absf(distan(7))
                distan=reldst/pla(6),obj(m1(I))
                mindis(6)=absf(distan(7))
DELETE/pla
draw/on
                xmin=(xmin-10)+mindis(1)
                xmax=(xmax+10)-mindis(2)
                ymin=(ymin-10)+mindis(3)
                ymax=(ymax+10)-mindis(4)
                zmin=(zmin-10)+mindis(5)
                zmax=(zmax+10)-mindis(6)
        x(I)=absf(xmax-xmin)
        y(I)=absf(ymax-ymin)
        z(I)=absf(zmax-zmin)
      &DECPL = 3
       a=FSTRL(x(I))
       b=FSTRL(y(I))
       c=FSTRL(z(I))
       stock(I)=a+'*'+b+'*'+c
              t=ISTR(I)
              NOTE/x1+w(1)/2,y1-(h/2)-I*h,t
       NOTE/(x1+w(1)+w(2)/2),y1-(h/2)-I*h,name(I)
       NOTE/x1+w(1)+w(2)+w(3)/2,y1-(h/2)-I*h,stock(I)
       NOTE/x1+w(1)+w(2)+w(3)+w(4)/2,y1-(h/2)-I*h,ISTR(num1(I))
l170:
        ln2=LINE/x1,y1,x1,y1-(N+1)*h
        ln3=LINE/PARLEL,ln2,XLARGE,w(1)
        ln4=LINE/PARLEL,ln3,XLARGE,w(2)
        ln5=LINE/PARLEL,ln4,XLARGE,w(3)
        ln6=LINE/PARLEL,ln5,XLARGE,w(4)
        ln7=LINE/PARLEL,ln1,YSMALL,(N+1)*h
hal:
    HALT
发表于 2017-3-12 22:32:55 | 显示全部楼层
             '定模镶件',$
             '动模镶件',$
             '滑块镶件'
l10:
      mask/70
      p1=0
l20:
      DO /l30:,J,1, N
         r1=&COLOR(obj(J))
          &COLOR(obj(J))=&RED
    a7:
       JUMP/a7:,hal:,,RSP1
        &COLOR(obj(J))=r1
        jump/l21:
        ELSE
        endif
l30:
     J=1
    m(J)=1
    num(J)=0
l40:
      DO /L50:,I,1,N
         IFTHEN/ans==1
              m(J)=m(J)+ans
              num(J)=num(J)
         ELSEIF/ans==0
            m(J)=m(J)
            num(J)=num(J)+1
          ELSE
             m(J)=m(J)
             num(J)=num(J)
          ENDIF
L50:
    IFTHEN/J>N
         JUMP/l60:
      ELSE
         J=J+1
         m(J)=1
         num(J)=0
         JUMP/l40:
      ENDIF
l60:
l70:
      fix='_fix_'
       l=100
      JUMP/l100:
l80:
       fix='_move_'
        l=300
       JUMP/l100:
l90:
       fix='_slide_'
        l=500
l100:
      VIEW/1
         x1,y1,z1,rsp
      w(1)=10
      w(2)=30
      w(3)=60
      w(4)=10
      h=6
      u1=0
l110:
      DO /l120:,I,1,N
        IFTHEN/num(I)==1
       u1=u1+num(I)
       ELSE
       u1=u1+1/num(I)
        ENDIF
l120:
       K=1
       J=1
l130:
      DO /l160:, K, 1, N
        DO /l150: , I, 1, N
         IFTHEN/m(I)==K
           m1(J)=I
           num1(J)=num(I)
           I=N
           lo=1
         ELSE
            lo=0
          ENDIF
l150:
     IFTHEN/lo==0
          J=J
       ELSE
          J=J+1
        ENDIF
l160:
     N=u1
    DO /l170:, I, 1, N
                p=solbox/obj(m1(I))
draw/off
DELETE/pla
draw/on
      &DECPL = 3
       a=FSTRL(x(I))
       b=FSTRL(y(I))
       c=FSTRL(z(I))
              t=ISTR(I)
l170:
hal:
    HALT
发表于 2017-3-12 22:35:40 | 显示全部楼层
b35n{:sad:}
发表于 2017-3-12 22:40:49 | 显示全部楼层
        老大总结的很好”有实力就可以不加班“呜哈
发表于 2017-3-12 22:43:22 | 显示全部楼层
好好学习天天向上
发表于 2017-3-12 22:55:09 | 显示全部楼层
学习学习学习学习
发表于 2017-3-12 23:23:13 | 显示全部楼层
111111111111111111111111111111111111111111
发表于 2017-3-13 12:01:13 | 显示全部楼层
发表于 2017-3-13 12:58:15 | 显示全部楼层
学习学习
GMT+8, 2025-4-26 07:47
