查看: 8510|回复: 4
[求助] msh文件导入失败,求大神指教
发表于 2017-2-25 10:24:54 | 显示全部楼层 |阅读模式
Error: This appears to be a surface mesh.
Surface meshes cannot be read under the /file/read-case functionality.
Reading Cells: failed while reading section 12.
       Clearing partially read grid.
Error: Read_Grid_Section: Aborted due to critical error.
Error Object: #f
Error: Error reading "H:\Fluent\Gambit\pipe.msh".
Error Object: #f
网上说是没有划分体网格,我又划分了好几变,可是还不成功,求大神指教
发表于 2018-8-31 11:11:25 | 显示全部楼层
回帖奖励 +1 G币
楼主解决了吗我也遇到这问题,请多指教
发表于 2020-4-11 19:02:28 | 显示全部楼层
楼主能告知解决了吗,急求,会的可以说一下吗
发表于 2020-4-11 19:03:02 | 显示全部楼层
楼主解决了吗,急求解决方法。
发表于 2021-10-16 14:55:34 | 显示全部楼层
求答案
GMT+8, 2025-2-23 04:30
