查看: 2005|回复: 1
[求助] UF_OBJ_cycle_by_name
发表于 2017-1-30 13:43:34 | 显示全部楼层 |阅读模式
程序执行完后就提示致命错误,UG就强制退出,怎么解决这个问题,我知道是UF_OBJ_cycle_by_name这个函数这里出错,但是怎么解决UF_initialize();
        tag_t cylinderfaceTAG = NULL_TAG;
        const char name[MAX_ENTITY_NAME_SIZE+1] = {"CYLINDER_FACE"};
        UF_OBJ_cycle_by_name(name,&cylinderfaceTAG);
        int type2;
        double ponit2[3];
        double dir2[3];
        double box2[3];
        double radius2;
        double rad_date2;
        int norm_dir2;
        UF_MODL_ask_face_data(cylinderfaceTAG,&type2,ponit2,dir2,box2,&radius2,&rad_date2,&norm_dir2);
        UF_UI_open_listing_window();
        char msg[200],msg2[200],msg3[200];
        sprintf(msg,"%d\n%f\t%f\t%f\n%f\t%f\t%f\n",type2,ponit2[0],ponit2[1],ponit2[2],dir2[0],dir2[1],dir2[2]);
        UF_UI_write_listing_window(msg);
        sprintf(msg2,"%f\t%f\t%f\t%f\t%f\t%f\t\n",box2[0],box2[1],box2[2],box2[3],box2[4],box2[5]);
        UF_UI_write_listing_window(msg2);
        sprintf(msg3,"%f\t%f\t%d\n",radius2,rad_date2,norm_dir2);
        UF_UI_write_listing_window(msg3);
        UF_terminate();
 楼主| 发表于 2017-1-31 22:45:14 | 显示全部楼层
现在又报错UF_MODL_ask_data,函数问题,难度不是这样用?
GMT+8, 2026-9-27 21:15
