楼主: 星夜冰宫
[求助] UGNX11.0后处理构造器打不开求解决!
发表于 2017-8-23 13:29:09 | 显示全部楼层
如一1984 发表于 2017-6-11 10:49
1. 在NX安装目录下找到POSTBUILD文件夹并进到文件夹里面;
2. 编辑post_builder.bat文件:在set PB_HOME= ...
非常感谢,真的有用!!!!!
发表于 2017-9-13 01:36:50 | 显示全部楼层
关于UG11.0后处理构造器打不开的问题找到11.0文件安装目录如图所示在set PB_HOME=%base_dir%\postbuild下面加上set UGII_BASE_DIR=%base_dir%然后保存就ok了
发表于 2017-10-9 22:19:49 | 显示全部楼层
@echo off
@setlocal
REM #########################################################################
REM Revisions
REM =========
REM v800
REM ----
REM Jan-26-2011 gsl - Set SUB_POST to activate subpost functionalities
REM==========================================================================
REM PB_HOME is the only env var referenced in the Post Builder source codes.
REM It should be set based on the Post Builder installation.
set base=%1
set base_dir=%base:"=%
set UGII_BASE_DIR=%base_dir%  是这样加么?好像不行
REM <01-26-2011 gsl>
REM Set variable to activate subpost functionalities.
set SUB_POST=1
REM UG DLL's search path.
set PATH=%base_dir%\UGII;%PATH%
REM Some vars for Tcl etc.
set PB_TCL=%PB_HOME%\tcl
set TCL_LIBRARY=%PB_TCL%\share\tcl8.4
set TK_LIBRARY=%PB_TCL%\share\tk8.4
set TIX_LIBRARY=%PB_TCL%\share\tix8.4
REM Force off debug mode in PB
set UGII_CHECKING_LEVEL=0
REM Tcl DLL search path
set PATH=%PB_TCL%\exe;%PATH%
REM Start Post Builder
"%PB_HOME%\app\post_builder.exe" "%*"
@endlocal
REM Post Builder returns 0 as the result of a successful run, otherwise
REM it returns a non-zero value.
if ERRORLEVEL 0 goto END
  pause
:END
发表于 2018-2-2 08:03:27 | 显示全部楼层
多谢指点,问题已经解决{:smile:}
发表于 2018-8-27 21:07:33 | 显示全部楼层
感谢,已经解决
GMT+8, 2025-1-10 17:32
