最快明日提供下载地址。
本次更新:Subject: Maintenance Pack 3 for NX 11.0.0 and SC 11.0.0 To: All users of NX 11.0.0 and SC 11.0.0 From: The Siemens PLM NX and Siemens PLM Simcenter Teams We are pleased to inform you that fixes are available for the problems listed below. A maintenance pack (MP3), built for installation on top of Windows64 and Linux64 images of NX 11.0.0 and SC 11.0.0, can now be downloaded from the Siemens PLM Download Server. This maintenance pack addresses the issues associated with the PR numbers and short descriptions listed in the tables below: Release | | | | | Error opening a routing assembly | | | Batch Processing with delay time does not work | | | Error opening a routing assembly | | | General WAVE Relinker doesn’t choose automatically IPE with multiple occurrences | | | Changes to named references prevent saving | | | NX crashes with an error when trying to open a part file | | | Option Report Shortest Tool doesn’t include the field (OS) Offset. | | | Option Report Shortest Tool doesn’t include the field (OS) Offset. | | | Report shortest Tool length is not correct for Zlevel | | | Error loading fem after replacing component | | | PMI Appended Text, parameter link only possible to parameters of default group | | | When in expression dialog, selecting objects in PNT does not work like NX10.0.2 | | | Measurement Failed with “Null Tag not allowed” Error when Measuring in Motion Application | | | Editing an Interpart Expression name | | | Expression dialog: after apply the new focus is on Visibility-Show | | | | | | Expression: New Expression ignores Active Group | | | Unable to open part with error “An embedded object cannot be deleted in isolation” | | | Repeat Command (F4) not available for AddOns |
Release | | | | | Subordinate Design Elements removed when finishing Subset in NX. | | | Teamcenter Attribute mapped in NX is not showing Display Name of LOV value | | | Standard Part Assembly Constraints have invalid RM references to components | | | NX 11.0.0 MP0 patch has hardcoded the wrong Title |
Release | | | | | Need to have an identifier for Inverse Bending Lines in Profile List. | | | Delete Deform for Deformable Component causes unexpected results | | | Issues with Profile List Export regarding Weld Properties | | | Fast RMS evaluation gives different solid stress results than standard evaluation | | | Transitioning after Validate Basic Design and Dry run still results in an error | | | Remove unused msvcr71.dll | | | | | | Toolpath Contact Point differences between NX9 & NX10.0.3 | | | Unable to create stiffener - Invalid trailer found | | | Need to be able to specify Item Type for Bending Templates (assemblies) | | | "Remove Spools" only removes the Stock Features while the Components remain in the spool | | | Generating Welds has an enormous performance impact when publishing welds during Save | | | Creating/Editing Expression by NXOpen using ug_read_list formula fails in NX11 | | | Spline path shape change intermittently leaves control points in previous position | | | NX crashes while exporting a part |
Release | | | | | Subordinate Design Elements removed when finishing Subset in NX. | | | Case sensitive expressions do not update correctly in Part Family spreadsheet | | | Part Families - Expressions are changed when new number is assigned | | | Save As fails with new name, after part name is stored in a tabular note | | | NX Mono JT Export does not honor suppression | | | LWSV of NX Mono JT Export Cuts through all components in view | | | Vis Piece Components do not display in view when using Assembly Context Control | | | Deleting a section cut component cuts the entire assembly | | | Assembly Geometry does not display in view with non-geometric component | | | Installation views do not display subset geometry when launched to TcVis | | | Longer time delay displaying PMI Balloon note dialog | | | NXMGR: Loading Assembly drawings in NX9: Error- Could not close O/S file | | | Upgrade OpenSSL 1.0.2h to OpenSSL 1.0.2j | | | | | | mom_mcs_goto differs from mom_pos in new drilling operations | | | NX11 MoldWizard will not Pocket components from mm moldbase. NX 10 will. | | | Tool position for material removal in CSE with 2 tracking points is not correct. | | | Hidden NX Geometry Visible in TcVis | | | Selection::SetSelectionStatusOfUserDefinedClass() does not add UDO class in NX11 | | | Geometry missing in PMI Model Views | | | Getting an error while saving the part file. | | | unable to stop a verify between GOTO points | | | Assembly cannot be converted to CATIA Data in the [Save As]. | | | When [Export]-[CATIA V5] is executed, the NX data disappears. | | | Part family spreadsheet seems corrupted | | | NX freezes after some selections of the same component | | | Bad curve distance given when part w/ coincident studio splines open in session | | | GRIP &ATTVL ignores IFERR label and throws error message anyway in NX11 | | | GRIP &ATTVL ignores IFERR label and throws error message anyway in NX11 | | | OK Button not active after UF_UGMGR_reg_new_dataset_name callback running | | | Unable to export to JT with CPU 100 usage in Linux Redhat 7.0 |
Windows update instructions
The files contained in nx-11.0.0.mp03.zip are provided as replacements for previously installed NX 11.0.0 and SC 11.0.0 products.
For the Windows64 platform, you should have at least 3.56 GB of free space to unzip this file.
Version NX 11.0.0 or SC 11.0.0 must be installed before updating to version NX 11.0.0.mp03. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
To use this update, change to the directory where you unzipped the nx-11.0.0.mp03.zip file, make sure the entire set of new MP files have execute access.
Then do either one of the following: 1. Run 'run_ugsupdate.exe' This will read the %UGII_BASE_DIR% from the Registry and apply the update to the NX 11.0.0 or SC 11.0.0 folder.
2. OR, you may follow the instructions below to run ugs_update.bat directly.
Before running the script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 11.0.0 or SC 11.0.0 release or set to the appropriate installed directory on your system. Then execute the 'ugs_update.bat' script.
For example:
Set UGII_BASE_DIR="C:\Program Files\Siemens\NX 11.0" cd nx1100_mp03
ugs_update.bat /v
The script supports a "/v" switch to turn on verbose messages while doing the file updates. The default operation of the script is non-verbose.
The script supports a "/d" switch. This will turn off the script confirmation prompts; useful for running the update in a batch job.
The script also supports a "/p" switch. This will turn off the initial confirmation prompt but it will display the final 'done' prompt. This is useful for running the update in a batch job where a final prompt is desired.
LINUX update instructions The files contained in nx-11.0.0.mp03.tar.gz are provided as replacements for previously installed NX 11.0.0 and SC 11.0.0 products.
For the Linux64 platform, you should have at least 4.63 GB of free space.
To use this update, change to the directory where you extracted the nx-11.0.0.mp03.tar.gz distribution file, make sure the entire set of new MP files have execute access, then execute the “ugs_update” script.
cd nx1100_mp03 chmod 555 * ./ugs_update -v
The script will interrogate your installed NX or SC directory, and update the installed files. The normal operation of the script is non-verbose; stop to confirm default answers.
The update script supports 2 switches: -v = Display verbose messages. -d = Take all default answers (i.e.: script will not stop to ask questions).
After the MP update has run successfully, the following identifying text will be written into the system log of every NX and SC session:
"NX 11.0.0.33 MP3, 17Nov16. See Maintenance Pack letter for detailed list of fixes."
If you have any issues with the installation or support of these fixes, please contact your local Siemens PLM GTAC support group.
Sincerely,
该贴已经同步到 老叶的微博 |
