查看: 2617|回复: 2
[分享] UG利用UI创建块 圆柱
发表于 2016-10-30 15:55:26 | 显示全部楼层 |阅读模式
               创建块
                Part *workpart(theSession->Parts()->Work());
                NXString length,width,height;
                Point3d origin=this->point0->GetProperties()->GetPoint("Point");
                double lengthValue =this->doubleLength->GetProperties()->GetDouble("Value");
                double widthValue =this->doubleWidth->GetProperties()->GetDouble("Value");
                double heightValue =this->doubleHeight->GetProperties()->GetDouble("Value");
                std::stringstream slength;
                slength<<lengthValue;
                length=slength.str();
                std::stringstream swidth;
                swidth<<widthValue;
                width=swidth.str();
                std::stringstream sheight;
                sheight<<heightValue;
                height=sheight.str();
                Features::Feature *null_block_feature(NULL);
                Features::BlockFeatureBuilder *blockfeaturebuilder;
                blockfeaturebuilder=workpart->Features()->CreateBlockFeatureBuilder(null_block_feature);
                blockfeaturebuilder->SetOriginAndLengths(origin,length,width,height);
                //commit
                blockfeaturebuilder->CommitFeature();
                //destroy
                blockfeaturebuilder->Destroy();
               创建圆柱
                NXString diamerString,heihtString;
                std::stringstream ssdia,ssheight;
                BlockStyler::PropertyList*vectorProperty=vector0->GetProperties();
                Vector3d vec=vectorProperty->GetVector("Vector");
                delete vectorProperty;
                vectorProperty=NULL;
                BlockStyler::PropertyList*pointProperty=point0->GetProperties();
                Point3d point=pointProperty->GetPoint("Point");
                delete pointProperty;
                pointProperty=NULL;
                BlockStyler::PropertyList*diaProperty=expressionDia->GetProperties();
                double dia=diaProperty->GetDouble("Value");
                delete diaProperty;
                diaProperty=NULL;
                BlockStyler::PropertyList*heightProperty=expressionH->GetProperties();
                double height=heightProperty->GetDouble("Value");
                delete heightProperty;
                heightProperty=NULL;
                ssdia<<dia;
                diamerString=ssdia.str();
                ssheight<<height;
                heihtString=ssheight.str();
                //create the cylinder feature
                 Part *workPart(theSession->Parts()->Work());
                 Part *displayPart(theSession->Parts()->Display());
         Features::Feature *nullNXOpen_Features_Feature(NULL);
                 Features::CylinderBuilder *cylinderBuilder1;
                 cylinderBuilder1 = workPart->Features()->CreateCylinderBuilder(nullNXOpen_Features_Feature);
                 cylinderBuilder1->Diameter()->SetRightHandSide(diamerString);
                 cylinderBuilder1->Height()->SetRightHandSide(heihtString);
                 cylinderBuilder1->SetDirection(vec);
                 cylinderBuilder1->SetOrigin(point);
                 cylinderBuilder1->CommitFeature();
                 cylinderBuilder1->Destroy();
贵宾
论坛技术员论坛贡献
发表于 2016-10-30 16:42:14 | 显示全部楼层
可以直接doubleLength->Value(),代码会更简洁。
在对应的类中,有这个成员函数。只有极个别的没有对应的函数来获取UI的值。
 楼主| 发表于 2016-10-31 11:08:40 | 显示全部楼层
在对应的类中,有这个成员函数。只有极个别的没有对应的 ...
那个圆锥能帮我看看咋回事啊   现在还是没搞对
GMT+8, 2026-9-19 18:55
