查看: 4805|回复: 6
[求助] 求哈斯机床热机程序
发表于 2016-10-20 20:43:17 | 显示全部楼层 |阅读模式
各位大侠谁有哈斯机床的热机程序,就是新机床自带的那个程序号是2020,和2121两个
 楼主| 发表于 2016-10-20 20:43:56 | 显示全部楼层
谁有发一个
发表于 2016-10-20 20:52:20 | 显示全部楼层
我有。
发表于 2016-10-20 20:53:52 | 显示全部楼层
VF2的。自己微调。
发表于 2016-10-20 20:54:45 | 显示全部楼层
O02020 (Spindle Warm-up)
(This program should be run prior to)
(machine use if machine has been idle)
(for more than 4 days.)
(Cycle time: 20-minutes.)
(This program can be used for all)
(spindle types and may be used daily)
(for spindle warm-up prior to high)
(speed spindle use. Adjust spindle)
(speed override depending on maximum)
(spindle speed of machine: Set)
(override at 50% for 5,000 rpm)
(machines, set at 100% for 7,500)
(& 10,000 rpm machines, and set at)
(150% for 15,000 rpm machines.)
(9-21-99)
/M8
S100 M03
M97 P11 L2
M97 P1 L8
S200 M03
M97 P1 L8
S300 M03
M97 P1 L7
S400 M03
M97 P1 L6
S500 M03
M97 P1 L6
S600 M03
M97 P1 L4
S700 M03
M97 P1 L6
M99
N11
G91 G01 X-761. Y-408. F2000.
G04 P1.
G91 G01 X761. Y408. F2000.
G04 P1.
M99
N1
G91 G01 X-761. Y-408. F4000.
G04 P1.
G91 G01 X761. Y408. F4000.
G04 P1.
M99
 楼主| 发表于 2016-10-23 06:34:05 | 显示全部楼层
好,谢谢了,有没有热主轴的那个?
 楼主| 发表于 2016-10-23 06:34:59 | 显示全部楼层
好,谢谢了,有没有热主轴的那个?
GMT+8, 2025-2-20 06:22
