查看: 2202|回复: 0
[分享] CAD快捷命令
发表于 2016-10-7 15:26:19 | 显示全部楼层 |阅读模式
使用必读
MLCK,      *YX_MLCK
;选项
ZDY,       *YX_ZDY
;环境设置
NA,        *YX_NEWALL
NL,        *YX_LAY_NEWALL
NS,        *YX_NEWSTYLE
ND,        *YX_NEWDIMSTY
STM,       *YX_STM
XF,        *YX_BDXF
YM,        *YX_YXML
;隐藏工具
HY,        *YX_HIDE
HU,        *YX_SHOW
J,        *YX_HB
UB,        *YX_UB
H6,        *YX_HIDEA
U6,        *YX_SHOWA
H7,        *YX_HIDEB
U7,        *YX_SHOWB
;图层工具
BL,        *YX_BL
LO,        *YX_LAY_OFFSEL
LOO,       *YX_LAY_OFFSELO
LOP,       *YX_LAY_OFFP
LUO,       *YX_LAY_ALLON
Lk,        *YX_LAY_LOCKSEL
Lkk,       *YX_LAY_LOCKSELL
LkP,       *YX_LAY_LOCKP
LkU,       *YX_LAY_UNLOCKSEL
LUL,       *YX_LAY_ALLUNLOCK
LF,        *YX_LAY_FREEZESEL
LFF,       *YX_LAY_FREEZESELF
LFP,       *YX_LAY_FREEZEP
LUF,       *YX_LAY_ALLTHAW
LUU,       *YX_LAY_ALLTUO
KDA,       *YX_LAY_DIMALL
KDTA,      *YX_LAY_DIMTMPALL
;设置当前图层
AI_MOLC,   *YX_AI_MOLC
LC,        *YX_LAY_SET_CENTER
LCO,       *YX_LAY_SET_COOL
LCR,       *YX_LAY_SET_CORE
LD,        *YX_LAY_SET_DIM
LDT,       *YX_LAY_SET_DIM_TEMP
L1,        *YX_LAY_SET_EPIN
LFR,       *YX_LAY_SET_FROM
LH,        *YX_LAY_SET_HATCH
LI,        *YX_LAY_SET_INSERT
LA,        *YX_LAY_SET_LIFT
LM,        *YX_LAY_SET_MOLDBASE
LP,        *YX_LAY_SET_PART
LR,        *YX_LAY_SET_RUNNER
LS,        *YX_LAY_SET_SCREW
LSL,       *YX_LAY_SET_SLIDE
LSP,       *YX_LAY_SET_SP
LST,       *YX_LAY_SET_STD
LSR,       *YX_LAY_SET_SPRING
LTE,       *YX_LAY_SET_TEMP
LT,        *YX_LAY_SET_TEXT
;线工具
CE,        *YX_CEN
vb,        *YX_CEN
SCF,       *YX_SCF
AXS,       *YX_AXS
SEC,       *YX_SEC
SX,        *YX_SX
KL,        *YX_KL
HL,        *YX_HL
TT,        *YX_TT
TY,        *YX_TY
FG,        *YX_FF
FD,        *YX_FD
CHL,       *YX_CHL
AS,        *YX_AS
SL,        *YX_SL
ZS,        *YX_ZS
OU,        *YX_OU
YL,        *YX_YL
LM,       *YX_LM
YT,        *YX_YT
STS,       *YX_STS
LN,        *YX_LN
DFX,       *YX_DFX
BN,        *YX_BREAK
OL,        *YX_OL
HH,        *YX_HH
VV,        *YX_VV
XC,        *YX_XC
;圆工具
AC,        *YX_AC
CTY,       *YX_CTY
CTU,       *YX_CTU
ER,        *YX_EDR
;块工具
EB,        *YX_EB
BG,        *YX_BG
BF,        *YX_BF
BS,        *YX_BS
BI,        *YX_BI
EC,        *YX_EC
BAA,       *YX_BAA
BAC,       *YX_BAC
BC,        *YX_BC
EXB,       *YX_EXB
EBT,       *YX_EBT
BRE,       *YX_BRE
NB,        *YX_NB
BUN,       *YX_BUN
BNU,       *YX_BNU
EG,        *YX_EG
EUG,       *YX_EUG
;文字工具
CK,        *YX_CK
JK,        *YX_JK
MJ,        *YX_MJ
WT,        *YX_WT
TH,        *YX_TH
TE,        *YX_TXTEXP
;旋转
E1,        *YX_E1
R1,        *YX_R1
E2,        *YX_E2
R2,        *YX_R2
E3,        *YX_E3
R3,        *YX_R3
E45,       *YX_E45
R45,       *YX_R45
E4,        *YX_E4
R4,        *YX_R4
R5,        *YX_R5
;复制旋转
CR,        *YX_CR
CE1,       *YX_CE1
CR1,       *YX_CR1
CE2,       *YX_CE2
CR2,       *YX_CR2
CE3,       *YX_CE3
CR3,       *YX_CR3
CE45,      *YX_CE45
CR45,      *YX_CR45
CE4,       *YX_CE4
CR4,       *YX_CR4
CR5,       *YX_CR5
;颜色工具
CB,        *YX_CB
CV,        *YX_CV
1,        *YX_C1
2,        *YX_C2
3,        *YX_C3
4,        *YX_C4
5,        *YX_C5
6,        *YX_C6
7,        *YX_C7
8,        *YX_C8
9,        *YX_C9
KBL,       *YX_BYLAYEROBJ
XS,        *YX_XS
X1,        *YX_X1
X2,        *YX_X2
X3,        *YX_X3
X4,        *YX_X4
X5,        *YX_X5
A1,        *YX_A1
A2,        *YX_A2
A3,        *YX_A3
A4,        *YX_A4
A5,        *YX_A5
;常用工具
ROO,       *YX_ROO
CRR,       *YX_CRR
VD,        *YX_VD
VS,        *YX_VS
EW,        *YX_EW
EQ,        *YX_EQ
BJ,        *YX_BJ
BX,        *YX_BX
ML,        *YX_ML
Q1,       *YX_4MI
Q2,       *YX_4RC
JT,        *YX_JT
ZG,        *YX_ZG
REGSS,     *YX_REGSS
RH,        *YX_RH
SS,        *YX_SS
SCC,       *YX_SCC
RR,        *YX_RR
MM,        *YX_MM
CC,        *YX_CC
PU,        *YX_PU
LJ,        *YX_LJ
ZYT,       *YX_ZYT
FS,        *YX_FS
FCC,       *YX_FCC
;计算工具
CM,        *YX_CM
CA,        *YX_CA
CS,        *YX_CS
CG,        *YX_CG
;模具工具
BM,        *YX_BM
QB,        *YX_QB
JG,        *YX_JG
DT,        *YX_DT
CJ,        *YX_CJ
VE,        *YX_VE
JB,        *YX_JBFD
AU,        *YX_ASMOUT
FC,        *YX_FC
EWE,       *YX_EWE
ETU,       *YX_ETU
ETY,       *YX_ETY
EXE,       *YX_EXE
MK,        *YX_MK
;模具资料
PI,        *YX_PI
PM,        *YX_PM
PC,        *YX_PC
PE,        *YX_PE
PG,        *YX_PG
PT,        *YX_PT
;模具标准件
K,         *YX_K
MB,        *YX_MB
CL,        *YX_CL
ET,        *YX_ET
TF,        *YX_TF
SW,        *YX_SW
SR,        *YX_SPRUE
HS,        *YX_HS
SP,        *YX_SP
AG,        *YX_AG
LP,        *YX_LP
XW,        *YX_XW
EGP,       *YX_EGP
GE,        *YX_GE
ES,        *YX_ES
SW2,       *YX_SW2
SBM,       *YX_SBM
;标注加强工具
DQ,        *YX_DQ
d,         *YX_D
DE,        *YX_DE
DX,        *YX_DX
DW,        *YX_DW
DA,        *YX_DA
DDR,       *YX_DDR
DD,        *YX_DD
DV,        *YX_DV
DC,        *YX_DC
DB,        *YX_DB
q,         *YX_Q
;标注超强工具
AQ,        *YX_AQ
UY,        *YX_UY
UYF,       *YX_UYF
SH,        *YX_SH
N,         *YX_N
DF,        *YX_DF
CCD,       *YX_CCD
DS,        *YX_DS
DH,        *YX_DH
DAQ,       *YX_DAQ
DDE,       *YX_DDE
DDW,       *YX_DDW
GG,       *YX_DDA
DR,        *YX_DR
;标注修改工具
QD,        *YX_QD
AD,        *YX_AD
EED,       *YX_EED
DTH,       *YX_DTH
UYU,       *YX_UYU
UYQ,       *YX_UYQ
DUP,       *YX_DUP
DAUP,      *YX_DAUP
DTZ,       *YX_DTZ
DSC,       *YX_DSC
DTC,       *YX_DTC
DCC,       *YX_DCC
DEC,       *YX_DEC
DG,        *YX_DG
DTK,       *YX_DTK
DFZ,       *YX_DFZ
DAF,       *YX_DAF
DAZ,       *YX_DAZ
DDZ,       *YX_DDZ
DGL,        *YX_DGL
SDTA,      *YX_SDTA
;标注检查工具
CUY,       *YX_CUY
CDA,       *YX_CDA
CDD,       *YX_CDD
CDT,       *YX_CDT
CDE,       *YX_CDE
CDS,       *YX_CDS
;标注文字工具
DTY,       *YX_DTY
DN,        *YX_DN
DM,        *YX_DM
DS1,       *YX_DS1
DS2,       *YX_DS2
D1,        *YX_D1
D2,        *YX_D2
D3,        *YX_D3
D4,        *YX_D4
D5,        *YX_D5
D6,        *YX_D6
D7,        *YX_D7
D8,        *YX_D8
D9,        *YX_D9
AT1,       *YX_AT1
AT2,       *YX_AT2
AT3,       *YX_AT3
DA1,       *YX_DA1
DA2,       *YX_DA2
DA3,       *YX_DA3
DA4,       *YX_DA4
DA5,       *YX_DA5
DA6,       *YX_DA6
DA7,       *YX_DA7
DA8,       *YX_DA8
;倒圆角
F,         *YX_F
FT,        *YX_FT
F01,       *YX_F01
F02,       *YX_F02
F03,       *YX_F03
F05,       *YX_F05
F1,        *YX_F1
F2,        *YX_F2
F3,        *YX_F3
F4,        *YX_F4
F5,        *YX_F5
F6,        *YX_F6
F7,        *YX_F7
F8,        *YX_F8
F9,        *YX_F9
F10,       *YX_F10
F20,       *YX_F20
F30,       *YX_F30
F50,       *YX_F50
;倒角
G,         *YX_G
GT,        *YX_GT
G01,       *YX_G01
G02,       *YX_G02
G03,       *YX_G03
G05,       *YX_G05
G1,        *YX_G1
G2,        *YX_G2
G3,        *YX_G3
G4,        *YX_G4
G5,        *YX_G5
G6,        *YX_G6
G7,        *YX_G7
G8,        *YX_G8
G9,        *YX_G9
G10,       *YX_G10
G12,       *YX_G12
G20,       *YX_G20
G30,       *YX_G30
G50,       *YX_G50
;延长
Yu,         *YX_Y
Y01,       *YX_Y01
Y02,       *YX_Y02
Y03,       *YX_Y03
Y05,       *YX_Y05
Y1,        *YX_Y1
Y2,        *YX_Y2
Y3,        *YX_Y3
Y4,        *YX_Y4
Y5,        *YX_Y5
Y6,        *YX_Y6
Y7,        *YX_Y7
Y8,        *YX_Y8
Y9,        *YX_Y9
Y10,       *YX_Y10
Y12,       *YX_Y12
Y20,       *YX_Y20
Y30,       *YX_Y30
Y50,       *YX_Y50
;偏移
OO,        *YX_OO
O01,       *YX_O01
O02,       *YX_O02
O03,       *YX_O03
O05,       *YX_O05
O1,        *YX_O1
O2,        *YX_O2
O3,        *YX_O3
O4,        *YX_O4
O5,        *YX_O5
O6,        *YX_O6
O7,        *YX_O7
O8,        *YX_O8
O9,        *YX_O9
O10,       *YX_O10
O12,       *YX_O12
O20,       *YX_O20
O30,       *YX_O30
O50,       *YX_O50
http://www.zuopinaihaozhe.com
GMT+8, 2025-4-30 01:52
