查看: 6478|回复: 5
[求助] 求大神翻译UG的说明
Rank: 2
发表于 2013-5-4 10:47:35 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Installation Notice
This is the description of Mold Wizard NX 8.5 Engineering Data Base Installation.
1. Windows XP :
  a. Download and unzip mwnx8.5_data.zip to a folder, such as "d:\moldwizard_data".
  b. Set MOLDWIZARD_DIR environment variable to the above folder, for example "set MOLDWIZARD_DIR=d:\moldwizard_data".
  c. In order for the Bill of Materials tool to work properly, copy \moldwizard\templates\moldwizard_add_in.xla to C:\Program Files\Microsoft Office\Office\XLStart directory
  d. For Win64 bit machine, you need to set MOLDWIZARD_DIR environment variable explicitly in .bat file or System Environment Variables.
2. Windows 7 :
     C:\apps\MSOffice\Office12\XLSTART directory ( For Microsoft Office 2007 ),
     or C:\apps\MSOffice\Office14\XLSTART directory ( For Microsoft Office 2010 )
3. For All platforms:
Siemens PLM Software recommends that you install the engineering database in a location outside the default ...\UGII_BASE_DIR\moldwizard location. You can put the library in shared location on your network, and point to it with the environment variable MOLDWIZARD_DIR.
4. Easy Fill
  a. Easy Fill integration package is included in this data base.
  b. First time run flow analysis needs administrator permission.
  c. Set WCS to absolute CSYS before starting flow analysis.
Notice
1. For Wint64 bit machine,  If BOM Export to Excel can not work.
Solution: put cursor in bom list Title Field area, MB3 -> Export to Spreadsheet.
2. Reserved part attribute.
The part attribute name of Material (or MATERIAL) is reserved by NX8.5, before starting to use NX/Mold Wizard application, you have to:
a. Open Customer Defaults settings by File->Utilities->Customer Defaults.
b. Expand Gateway->Materials/Mass.
c. Go to Attirbutes tab and turn off Create Attribute for Part Material.
d. Click OK and restart NX.
Problems Solved in This Release
1. Standard parts: Updated DME, HASCO, PUNCH, MEUSBURGER, OMNI catalogs:
   a. Metric
DME Locating Ring data.
        DME Spring Set data.
        HASCO Spring Set data.
        MEUSBURGER meusburger_mm registry.
        PUNCH guide_rail data.
   b. English
        OMNI cavity_rnd model.
        OMNI insulation data.
2. Mold base: Updated MEUSBURGER catalog:
   a. meus_d_eng_int.xls  (MEUSBURGER_DRILLED_INTERCH)
   b. meus_d_ger_int.xls  (MEUSBURGER_VERBOHRT_INTERCH)
   c. meus_eng_int.xls    (MEUSBURGER_PLAIN_INTERCH)
   d. meus_ger_int.xls    (MEUSBURGER_UNVERBOHRT_INTERCH)
3. PR#6589686 : DME Sprue returns Consistancy and Self Intersection failure when Timing is used.
4  PR#1883051 : Excel MW Add-In 'Export to Xess' stops at line 1501 and truncates file.
5. PR#6663803 : Progressive Ejector Pin English has wrong catalog info in spreadsheet.
6. PR#6663856 : shoulder ejector pin head type 3and 4 incorrect false body.
7. PR#1891994 : Moldwizard DME_M ejector bumper assembly has non sufficient assembly constraint.
8. PR#1889994 : MW FHCS Socket Head Countersunk screw has non-standard dimensions.
9. PR#1891947 : Moldwizard False Body of Hasco screws has a small flat at the tool tip.
10. PR#6692204 : Mixed Units in MW Standard Parts create incorrect screw sizes.
11. PR#1891857 : MW Hasco Z10/Z1000 has wrong criteria compared to Hasco specs.
12. PR#6692204 : Mixed Units in MW Standard Parts create incorrect screw sizes.
13. Fix the fit distance adjustment issue for MISUMI straight ejector pins.
New Database in This Release
1. DMS moldbase Library [Metric]
2. DMS Standard Library [Metric]
3. Universal Standard Library [Metric]
4. Fill Standard Library [metric]
5. Cool Standard Library [Metric]
6. Slide/Lifter Standard Library [Metric]
If there are any problems or feedbacks, please contact:
  Zhi Li
  Email: li.zhi@siemens.com
Rank: 3Rank: 3
发表于 2013-5-4 17:54:43 | 只看该作者
要命呀  这么多   去百度翻译就好了
Rank: 2
 楼主| 发表于 2013-5-6 16:08:59 | 只看该作者
糊涂人 发表于 2013-5-4 17:54
要命呀  这么多   去百度翻译就好了
呵呵。其实我就是模具向导装不起来,折腾N久,终于完成了。。。谢谢你回复。。呵呵
Rank: 2
发表于 2013-5-21 19:40:00 | 只看该作者
能告诉下怎么装的吗
Rank: 1
发表于 2024-1-23 21:51:19 | 只看该作者
建议你装个中英文翻译插件
发表于 2024-2-3 10:00:14 | 只看该作者
有大神翻译一下GC工具箱的齿轮插件说明书吗
Powered by UG爱好者 X3.2  © 2001-2014 Comsenz Inc. GMT+8, 2024-11-24 13:26
