楼主: 副总经理
[图文教程] UG NX11.0帮助文档安装教程(通用)
 火.. [复制链接]
发表于 2017-11-12 13:48:59 | 显示全部楼层
安装完怎么不见  打开UG的那个图标的?
发表于 2017-11-12 14:52:45 | 显示全部楼层
安装完怎么不见  打开UG的那个图标的?
发表于 2017-11-26 22:39:00 | 显示全部楼层
按照要求安装了 打开UG按F1出现以下信息 是什么原因
HTTP ERROR 500
Problem accessing /tdoc/nx/11/nx_help/. Reason:
    Server Error
Caused by:
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.remoting.RemoteLookupFailureException: Lookup of RMI stub failed; nested exception is java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
        java.net.SocketTimeoutException: Read timed out
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:982)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
        at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85)
        at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
        at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
        at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
        at org.eclipse.jetty.server.Server.handle(Server.java:497)
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
        at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
        at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
        at java.lang.Thread.run(Unknown Source)
Caused by: org.springframework.remoting.RemoteLookupFailureException: Lookup of RMI stub failed; nested exception is java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
        at org.springframework.remoting.rmi.RmiClientInterceptor.lookupStub(RmiClientInterceptor.java:215)
        at org.springframework.remoting.rmi.RmiClientInterceptor.getStub(RmiClientInterceptor.java:237)
        at org.springframework.remoting.rmi.RmiClientInterceptor.invoke(RmiClientInterceptor.java:258)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207)
        at com.sun.proxy.$Proxy35.getDeliverableMetadata(Unknown Source)
        at com.siemens.plm.lmd.xps.output.tdocExt.server.TdocController.getDisplayConditionsLocation(TdocController.java:343)
        at com.siemens.plm.lmd.xps.output.tdocExt.server.TdocController.initializeModel(TdocController.java:182)
        at com.siemens.plm.lmd.xps.output.tdocExt.server.TdocController.launchCollection(TdocController.java:91)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:221)
        at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
        at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:111)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:806)
        at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:729)
        at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
        ... 28 more
Caused by: java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
        at sun.rmi.transport.tcp.TCPChannel.createConnection(Unknown Source)
        at sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
        at sun.rmi.server.UnicastRef.newCall(Unknown Source)
        at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
        at java.rmi.Naming.lookup(Unknown Source)
        at org.springframework.remoting.rmi.RmiClientInterceptor.lookupStub(RmiClientInterceptor.java:200)
        ... 49 more
Caused by: java.net.SocketTimeoutException: Read timed out
        at java.net.SocketInputStream.socketRead0(Native Method)
        at java.net.SocketInputStream.socketRead(Unknown Source)
        at java.net.SocketInputStream.read(Unknown Source)
        at java.io.BufferedInputStream.fill(Unknown Source)
        at java.io.BufferedInputStream.read(Unknown Source)
        at java.io.DataInputStream.readByte(Unknown Source)
        ... 55 more
Caused by:
发表于 2017-12-14 11:24:02 | 显示全部楼层
设了变量还是不行
发表于 2018-1-4 15:37:00 | 显示全部楼层
感谢,看一下有没有二次开发的api文档
发表于 2018-3-21 20:20:13 | 显示全部楼层
请问下这个失败是什么原因呢?
发表于 2018-8-15 15:49:02 | 显示全部楼层
你知道你在回复贴子,系统要让你回答问题几次?
发表于 2018-10-2 08:17:58 | 显示全部楼层
感谢!!!
发表于 2018-12-30 09:56:41 | 显示全部楼层
感謝樓主分享
GMT+8, 2025-4-25 17:25
