UID2707739
U币1
G币120
技术0
主题0
精华0
阅读权限20
注册时间2016-9-25
最后登录2019-1-18
在线时间10 小时
To view the Programming Tools help click here
On Windows systems, the Programming Tools help is an optional, selectable feature of the NX Help Install. If the above link does not work contact your system administrator to install the Programming Tools help, or perform the following steps if you have administrator privileges:
Insert the NX Documentation Windows DVD or access the install image.
Run setup.exe.
The Siemens NX 8.0 Documentation - InstallShield Wizard displays.
From the Custom Setup page which allows you to select the program features you want installed, click on the icon for NX API Manuals.
Be sure to install both the NX On-line Help and NX API Manuals in the same directory or links between the two help collections will not work.
Refer to the NX Documentation (UGDOC) Installation Instructions for Windows for assistance
