查看: 9619|回复: 20
[分享] UG_NX11.0.0 MP01升级补丁发布
德高才能望重
2293
站长优秀版主论坛技术员论坛元老论坛贡献推广达人
发表于 2016-9-13 15:02:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NX 11.0.0 MP1升级补丁提前发布,更新内容如下:
NX11.0正式版 缝合完成以后不显示边界的问题已经修复!
We are pleased to inform you that fixes are available for the problems listed below.  A maintenance pack (MP1), built for installation on top of Windows64 and Linux64 images of NX 11.0.0 and SC 11.0.0, can now be downloaded from the Siemens PLM Download Server.
This maintenance pack addresses the issues associated with the PR numbers and short descriptions listed in the tables below:
Release
PR Number
Short Description
MP0
7543147
Error opening a routing assembly
MP0
7686179
Batch Processing with delay time does not work
MP0
7721010
MP0
7723695
General WAVE Relinker doesn’t choose automatically IPE with multiple occurrences
MP0
7732325
Changes to named references prevent saving
MP0
7734413
NX crashes with an error when trying to open a part file
MP0
7740300
Option Report Shortest Tool doesn’t include the field (OS) Offset.
MP0
7745527
MP0
7760795
Report shortest Tool length is not correct for Zlevel
MP0
8277216
Error loading fem after replacing component
MP0
8288586
PMI Appended Text, parameter link only possible to parameters of default group
MP0
8298245
When in expression dialog, selecting objects in PNT does not work like NX10.0.2
MP0
8303559
Measurement Failed with “Null Tag not allowed” Error when Measuring in Motion Application
MP0
8305515
Editing an Interpart Expression name
MP0
8305522
Expression dialog: after apply the new focus is on Visibility-Show
MP0
8305952
Operating System Error
MP0
8306042
Expression: New Expression ignores Active Group
MP0
8308133
Unable to open part with error “An embedded object cannot be deleted in isolation”
MP0
8312278
Repeat Command (F4) not available for AddOns
Release
PR Number
Short Description
MP1
7497700
Subordinate Design Elements removed when finishing Subset in NX.
MP1
7683194
Teamcenter Attribute mapped in NX is not showing Display Name of LOV value
MP1
8293137
Standard Part Assembly Constraints have invalid RM references to components
MP1
8313250
NX 11.0.0 MP0 patch has hardcoded the wrong Title
Windows update instructions
The files contained in nx-11.0.0.mp01.zip are provided as replacements for previously installed NX 11.0.0 and SC 11.0.0 products.
For the Windows64 platform, you should have at least 3.08 GB of free space to unzip this file.
Version NX 11.0.0 or SC 11.0.0 must be installed before updating to version NX 11.0.0.mp01. Please be aware that these updated MP files will be superseded by the next maintenance release or maintenance pack installed on your machines.
To use this update, change to the directory where you unzipped the nx-11.0.0.mp01.zip file, make sure the entire set of new MP files have execute access.
Then do either one of the following:
1.  Run 'run_ugsupdate.exe'
This will read the %UGII_BASE_DIR% from the Registry and apply the update to the NX 11.0.0 or SC 11.0.0 folder.
2.  OR, you may follow the instructions below to run ugs_update.bat directly.
Before running the script, please make sure the environment variable %UGII_BASE_DIR% is set to the base directory of the NX 11.0.0 or SC 11.0.0 release or set to the appropriate installed directory on your system.  Then execute the 'ugs_update.bat' script.
For example:
         Set UGII_BASE_DIR="C:\Program Files\Siemens\NX 11.0"
         cd nx1100_mp01
         ugs_update.bat /v
The script supports a "/v" switch to turn on verbose messages while doing the file updates. The default operation of the script is non-verbose.
The script supports a "/d" switch. This will turn off the script confirmation prompts; useful for running the update in a batch job.
The script also supports a "/p" switch. This will turn off the initial confirmation prompt but it will display the final 'done' prompt. This is useful for running the update in a batch job where a final prompt is desired.
LINUX update instructions
The files contained in nx-11.0.0.mp01.tar.gz are provided as replacements for previously installed NX 11.0.0 and SC 11.0.0 products.
For the Linux64 platform, you should have at least 3.93 GB of free space.
To use this update, change to the directory where you extracted the nx-11.0.0.mp01.tar.gz distribution file, make sure the entire set of new MP files have execute access, then execute the “ugs_update” script.
cd nx1100_mp01
chmod 555 *
./ugs_update -v
The script will interrogate your installed NX or SC directory, and update the installed files.  The normal operation of the script is non-verbose; stop to confirm default answers.
The update script supports 2 switches:
-v = Display verbose messages.
-d = Take all default answers (i.e.: script will not stop to ask questions).
After the MP update has run successfully, the following identifying text will be written into the system log of every NX and SC session:
"NX 11.0.0.33 MP1, 07Sep16.  See Maintenance Pack letter for detailed list of fixes."
If you have any issues with the installation or support of these fixes, please contact your local Siemens PLM GTAC support group.
Sincerely,
该贴已经同步到 老叶的微博
Rank: 10Rank: 10Rank: 10
67
发表于 2016-9-13 15:19:54 | 只看该作者
不可以下载?
德高才能望重
2293
 楼主| 发表于 2016-9-13 15:23:11 | 只看该作者
晚上或者明天上午。
发表于 2016-9-13 15:29:01 | 只看该作者
沙发!!
太好了,不知道那些BUG都改好了没?{:victory:}{:victory:}
点评
有几个BUG还是没有修复,这次是提前发布了  发表于 2016-9-13 15:31
Rank: 3Rank: 3
发表于 2016-9-13 16:09:10 | 只看该作者
11.0草图里的样条(不是艺术样条,这个命令是以前版本的),用样条这个命令画曲线时,确定后,尾部会飞走,我已经试了10.0 8.0 6.0 都不会飞,老叶能不能帮忙解决下。
67
发表于 2016-9-13 16:09:14 | 只看该作者
老叶 发表于 2016-9-13 15:23
晚上或者明天上午。
不知道修复了框选延迟问题了没有?
点评
这个不是BUG,你用NX10.0的套索试试就知道为什么了  发表于 2016-9-13 17:13
Rank: 8Rank: 8
24
发表于 2016-9-13 16:12:47 | 只看该作者
MP01基本没修复什么
发表于 2016-9-13 16:22:45 | 只看该作者
qys1002 发表于 2016-9-13 15:29
沙发!!
太好了,不知道那些BUG都改好了没?
西门子搞啥飞机啊,,,干脆九月底发布得了,搞一半丢一半的,,,
发表于 2016-9-13 16:23:06 | 只看该作者
沙发!!
太好了,不知道那些BUG都改好了没?
Rank: 4
发表于 2016-9-13 17:00:54 | 只看该作者
Powered by UG爱好者 X3.2  © 2001-2014 Comsenz Inc. GMT+8, 2024-11-22 12:16
