楼主: haoyuan366
[视频教程] MasterCAM后处理修改2(修改pst添加程序号与井号详解)
 火... [复制链接]
发表于 2017-5-30 23:35:13 | 显示全部楼层
punclamp        #Unclamp the rotary axis
      if use_clamp,
        #Force both rotaries to unlock if multi-axis
        if cuttype <> zero & opcode$ <> three & opcode$ <> 16 & (p_lock = one | s_lock = one),
          p_lock = zero, s_lock = zero
          pbld, n$, *s_slock, e$
          pbld, n$, *s_plock, e$
        else,  #Unlock the rotary axis if it is locked and moving
          if p_inc, p_lock = zero
          if s_inc, s_lock = zero
          pbld, n$, s_slock, e$
          pbld, n$, s_plock, e$
pclamp          #Clamp the rotary axis
      if use_clamp & (cuttype = zero | opcode$ = three | opcode$ = 16),
        if p_inc, p_lock = one
        if s_inc, s_lock = one
pbld            #Canned text - block delete
      if bld, '/'
pccdia          #Cutter Compensation
      #Force Dxx#
      sav_cc_pos = cc_pos$
      if cc_pos$ & pln_2_rev, cc_out = abs(cc_pos$ - three)
      else, cc_out = cc_pos$
      if prv_cc_out <> cc_out & cc_out, result = force(tloffno$,tloffno$)
      sccomp
      if cc_out, tloffno$
      cc_pos$ = sav_cc_pos
      !cc_pos$     # 01/26/04
pscool          #Coolant output
      scoolant   #Old style coolant - based on NCI variable "coolant$"
      pcan1_cool #X style coolant - based on Canned Text coolant
psign_ang_out   #Signed angle output modification
      if pang_output,
        sv_p_abs = p_abs
        ppsign_ang
        if p_inc, result = force(p_out,p_out)
        else, !p_out
      if sang_output,
        sv_s_abs = s_abs
        pssign_ang
        if s_inc, result = force(s_out,s_out)
        else, !s_out
psign_ang_res   #Restore p_abs with signed angle output
      if pang_output, p_abs = sv_p_abs
      if sang_output, s_abs = sv_s_abs
parc_setup      #Force the arc position output
      if pln_2_rev, gcode$ = abs(gcode$ - five)
parcijk         #Select the arc output
      if arcoutput$ = zero | full_arc_flg$,
        #Arc output for IJK
        iout, jout, kout
        !i$, !j$, !k$
      else,
        #Arc output for R
        if abs(sweep$)<=arc180 | arcoutput$=one, result = nwadrs(srad, arcrad$)
        else, result = nwadrs(srminus, arcrad$)
        *arcrad$
p_nobrk_emul    #'nobrk' emulation option
      if abs(zinc)<brk_tol | not(abs(xinc)>brk_tol | abs(yinc)>brk_tol)
        | not(mtype = zero | mtype = three),
        if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
        prapidout
      else,
        nobrk_xa = vequ(xabs)
        nobrk_xi = vequ(xinc)
        nobrk_pa = vequ(p_abs)
        nobrk_pi = vequ(p_inc)
        #Z up, move Z, XY, PRI, SEC
        if zinc > zero,
          #Kill X, Y, PRI, SEC
          xabs = prv_xabs
          yabs = prv_yabs
          xinc = zero
          yinc = zero
          p_abs = prv_p_abs
          s_abs = prv_s_abs
          p_inc = zero
          s_inc = zero
          psign_ang_out #jphjph need p_dlt_ang, s_dlt_ang
          prapidout
          #Enable X, Y
          xabs = vequ(nobrk_xa)
          xinc = vequ(nobrk_xi)
          prapidout
          #Enable PRI, SEC
          p_abs = vequ(nobrk_pa)
          p_inc = vequ(nobrk_pi)
          ppos_cax_lin
        #Z down, move PRI, SEC, XY, Z
        else,
          #ppos_cax_lin handles rotation
          ppos_cax_lin
          #Kill Z
          zabs = prv_zabs
          zinc = zero
          prapidout
          #Enable Z
          prapidout
      ##### Stop custom changes #####
发表于 2017-5-31 10:43:06 | 显示全部楼层
发表于 2017-6-1 19:08:57 | 显示全部楼层
sssssssssssssssssssssssss
发表于 2017-6-3 10:38:37 | 显示全部楼层
能不能输出刀塔编号呢?
发表于 2017-6-15 23:19:03 | 显示全部楼层
好东西好东西
发表于 2017-6-22 10:56:13 | 显示全部楼层
谢谢分享,谢谢分享
发表于 2017-6-22 22:05:30 | 显示全部楼层
车床MasterCAM后处理修改2
发表于 2017-6-22 22:05:58 | 显示全部楼层
RE: MasterCAM后处理修改2(修改pst添加程序号与井号详解)
车床MasterCAM后处理修改2
发表于 2017-6-27 16:34:42 | 显示全部楼层
阿萨德阿大神
发表于 2017-7-5 19:09:31 | 显示全部楼层
顶顶顶顶顶顶顶顶顶
GMT+8, 2025-3-7 09:09
